Center console safe
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boss hog, Oct 17, 2020.
  1. Dec 3, 2020 at 11:45 PM
    #121
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Mine came from Dallas.
    As far as the Lock'er Down vs. these less inexpensive alternatives, I've looked at one of those very closely (in a Ford, not a Tundra) and compared it to the one I have from Amazon and I have to say I don't see a lot there, at least not for the price difference.
    They're both just metal boxes bolted to the floor with a spring-loaded door and a cam lock.
    The locks are really the only differing factors, and from what I can tell there's nothing there to make me think one is superior to the other.
    They're all just a deterrent at best. If a thief wants in there, and they have the right tools, they're getting in there... either one.
    Sure, Lock'er Down is made in the USA and all that, but that in itself doesn't make it better, just more expensive.
    In the end its all about what your personal evaluation and comfort level is with the safe you choose. If you are more comfortable with the name brand version and believe its superior, then its the right choice for you. If you check out one of the less expensive and less advertised versions and feel its adequate for the job, then it probably is. Most gun owners will be able to tell right away whether a safe is up to the task or not.
    Hightide and Jalzate44 like this.
  2. Dec 4, 2020 at 5:49 PM
    #122
    Ncreator74
    Ncreator74 New Member
    2018 White XP Tundra
    Hi guys, I bought my 2018 truck a few weeks ago. It's used but well kept, it looks almost new. When I test drove it, I saw the safe box but didn't inquired about it (too many things to pay attention). After getting home the following day I tried to open the safe without luck. The key and the generic combination both seem to work in terms of turning the lock, however, it doesn't open. You can even feel the can lock engaging and disengaging when the turning the key, but still it doesn't open. Almost feel like is jammed. Have any of you had this issue? It seems to be the OEM model. I called the dealership and they say they don't have too many safe box before and they are not sure. The dealership is an hour away so I'm trying to see if it's something simple that can solve without going over there. If not, then I'll go.
  3. Dec 4, 2020 at 8:27 PM
    #123
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How far can you turn the chrome knob? I can take a picture of the cam so you can see what your dealing with if you need it.
  4. Dec 5, 2020 at 4:11 AM
    #124
    Ncreator74
    t goes all the way from the locked symbol to the unlocked symbol. It seems is turning all the way, except the door doesn't move, at all. The picture would be great because you are right, I don't know how theinside looks.
    Thanks Ruggybuggy
  5. Dec 5, 2020 at 7:48 AM
    #125
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Dec 5, 2020 at 7:50 AM
    #126
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    That’s the $58 one?
  7. Dec 5, 2020 at 9:57 AM
    #127
    OnespeedTRD
    Don
    San Diego
    Well that sucks. Interesting that the key doesn’t even work. Who knows if that’s the right key even since it’s used. I have no real solutions for you other than to drill or otherwise break into it. I’d be willing to start a replacement fund if you document breaking into it just so everyone can see how easy/hard it is to get into.
  8. Dec 5, 2020 at 10:03 AM
    #128
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Here how it looks on the inside with movement for lock to unlock.
    https://youtu.be/mEaL3bMDV1U
    For those wondering it the quality is the same between the Toyota safe and the knock off here are a couple of pictures showing the difference in the latch.
  9. Dec 5, 2020 at 10:06 AM
    #129
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    That's the one I got. I really like it.
    Ruggybuggy[QUOTED] likes this.
  10. Dec 5, 2020 at 10:35 AM
    #130
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Yep - and it was delivered a few minutes ago. It looks exactly like what has been described here, including the bent corner. It's pretty heavy, too. Pics:
    Hightide likes this.
  11. Dec 5, 2020 at 10:49 AM
    #131
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's strange, the bend corner on the OE always happens on the right rear corner.
  12. Dec 5, 2020 at 10:53 AM
    #132
    Jalzate44
    San Antonio TX
    Now I’m stoked to get mine. Says it will be here Monday
  13. Dec 5, 2020 at 11:01 AM
    #133
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    :yes:
    Mine too.
  14. Dec 5, 2020 at 12:15 PM
    #134
    CourtJester
    Alabama
    You’ll like it and it’s a freaken breeze to install.
  15. Dec 5, 2020 at 2:37 PM
    #135
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    And installed it while "putting Christmas decoration boxes up." :D
    I did have to remove the OEM tray, but my Dremel made quick work of that!
  16. Dec 5, 2020 at 3:36 PM
    #136
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Damn, I wish I saw this when they were $58!!!! Looks like the cheapest right now in $139
  17. Dec 5, 2020 at 4:41 PM
    #137
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    Got mine's today and it had the same dent on the right corner fixed it with a pair of pliers. The install was very easy and I'm pleased. I only spent 58.00 bucks thank to you guys posting the Black Friday Deals. Did not upload photos because everyone else did a great job on posting them.
  18. Dec 5, 2020 at 5:55 PM
    #138
    Ncreator74
    Thank so much for the pictures guys. It's a little better to understand what's going on inside. That's a pretty heavy duty cam inside. I'm wondering if the cam part of the lock is lose from the lock, so it doesn't matter when I turn the lock. Here are a few pics. Tried to upload video but I guess file it's too big.PXL_20201206_013838097.jpg PXL_20201206_013258418.jpg
    Wallygator likes this.
  19. Dec 5, 2020 at 6:08 PM
    #139
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When you swing the latch from left to right does it feel weighted? Maybe the nut came off the cam. I would try a slip something in the crack at an angle and see if you can feel the cam. You might be able to see it shiny in the crack with a flashlight. If the nut has came off you might be able to push the cam out of the slot through the crack in the door.
  20. Dec 5, 2020 at 6:18 PM
    #140
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    My 2020 came factory with a safe. Really nice feature
  21. Dec 5, 2020 at 6:39 PM
    #141
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Ya get what ya pay for!
  22. Dec 5, 2020 at 9:56 PM
    #142
    Heatjay
    Heatjay New Member
    2018 TUNDRA PLATNIUM MG
    Damn $58. I slept on this
  23. Dec 6, 2020 at 12:03 AM
    #143
    The Fall Guy
    The Fall Guy New Member
    Vancouver, WA
    2018 Cement TRD Off Road DC
  24. Dec 6, 2020 at 4:40 AM
    #144
    shawn474
    MoCo, Maryland
    TomC843 and The Fall Guy[QUOTED] like this.
  25. Dec 6, 2020 at 7:37 AM
    #145
    The Fall Guy
    Vancouver, WA
    Had to do a little digging to find it but hopefully it pays off. Seems to be a similar build to the others offered but for about half the price.
  26. Dec 6, 2020 at 7:40 AM
    #146
    SouthWestGA
    SouthWestGA New Member
    If you bought it off Amazon
    Buy a second one
    Stick broken one in box
    return
    CourtJester likes this.
  27. Dec 6, 2020 at 11:31 AM
    #147
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Too much trouble. After I bent it back and installed it, only I can tell that there was ever anything wrong with it. Plus, as tight as it was getting it installed, I don't plan on EVER removing it!
  28. Dec 7, 2020 at 4:02 PM
    #148
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Mine arrived today - no bent corners at all. The combo-vs-key operation takes a little bit to understand: if the combination is not dialed to the unlock code, and the safe is UNLOCKED, you cannot use the key to lock it. But if the safe is LOCKED you can use the key to unlock and lock it.
    Planning on installing it this evening. I'll have to modify my OCD organizer to fit in the bottom once I get it installed. For $68 (with tax), I'm happy.
  29. Dec 7, 2020 at 4:45 PM
    #149
    AGuyFromNC
    AGuyFromNC New Member
    Nick
    2020 Tundra CM TRD Offroad
    My Black Friday special was delivered today. I havent had a chance to open the box up yet. I guess it's a game of chance if you get a bent corner or not.
  30. Dec 7, 2020 at 4:50 PM
    #150
    shawn474
    MoCo, Maryland
    Price just went up to $146!!!!
