Cavalry Blue Owners
Discussion in '2.5 Gen Tundras (2014-2021)' started by 808Kaap, Jan 2, 2020.
  1. Apr 18, 2020 at 1:54 PM
    #211
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Killing me. I’m trying not to spend my coronacash on this. Looks great!
  2. Apr 18, 2020 at 1:56 PM
    #212
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Thanks! It definitely helped me out lol
    now I just need to decide on what to do with the bumper caps...
  3. Apr 18, 2020 at 2:14 PM
    #213
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    What light bar and brackets did you use?
    ElNopal likes this.
  4. Apr 18, 2020 at 2:28 PM
    #214
    paradizecityz
    Richmond, TX
    which lights are you asking about? My light bar? Caliraised brackets and Auxbeam light bar
    ElNopal and aussieaarons[QUOTED] like this.
  5. Apr 18, 2020 at 2:40 PM
    #215
    Buster1
    Buster1 New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    Powder coated wheels. Slowly working on the blackout. Badges are next.
    ElNopal, GODZILLA and paradizecityz like this.
  6. Apr 18, 2020 at 2:49 PM
    #216
    paradizecityz
    Richmond, TX
    Badges are quick and easy with plastidip :)
  7. Apr 19, 2020 at 8:57 AM
    #217
    paradizecityz
    Richmond, TX
    heres the new angle. You can see where the Toyota grill emblem is
    surprisingly pretty centered...
    ElNopal[QUOTED] likes this.
  8. Apr 19, 2020 at 9:31 AM
    #218
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    That does look great.
    Do you think you will leave it as is? If not, another suggestion might be to make a template out of cardboard and then fab a new plate out of thinner gauge sheet aluminum/metal and use that with same concept of a larger washer behind the plate for a compression type fit.
    Just a thought in case you wanted to move it back to the bottom.
    paradizecityz[QUOTED] likes this.
  9. Apr 19, 2020 at 10:23 AM
    #219
    paradizecityz
    Richmond, TX
    now that I see that it’s pretty centered on screen, I might.
    I didn’t want to put too much work into it. Plus I think the raptor lights are gonna go soon? I saw 2 out of the 3 have lost the protective front cover so when they go, I might pull the whole assembly and then put the camera centered
  10. Apr 19, 2020 at 11:45 AM
    #220
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    That is a bummer to hear about the grille lights. I think you can get replacement lights for them so you do not have to scrap them entirely because I think they look neat.
    Maybe the ones I used from superbrightleds can be an easy and cost effective alternative.
    I was going to go the plate fit on each honeycomb route that I suggested earlier. However, every stinking opening was different and I got unenthused quickly. Instead, I used some light, rigid aluminum angle iron.
    I painted them black and installed them with the 3M exterior/auto grade double sided tape similar to the kind used on the badges.
    I ran the wiring inside a loom with a connector that runs along upper part of the grille, again using double sided tape. It has been super solid thus far through snow, cold, and plenty of bucket washes.
    I was about $32 into the project and feel it was a very easy, satisfying mod. If one or more go out I can easily pop in a replacement. At $2.95 per LED, I bought up a whole other set of five to have on hand as replacements.
    Instead of five, like I have, do four and leave your camera in the middle.
    Here is sneak peek of what I have been working on... These lights were lost in the mail for over a month! They just showed up yesterday!
  11. Apr 19, 2020 at 12:28 PM
    #221
    paradizecityz
    Richmond, TX
    Nice! I go back and forth on wanting them or not. I do like them and then sometimes I'm like, it's a ford thing, not toyota lol
    I made my own kit and bought some lights on Amazon for like $20 before when I had the tacoma. Seems like it's the same or very similar lights as what I have now. I would of done it myself but wanted a plug and play kit, paid too much for it, and ended up re-doing the wiring as I ended wiring it to a switch lol
    I think what I might end up doing is when it goes out, remove them and wiring in a different set in the hood bulge instead
    Not this one but something similar to below:
  12. Apr 19, 2020 at 12:54 PM
    #222
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I get that.
    Speaking on the subject, with my father, a trucker (therefore, a lights and more lights enthusiast), he is quick to remind me (and others) that DOT/clearance lights have been “a thing” well before 2010 when Ford decided to call them “raptor lights”. He has always installed some sort of light(s) in/on all of his vehicles since the 60’s. His 2000 Tundra had three in the grille for awhile but then dropped off one for balance...
    Long, short, your ride will be fabulous with them or not because it is your preference that matters!
    Also, like the hood bulge light route you are also suggesting!
    Cheers and great day!
  13. Apr 23, 2020 at 2:35 PM
    #223
    dbush
    dbush What would Waylon Jennings Do?
    Dustin
    2020 Cavalry TRD Sport CM
    Picked this up today. Left behind my 2010 DC, but it was worth it. Ive been looking for this truck for a while. Found it about 4 hours away and my local dealer made it happen! The plan was to put some miles on these brand new tires before i swapped, but i dont think its gonna happen.
  14. Apr 23, 2020 at 3:47 PM
    #224
    dbush
    Dustin
    my internet went out right when i tried to upload, woops
  15. Apr 23, 2020 at 10:59 PM
    #225
    Chip_Tundra
    Chip_Tundra New Member
    Ironic that I'm a giants fan, have the blue truck and the owner of the white truck is a dodger fan. Lol
    georgiey22 and Y0TA PR0 like this.
  16. Apr 28, 2020 at 2:36 PM
    #226
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Well I missed out on the sport grill surround....apparently they are discontinued and will have to buy a new damn badge for the front.....when they come out with the new surround....
  17. Apr 28, 2020 at 2:51 PM
    #227
    aussieaarons
    I installed some EZFlares to protect the under side of the flares. Came out alright I think, once again the blue pops with black
  18. Apr 28, 2020 at 7:58 PM
    #228
    paradizecityz
    Richmond, TX
    Haven't heard of this one...can I see a further away picture?
    GODZILLA likes this.
  19. Apr 28, 2020 at 8:10 PM
    #229
    aussieaarons
  20. Apr 28, 2020 at 8:14 PM
    #230
    paradizecityz
    Richmond, TX
    Oh wow, I like the contrast!
    aussieaarons likes this.
  21. May 4, 2020 at 4:40 PM
    #231
    paradizecityz
    Richmond, TX
    welcome! :)
  22. May 4, 2020 at 7:07 PM
    #232
    dbush
    Dustin
    Welcome to the club. I've found you really will get a lot of compliments on the color. The people at my local dealership had never had this color on the lot. I picked it up a couple weeks ago and there were constantly people commenting on it.
  23. May 4, 2020 at 7:51 PM
    #233
    Skip_TRD_Sport
    Skip_TRD_Sport Less is More.
    2019 Cavalry Blue TRD Sport
    Westin Pro Traxx 4 Step Bars, Bed Mat, Color Matched Door Handles
    Do any of our Cavalry Blue owners have color matched door handles? I'm looking for the part number for paintable door handles.
  24. May 6, 2020 at 12:41 PM
    #234
    dbush
    Dustin
    Got the xd's put back in. Forgot how much dirt they throw around.
    EN2TUNDRA, ElNopal, a_double and 2 others like this.
  25. May 6, 2020 at 2:30 PM
    #235
    Lunercrab
    Lunercrab New Member
    So I might be pulling the trigger on a 2020 sport in Calvary blue. Tho I love the blue there's so much of it lol. So I'd like to do a like matte black hood decal. But I'd like one that goes on and around the hood scoop and I can for the life of me find one. Something similar to like the taco pro hood decal. Any suggestions?
    paradizecityz likes this.
  26. May 6, 2020 at 3:29 PM
    #236
    dbush
    Dustin
    I haven't found anything for the hood like the taco has but I have been looking at the black center of the bumper to break it up a bit. I will say in real life the blue isnt as overwhelming as it looks in pics.
    GODZILLA and Lunercrab like this.
  27. May 6, 2020 at 6:06 PM
    #237
    18" TRD Off Road Wheels
    That was what made me not look at the sport. That and the scoop. Don't look at the truck as it sits now, look at what you will do with it. If you are going to put an aftermarket bumper on it (Lots of great options) then that will take care of the blue overload. As far as a hood decal, you can vinyl anything you want if you have the time and patience. Just ask @Jim LE 1301 cuz he did his scoop in black. Not a Cavalry Blue, but he can point you in the right direction.
    This is a great idea. There are some slim winch bumpers that would do the same thing, if you need a winch. Southern Style Off-road has one, I think, along with Victory4x4.
    ElNopal and dbush[QUOTED] like this.
  28. May 6, 2020 at 7:11 PM
    #238
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    looks so good man, mind me asking what is cost you to do that?
  29. May 6, 2020 at 7:20 PM
    #239
    Just unbolt it and wrap it, that's what I did.
    20200311_203647.jpg 20200311_203652.jpg 20200314_112432.jpg 20200314_114911.jpg 20200314_114931.jpg 20200314_114924.jpg
  30. May 6, 2020 at 7:42 PM
    #240
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Thanks Dane, I appreciate it!
    No worries, $30 total out the door for the powder coating. They are a fairly close match to the TRD rear sway bar and the exact same color of my calipers.
    Jsnake89[QUOTED] likes this.
