Catalytic converter protection installed
Discussion in '2.5 Gen Tundras (2014-2021)' started by DanSanDiego, Jun 15, 2022.
  1. Jun 16, 2022 at 3:00 PM
    BayRunner
    2017 Tundra Platinum
    Yes indeed. If they want the cats bad enough, they are going to get them. However all these security precautions are going to make them really work for it.
    WBW likes this.
  2. Jun 16, 2022 at 3:25 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    They could hit like 10 Priui in the time it would take to get my cats....
  3. Jun 16, 2022 at 3:47 PM
    DanSanDiego
    DanSanDiego [OP] New Member
    2019 Tundra Limited 4x4
    Millercat has an extension to cover the rear cats, but they are not yet back in stock. This covers the front half of the rear cats though.
    Tundra234[QUOTED] likes this.
  4. Jun 16, 2022 at 3:50 PM
    DanSanDiego
    The guys cutting these things off generally aren’t the sharpest tools in the shed. They will just move on to an easier target. I have seen that most thefts occur in parking lots where they can get in out out really quickly. They don’t want to spend more then a few minutes.
  5. Jun 16, 2022 at 5:55 PM
    trj
    trj New Member
    Tom
    2020 Tundra SR5 TSS Quicksand
    Makes sense. I was concerned if I a cat shield is installed, would they just remove the shield (with a correct drill hex head) and be as quick at removing the shield as one could be taking off a tire with a impact wrench, but as you mentioned, sounds like they would see the shield, and then, funk-dat, move on to the next. Thanks!
  6. Jun 22, 2022 at 4:11 PM
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    Thos is meant to be a visual deterrent more than an actual, I can't take it off, I agree that is they look at the undercarriage and see that it going to take more time that someone else's, they will move on. particularly in a public parking place. Thie cost me less than $50 to make
  7. Jun 25, 2022 at 5:37 PM
    Mfanatic22
    Mfanatic22 New Member
    2019 CM White SR5 Sport 4x4
    Thanks for great idea! I got the front millercat plate and just ordered the rear panels. Will fill them up with superglue!
