Cb shackles/rear lift?
Discussion in 'Suspension' started by hollandhunter, Feb 2, 2018.
  1. Feb 2, 2018 at 7:57 AM
    hollandhunter
    hollandhunter [OP] New Member
    2017 SR5 CM 4x4
    Can someone please take me to school on the coach builder shackles. What are the pros and cons? I have a readylift 6 lift and wanna get rid of the rear blocks eventually. Is the cb shackles the way to go or is a whole new leaf pack the way to go? Or both? An what size do i need?
  2. Feb 2, 2018 at 8:12 AM
    Mike's Custom Toys
    Mike's Custom Toys New Member
    You will need to do both to get rid of a block completly. Most 6 inch kits run a 4" block. Most lift shackles give you 1-1.5 inches of lift. The Old Man Emu rear springs or ironman springs are good for 2-2.5". To get the full 4" you need to remove the block and keep the same rake you will need both.
    hollandhunter[OP] likes this.
  3. Feb 2, 2018 at 8:18 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    The Icon RXT leaf pack can be configured to give 4" in the rear and increases payload and wheel travel.
  4. Feb 2, 2018 at 8:24 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Also Total Chaos makes shackles that mate with the deaver packs. Just another option.
    One thing about the CBs that I'm not a fan of is you need to replace the bushing eyelets in the springs which is a pain. It provides a little more stability.
    equin, TheBeast and hollandhunter[OP] like this.
  5. Feb 2, 2018 at 8:28 AM
    hollandhunter
    2017 SR5 CM 4x4
    My readylift 6inch lift only came with 3inch rear blocks. Which suprised me but none the less it did. At first my nose was sticking up a couple inches in the front vs the back. But since it has settled its almost even. Still maybe a touch high in the front. So i would prolly want 3.5 or 4inches of lift in the rear.
  6. Mar 1, 2018 at 12:19 AM
    YTThao530
    YTThao530 New Member
    Have you installed a new leaf springs and shackles yet? If u do which one you go for?
  7. Mar 5, 2018 at 2:28 PM
    MRTUND460
    MRTUND460 New Member
    2010 CrewMax Platinum
    TRD Supercharged, Doug Thorley headers, MBRP cat back exhaust, DAP Tuned, 4.5" BDS lift, Firestone airbags, TRD sway bars, TRD big brakes, Icon CNC upper control arms Fox DSC shocks all 4 corners, Deaver custom rear leaf springs, 2018 Sequoia headlights.
    On my 4.5" BDS lift I installed the 3+ CB shackles and had all kinds of pinion angle issues that could not be resolved by carrier bearing spacers. I ordered custom Deaver springs (8 weeks to make) new 1+ CB shackles, installed all to find the shackles are too thick and hit the hitch where it bolts to the frame.
    The new Deavers are 3" longer than stock (didn't know that going into the install) so we ended up making our own custom shackles. Waiting for the oddly sized bolts to come in this Friday. Fingers crossed everything will work out!
    TheBeast and YTThao530 like this.
  8. Mar 5, 2018 at 2:33 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @MRTUND460
    What load are your new deavers built to handle? They look awesome. I’m looking forward to hearing how the install winds up!
    YTThao530 likes this.
  9. Mar 5, 2018 at 2:37 PM
    MRTUND460
    I had him build them specifically to offer me a nice smooth ride when not towing but strong enough to tow my 32ft trailer. When loaded we're at about 900lbs at the hitch. I also have Firestone airbags to help out with leveling.
  10. Mar 5, 2018 at 3:33 PM
    YTThao530
    Bad luck here! lol
    Told him to made a nice smooth ride like K37 but 3” off lift he said okay take about 8-10 week but only 3 week they just sent me a U748 with TC shackles 800lbs and get me 1.5 off lift! What part number you got on the leaf spring?38AA946D-82B3-428E-99B0-790568F17431.jpg
    040Tundra likes this.
  11. Mar 5, 2018 at 3:35 PM
    MRTUND460
    V435
    TheBeast likes this.
  12. Mar 5, 2018 at 3:40 PM
    YTThao530
    Thank I will call them
    3” off lift right ?
    MRTUND460[QUOTED] likes this.
  13. Mar 5, 2018 at 3:42 PM
    TheBeast The Beach
    never heard of her.
    Must be reference for custom work.
  14. Mar 5, 2018 at 3:42 PM
    TheBeast The Beach
    you selling them ? I might have a guy interested.
  15. Mar 5, 2018 at 3:47 PM
    MRTUND460
    Yes the springs were about 3" of lift but we got the rest we needed out of the custom shackles we built.
    I can only assume as again these were custom built to my requirements and again they are 3" longer eye to eye than the stock ones. Mine also have 9 leafs total.
    YTThao530[QUOTED] likes this.
  16. Mar 5, 2018 at 3:50 PM
    TheBeast The Beach
    the Deavers are always longer from what I seen. I have the K37s and they were longer than stock
  17. Mar 5, 2018 at 3:51 PM
    YTThao530
    I talk to Deaver spring and they will made a new one for me but he said he will let Fedex come pick up the leaf spring I will call them again to lowball and will let you know
    TheBeast[QUOTED] likes this.
  18. Jan 14, 2019 at 6:17 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    With the U748's and TC 3/4" Shackles, how much height did you gain in the rear? Lookin at pairing this combo with Billy 5160's and those shocks are good up to 1.5" of lift
  19. Jan 15, 2019 at 11:18 PM
    YTThao530
    u748 and TC3/4 your get about 2” of lift..
    iamsmokey[QUOTED] likes this.
  20. Jan 17, 2019 at 11:55 AM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I’ve done the icon RXT with cb +3 shackles in my 7in BDS Lift! It worked perfectly to remove my lift block and now when I tow or haul the truck doesn’t squat as much! Before with like 300 pounds in the bed it would hit the bump stop but now with over 1000 it will NOT touch the bumps!
  21. Apr 9, 2019 at 2:56 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Hows the ride quality with nothing in the bed? Do you have the whole 4" set up in the rxt's?
  22. Apr 9, 2019 at 2:59 PM
    anthonygan
    2017 Cement TRD PRO
    Yeah I have the 4 inch setup with the rxt!! It’s not bad at all especially with weight in the bed before with like 300 pounds or so, I would almost bottom out, now with 1000+ It won’t even bottom out, but that’s thanks to the shocks as well!
  23. Apr 10, 2019 at 6:14 AM
    1BadTundra
    Clinton
    Too Much to List
    How is it with no weight in the bed? I'd like to get the full 4" lift out of it, but worried it'll be too harsh of a ride.
  24. Apr 10, 2019 at 7:50 AM
    anthonygan
    2017 Cement TRD PRO
    It rides great actually not harsh at all!! Do you have adjustable shocks in the rear?
  25. Apr 10, 2019 at 9:31 AM
    1BadTundra
    Clinton
    Too Much to List
    I have 5100's, but switching out once these are installed...
  26. Apr 10, 2019 at 9:33 AM
    anthonygan
    2017 Cement TRD PRO
    Ahh okay yeah, I like have adjustable shocks becuase daily I can run they soft feels great and plush, but towing I run them firm
  27. Apr 10, 2019 at 9:38 AM
    1BadTundra
    Clinton
    Too Much to List
    Nice... I'll have to invest in these... Its all going together in 2 weeks. Still gathering parts. You have all the leafs in the pack for the full 4", correct?
  28. Apr 10, 2019 at 9:40 AM
    anthonygan
    2017 Cement TRD PRO
    ya correct I used all the leafs!
  29. Apr 10, 2019 at 9:48 AM
    1BadTundra
    Clinton
    Too Much to List
    Awesome... Thanks for all the info!
    anthonygan likes this.
  30. Apr 10, 2019 at 12:58 PM
    1BadTundra
    Clinton
    Too Much to List
    So I put my leaf pack together like it states, but this is how it looks. The additional leaf is to be placed between 2 and 3, but its shorter than 3. Is this correct?
