Center console safe
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boss hog, Oct 17, 2020.
  1. Nov 11, 2020 at 7:13 AM
    #61
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I completely glossed over this sentence. This whole time I thought you had the Locker Down half safe, but you have one from Toyota. I'm going with this one. ~50 bucks cheaper than the Locker Down half safe (Sparks) & comes with a tray. "Tundradude34" code brought it down another 5%. Thanks!
    Ruggybuggy[QUOTED] and Zilla18 like this.
  2. Nov 11, 2020 at 7:34 AM
    #62
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When you get it check and see if the right rear corner is bent down slightly. Many that have received their safe had this issue. Use a rubber mallet and tap the corner back up before installing.
  3. Nov 11, 2020 at 7:35 AM
    #63
    Uhhhh....
    Dave
    7” BDS, 37s
    Okee dokee thanks!
  4. Nov 11, 2020 at 8:27 AM
    #64
    JPritch
    JPritch New Member
    Josh
    17 TSS Crewmax
    Here's an OEM. They are always $250+.
    Here are some of the non-OEM. They are half the price and seem to outnumber OEM 3-1 on eBay. In looking closer, it appears they are not identical to OEM (the lock looks different).
    They could be just as good as getting one from Toyota, but I'm hoping somebody else is my guinea pig.
    #64
    Wallygator likes this.
  5. Nov 11, 2020 at 9:42 AM
    #65
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    I was under the impression the sparks half safe was oem with the tray. This isn’t the case?
  6. Nov 11, 2020 at 9:56 AM
    #66
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The lock is definitely different. It uses a double sided key and knob looks plastic. Personally I would spend the extra dollars for known quality and the safety of my items.
    #66
    JPritch[QUOTED] likes this.
  7. Nov 14, 2020 at 1:49 PM
    #67
    daduls
    daduls New Member
    Agreed,
    I’m Feel better with firearms in my truck locked in this.
    Zilla18[QUOTED] likes this.
  8. Nov 14, 2020 at 3:48 PM
    #68
    Uhhhh....
    Dave
    7” BDS, 37s
    Sorry I didn’t see this. Yes it’s OEM. Southeast Toyota, so only that region carries it.
    Arrived today & installed it. It’s solid! Also, I managed to cut my OCD organizer to fit in each side, so have compartments, no dual-abyss.
    Hartsy8[QUOTED] likes this.
  9. Nov 14, 2020 at 3:48 PM
    #69
    Uhhhh....
    Dave
    7” BDS, 37s
    You leave firearms in your truck?
  10. Nov 14, 2020 at 4:17 PM
    #70
    Boss hog
    Boss hog [OP] Tundra_Tombstone
    San Antonio, Texas
    2021 Crewmax TSS 4WD --- Cement
    Wheels: KMC KM535 18x8.5 Tires: General Grabber X3 35/12.50 R18 F Bumper: C4 Fabrication Overland Series, powder coat black R Bumper: C4 Fabrication Overland Series, powder coat black Suspension: Fabtech 6" lift Interior Trim: A-pillar grab handle (Toyota Sequoia) Security: Exxtreme Console Safe ® Half Size Body: TRD Grill
    Do you have a pic of the organizer cut in half? I'm still trying decide how to keep the other half organized.
  11. Nov 14, 2020 at 4:26 PM
    #71
    Uhhhh....
    Dave
    7” BDS, 37s
  12. Nov 14, 2020 at 4:29 PM
    #72
    Boss hog
    San Antonio, Texas
    Uhhhh....[QUOTED] likes this.
  13. Nov 14, 2020 at 4:41 PM
    #73
    Uhhhh....
    Dave
    7” BDS, 37s
    If you end up getting one and cutting it, just be aware that the center console isn't perfectly square - it's shaped like an upside down trapezoid (the bottom of the console is slightly smaller than the top; though not nearly as pronounced as this):
    So that OCD organizer is shaped correctly to accommodate the trapezoid shape.
    The only problem with this, is the locking safe side has regular straight, 90-degree angle walls - so when you cut the organizer for that side, you need to cut both ends of the slats (thus cutting off the angle on each end & making it 90 degrees).
    On the open end of the console safe, one side is 90 degrees (the safe side), and the other side is the OEM side of the console, so it's slanted. For that side, you only cut the one end of the OCD organizer slats to make it 90 degrees: the end that touches the actual safe.
    It's not nearly as complicated as it sounds. If you pick up the organizer you'll see what I mean.
  14. Nov 14, 2020 at 8:57 PM
    #74
    Hartsy8
    Max
    2020 MGM 1794
    Wow this is great. I have the exact same organizer and was wondering what I was going to do with it. Thanks man!!!
  15. Nov 14, 2020 at 10:39 PM
    #75
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I'll be your guinea pig. I went through this same thing a few weeks ago. Wanted a half safe for convenience, but the "Toyota" brand was pretty pricy, and in all likelihood made by the same mfgr as these others, so I took a chance on one from Amazon.
    https://www.amazon.com/gp/product/B08C54Y49S/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    For half the cost I think its every bit as solid and sturdy as the Toyota version. Is it as solid as a Lock'r Down? Maybe... probably.
    I compared it to a buddy's with the Toyota version he got from Sparks and besides the lock they are pretty much identical. In fact, we both agreed the cover plate on mine was a little tighter and would be harder to get a tool under than his. I only use it if I have to run in somewhere where handguns are not allowed, never leave a gun in the safe overnight or long-term, so I think this safe is perfect for that use. For reference the gun in the pic is a Glock 43X, so you can see there is plenty of room in there for larger items, purses, wallets, whatever.
    #75
  16. Nov 15, 2020 at 5:49 PM
    #76
    JPritch
    JPritch New Member
    Josh
    17 TSS Crewmax
    @OnespeedTRD Man, I really appreciate your post! That's exactly the info I was looking for to make my decision. I also had never seen the interior space and wondered if my pistol would fit in there, but looks like it won't be an issue. I'm comfortable ordering the non-oem branded safe now.
  17. Nov 15, 2020 at 9:32 PM
    #77
    OnespeedTRD
    Don
    San Diego
    Yep, no problem. There's plenty of room in there for pretty much whatever you may need to keep in there. That piece of foam in the back is just laying in there, can't remember if it was part of the packing material or something I had laying around or what. It actually makes it look smaller than it is, but even with that its plenty big enough for a pistol, spare mags, flashlight, whatever you need.
    There are few different models on Amazon but the lock on this one looks a little more robust than the others, four digit combo vs three, and it came with two keys. It was shipped out of the DFW area and only took a couple of days to get here. I think you'll be more than satisfied with this one compared to the others out there, especially the OEM version. Between these and the Lock'r Down I just don't think its worth the extra cost as I can't see how they'd be any less defeatable than these to a determined thief. Since I'm not likely to leave my truck anywhere where that may happen, and especially not with my pistol in there, that's how I justified my decision.
  18. Nov 16, 2020 at 3:42 AM
    #78
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    One of the Amazon reviews indicated that the combination lock doesn't work. The way I read it, though, the writer of that review might not understand how it is supposed to work. If you don't use the keys at all, can you lock it securely using the combination lock? Then does the combination lock reliably unlock it to open? What are your experiences with this?
  19. Nov 16, 2020 at 8:09 AM
    #79
    gratefuljed
    gratefuljed New Member
    john
    Land of Enchantment
    2019 TUNDRA SR5 LB
    I have the locker down full size. While it might be considered an abyss I simply dropped a tray on some magnetic shelves inside. I'll also say I went with the keyed version first and it was a pain, the console won't shut with the key in and you can't leave it unlocked without the key in, so I upgraded for way too much money for the keyless. I can leave it unlocked, close both center console on top of unlocked safe, then lock the safe when I stop. I don't know about the other safes but I get the feeling a thief would have to steal my whole truck to work on gettin in the locker down . Buy once, cry once, but peace of mind is worth something
    Tundra234 and Ruggybuggy like this.
  20. Nov 16, 2020 at 9:00 AM
    #80
    OnespeedTRD
    Don
    San Diego
    Yeah, I read that review too. I think that person just doesn’t understand the concept of a combo lock with a keyed back up. The key will always unlock the box, even if the combo is locked and you spin the dial. Otherwise there’d be no point in having a key. My lock works fine, no issues at all. When you spin it to lock it it actually tightens the lid down a little more and snugs up pretty tight, then spin the dial and you’re set.
  21. Nov 16, 2020 at 9:05 AM
    #81
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    On a related note, I have a distributor-installed safe that occupies half the console, pretty nice and wasn’t very expensive, is there a tray-type organizer out there that will fit adjacent to the safe?
    KingsAustin likes this.
  22. Nov 16, 2020 at 3:30 PM
    #82
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Does the tray next to the safe come up for more storage?
  23. Nov 16, 2020 at 4:28 PM
    #83
    OnespeedTRD
    Don
    San Diego
    Yes, the upper tray sits around the edge of the opening and there is a little hole to access the USB port underneath, or use that hole to pull it out to keep larger items underneath. I keep my manual and other rarely used junk in there, small items on the tray, and knife, flashlight and pens in the little holders on the bottom of the armrest lid.
  24. Nov 17, 2020 at 8:28 PM
    #84
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Sweet, just bought it thanks to your review! I'm sure your commission check is in the mail.
    JPritch likes this.
  25. Nov 17, 2020 at 8:35 PM
    #85
    OnespeedTRD
    Don
    San Diego
    Nice! I'm sure you'll be happy with it. Let us know what you think when you get it.
  26. Nov 19, 2020 at 11:38 AM
    #86
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    We must have the same safe because I am in search for a half tray to join my console safe. Let me know if you track one down. Good luck!
  27. Nov 22, 2020 at 11:21 AM
    #87
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Got it and installed it! A little more involved as I had a dealer installed console organizer, which had 2 rails riveted in place. Getting the rails off was a pain, but besides that, easy install and sturdy safe. The safe door seems like there's a little too much play when it's locked, like I can pull up 3/4", but it is what it is.
  28. Nov 22, 2020 at 12:46 PM
    #88
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'd contact the seller and ask them about it.
    There shouldn't be that much play in the lid.
    You may just need a different sized cam offset to get rid of that play.
    Look down this link about half way and you'll see the different sized cams and the different offsets.
    Cam Lock Accessories | Cam Lock | Cam Lock Finger Pull (fjmsecurity.com)
    2C2BAFD2-26EF-4DF1-A9A8-49CD2FCCF629_zps_a2c82a4c2bac1cd0f176dbf3419d6e79d1ef5599.jpg
    Not sure who made your lock.
    But if you measured the cam: thickness, length, hole size, what offset you may need, perhaps you can figure out what you need.
    I had to work with it a bit when I put a Combi-cam on my swing case.
    TR15UCK[QUOTED] likes this.
  29. Nov 22, 2020 at 12:48 PM
    #89
    1lowlife
    DADA
    2014 MGM DC SR5
    Also on my vault I put a small piece of rubber weather-strip I had in the garage and put it in the grove where the door closes into the frame.
    It took some play out and my lid closes all the way down and securely.
    TR15UCK likes this.
  30. Nov 22, 2020 at 3:28 PM
    #90
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Thanks!
