Caught between cat thefts and a hard place
Discussion in 'General Tundra Discussion' started by doggiecareman, Jul 8, 2022.
  1. Jul 13, 2022 at 10:16 AM
    doggiecareman[OP] likes this.
  2. Jul 13, 2022 at 10:29 AM
    Solv3nt
    Solv3nt New Member
    Oregon
    2021 SR5 Off-Road 4x4
    Driver side grab handle, Genuine Cooling System Transmission cooler package, Max Modular Bed Rack, White Knuckle Off-road sliders, undercover ultra flex tonneau cover
  3. Jul 13, 2022 at 10:53 AM
    What have you been seeing for temperatures? They should be pretty low.
  4. Jul 13, 2022 at 10:56 AM
    Solv3nt
    Solv3nt New Member
    Oregon
    With Nick's cooler installed, I've yet to go over 195F. The ambient hasn't been the highest this year in Oregon, but I've towed in 85-90F.
  5. Jul 13, 2022 at 10:57 AM
    Thats pretty good. I would be happy with those results.
  6. Jul 13, 2022 at 11:27 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    4,000 pounds with ambient temp of 91°, max trans temp was 202°, trip was @ 200 miles T/H in D, S mode in 4 for long pulls uphill.
  7. Jul 13, 2022 at 2:13 PM
    Retired...finally
    Does cruise control have any affect in regards to shift points and trans temps when in T/H? Read something in the forum that gave me the impression using cruise negated any positive effects of T/H.:confused:
    I can't find the post. So many threads, so little short term memory. :annoyed:
    Not only can I not remember things I'm lazy and use cruise when conditions permit.
  8. Jul 13, 2022 at 2:29 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    The cat protection plates trapping heat was a concern of mine. I haven't towed since installing. I'm wondering if this contributed to OP's event.
  9. Jul 13, 2022 at 2:39 PM
    Retired...finally
  10. Jul 14, 2022 at 12:51 PM
    doggiecareman
    doggiecareman [OP] YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I had that appointment on Tuesday so yes it was yesterday from the time of this post you made.
    Okay here’s a list of what I learned and what I’ll be doing.
    I made the mistake of trying to haul in D some of the time and got considerably better gas mileage but it was because the transmission was working way too hard. I had them take the plates off and grab a sample of the transmission fluid and they said it was fine and they showed it to me. Normal color and no burnt smell. Also they did not even make mention of the plates being there contributing to overheating it and were impressed with the plates. @Classy63 I’ve been going to this dealership for 15 years and the lead tech supervisor I’ve known for quite a few years and he has the same rig. He conceded that the manual as has been discussed here on this thread is vague and less than optimal to say the least. Though they normally don’t install transmission coolers they’re going to go ahead and put together a set up for me so that it will be dealer installed. They cannot use the original ones for pre-19 after he looked into it so they’re going to research and put together a price for me on other components instead. If it’s not sticker shock I’ll do it, and I’ll keep you guys posted. Even though I have a 10 year 125K #Warranty I believe putting in the transmission cooler is a wise investment.
  11. Jul 14, 2022 at 1:36 PM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    This is a dumb problem that Toyota made… I am glad to hear they are adding a transmission cooler to fix this.
    I would have been VERY surprised if it was heat build up due to the plates
  12. Jul 14, 2022 at 2:31 PM
    Retired...finally
    Although I don't have the cat plates I can add that ambient temps don't change my trans temps much at all. Between 35 - 95*f I'm not seeing a difference.
  13. Jul 14, 2022 at 3:06 PM
    Melikeymy beer
    Muscogee Nation
    Did the Service Advisor tell you this or are you speculating? It's an ongoing debate here is why I ask.
  14. Jul 14, 2022 at 3:46 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    I tow(very rarely) in s5. When using d, she will shift into 6th and then slowly decelerate from air drag and then downshift to 5th, so it's pointless to tow in d. (Speed around 60. 4000lb)
    Towing in s4 is actually quite exciting because of all that ample power. I bet 5.7 is even faster. It's probably best to just tow in 5 and click into 4 when needed. You probably don't need all that torque going on flat terrain constant speed.
    Mines a smol v8(4.6) from 2010
  15. Jul 14, 2022 at 6:57 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    I haven’t noticed any issues. 2016 crewmax, towing in 100+F heat and mostly flat with some rolling hills, most of the time in S4 with a little time in S5 and temps stayed around 205-215 when I kept the converter locked up(90+% of the time).
    Long uphills see maybe 235-240 if the converter isn’t locked up; I just downshift to S4 or S3 typically anyway to keep that from happening.
    I have the full Valhalla kit including front skid, and tow a ~7,000lb travel trailer. Temperatures are checked with OBD Fusion when towing; these trucks are far happier revving under load than lugging along at low rpm’s.
  16. Jul 14, 2022 at 8:56 PM
    Solv3nt
    Solv3nt New Member
    Oregon
    With a cooler or stock?
  17. Jul 14, 2022 at 8:58 PM
    Melikeymy beer
    Muscogee Nation
    He has a 2016 so it will have a cooler.
  18. Jul 14, 2022 at 8:59 PM
    Solv3nt
    Solv3nt New Member
    Oregon
    His profile says 2019, does he have two?
  19. Jul 14, 2022 at 9:01 PM
    #49
    Melikeymy beer
    Muscogee Nation
    Sorry, my bad. I was looking at another post.
  20. Jul 14, 2022 at 9:04 PM
    #50
    Solv3nt
    Solv3nt New Member
    Oregon
    I just saw his earlier post on page one, he's got a cooler.
  21. Jul 14, 2022 at 9:08 PM
    #51
    Melikeymy beer
    Muscogee Nation
    Right, so still curious if the cat plates will cause overheating w/o the auxiliary cooler like OP.
  22. Jul 15, 2022 at 3:09 AM
    #52
    Bammer
    Monroe, CT
    Yes correct, have the cooler. Have the plates too, have a lot of other things because of this site. All for the good except my bank account ! :rolleyes::D
    ColoradoTJ and Solv3nt[QUOTED] like this.
  23. Jul 15, 2022 at 6:46 AM
    #53
    Solv3nt
    Solv3nt New Member
    Oregon
    I just ordered some tow mirrors because if this stupid site :ballchain:
  24. Jul 15, 2022 at 6:53 AM
    #54
    Bammer
    Monroe, CT
    Let the games begin !
    Get ready sir for a lot of:spending:
  25. Jul 15, 2022 at 7:28 AM
    #55
    Solv3nt
    Solv3nt New Member
    Oregon
    If only that were the only thing... KB Voodoo bed rack, White Knuckle Rock sliders, Tranny cooler, driver side grab handle.
    Bammer[QUOTED] likes this.
  26. Jul 15, 2022 at 9:04 AM
    #56
    Retired...finally
    Off to a good start. Travel trailer TPMS and a rear camera/monitor system are also a must. The anytime backup camera mod is important to see if the trailer is still there. (JK) It is very handy to watch as you're going forward to see how close the truck comes to the trailer while making tight turns. One drawback of the Tundra's tight turning radius is it can get very close.
    bulldog93 likes this.
  27. Jul 15, 2022 at 9:21 AM
    #57
    Solv3nt
    Solv3nt New Member
    Oregon
    I just upgraded the original tires to Goodyear Endurance with Steel stems. The plan is for a TPMS system, but I'm not as concerned now that I upgraded the tires to something that isn't prone to blowing up.
  28. Jul 15, 2022 at 12:27 PM
    #58
    Bammer
    Monroe, CT
    I did the grab handle, great upgrade !
  29. Jul 15, 2022 at 2:47 PM
    #59
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Do the cooler install mentioned in multiple threads.
  30. Jul 15, 2022 at 2:59 PM
    #60
    doggiecareman
    Eric
    North Central CT
    We talked at length about it and he did confirm that you’re able to tow but definitely at the expense of the mileage. He said if you want to tow with the tundra you just accept the fact that it’s 8 to 10 miles a gallon with any significant load. Otherwise it’s just too hard on the transmission like is being discussed.
