Cast Iron Cooking
Discussion in 'Food Talk' started by ColoradoTJ, Oct 11, 2020.
  1. Jan 7, 2021 at 10:52 PM
    #241
    ColoradoTJ [OP] Certified tow LEO Staff Member
    Round 1 done.
    BravoDeltaRomeo and Hbjeff like this.
  2. Jan 7, 2021 at 11:15 PM
    #242
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Nice Chris! After sanding my 10 inch, it was yellowish after 3 oven seasons even. So i gave it two seasoning rounds on the Weber Kettle....oh man its got beautiful color now!
  3. Jan 7, 2021 at 11:22 PM
    #243
    I will purchase some grape seed oil like @Kanobi13 suggested. Looks like the best way to season.
    Thanks @Sunnier for the link!
    Sunnier likes this.
  4. Jan 8, 2021 at 12:49 AM
    #244
    Round 2 completed. Going for 1 more tonight.
    Hbjeff likes this.
  5. Jan 8, 2021 at 3:42 AM
    #245
    Final seasoning tonight.
    May have to test this out on some eggs.
  6. Jan 8, 2021 at 6:15 AM
    #246
    Tested...works very well.
    Panther waiting patiently for his cut.
    C788CE14-A710-4DF0-8C14-BA63416A89F0.jpg CA302403-5F1E-4E16-BCE2-7ECE382706B2.jpg
    MS22, Blueknights75, JMB and 4 others like this.
  7. Jan 8, 2021 at 7:22 AM
    #247
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    2nd overnight season in the kettle done E81C4AD0-325F-4906-836C-DB9EBAA6CEB9.jpg
  8. Jan 8, 2021 at 12:19 PM
    #248
    We can’t wait until you use the pan. Looking great.
  9. Jan 8, 2021 at 12:41 PM
    #249
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Just did bacon in them! I got super worried, pan was a little too hot, bacon it it and stuck! But i did a light scrape after a minute with plastic spatula, gave it all a good stir and they have no more sticking! I think it’s looking good
    ColoradoTJ[OP] likes this.
  10. Jan 8, 2021 at 12:43 PM
    #250
    Kanobi13
    Kanobi13 New Member
    Lol try lower heat then turn it up should be all good
  11. Jan 8, 2021 at 12:54 PM
    #251
    Kanobi13
    Kanobi13 New Member
  12. Jan 8, 2021 at 12:55 PM
    #252
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes yes! I lowered it and did a good stir. I think i used to let my pans get too hot before dumping eggs in them. At least my first experiment after a long seasoning process has zero stuck on bacon chips!
  13. Jan 8, 2021 at 1:08 PM
    #253
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Get yourself a good stainless steel spatula, something with a nice straight edge. Plastic spatulas are for non-stick pans.
    rockmup likes this.
  14. Jan 8, 2021 at 1:09 PM
    #254
    Kanobi13
    Kanobi13 New Member
    My cast iron are non stick pans lol
    Sunnier and Hbjeff like this.
  15. Jan 8, 2021 at 1:10 PM
    #255
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    True. I meant coated pans.
  16. Jan 8, 2021 at 1:46 PM
    #256
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    everything im reading says wood/silicone only for cast iron. Stainless will scrape seasoning off the bottom? I used to use stainless until i read this
  17. Jan 8, 2021 at 1:51 PM
    #257
    Kanobi13
    Kanobi13 New Member
    I have never had this my experience with metal spatulas and cleaning products have never stripped my seasoning
    rockmup and Hbjeff[QUOTED] like this.
  18. Jan 8, 2021 at 2:16 PM
    #258
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    Agreed. The seasoning isn’t that delicate. I only use a carbon steel spatula, and have no issues. I also clean my pans with soap every time I use them, and chain mail when stuff gets stuck on. No issues.
    rockmup and Hbjeff like this.
  19. Jan 8, 2021 at 2:20 PM
    #259
    I use metal spatulas. No issues
    Hbjeff likes this.
  20. Jan 8, 2021 at 5:24 PM
    #260
  21. Jan 11, 2021 at 4:51 PM
    #261
    With everything, sometimes one wins and other times we have fails.
    This is a story of fail.
    Time for some grape seed oil seasoning.
  22. Jan 11, 2021 at 5:11 PM
    #262
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This was my pan after 5 eggs this morning 83C04ADA-B38D-4A56-8C39-936359EF9263.jpg
    finally a non stick result!
  23. Jan 11, 2021 at 5:39 PM
    #263
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    What's the thoughts on stripping cast iron using the self clean setting of the oven? I have several pieces that need to be completely stripped and reseasoned.
  24. Jan 11, 2021 at 7:21 PM
    #264
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    Sounds like a good way to stank up your house. Never done it myself, I use a homemade electrolysis tank. Pretty simple to setup, and very effective.
  25. Jan 11, 2021 at 7:42 PM
    #265
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How bad is it? I considered it, but since i wanted to polish anyways i just used a wire brush, then polishing disk, then sander
    lc69hunter likes this.
  26. Jan 11, 2021 at 7:57 PM
    #266
    lc69hunter
    lc69hunter New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    Lard, Crisco, or bacon grease are preferable to any kind of oil for seasoning or re-seasoning. Oil can become rancid. I have a complete set of skillets I keep in the oven when not in use, and yes, they are the original and ultimate non-stick, if taken care of properly.
    MS22, Hbjeff and Cpl_Punishment like this.
  27. Jan 13, 2021 at 7:04 PM
    #267
    Kanobi13
    Kanobi13 New Member
    Rube207 and JMB like this.
  28. Jan 14, 2021 at 6:05 PM
    #268
    12” Finex pan
    Home Depot online (of all places) for 240.00 with lid. Most other places after shipping and tax, over 300.00.
    These pans are HEAVY!
    BD0A8110-657D-49F9-8E37-0F3116A3879C.jpg A1D75882-A240-412F-9E18-5B1377DCD40F.jpg 7F4123B1-D338-4205-8107-4DED569AB29C.jpg A870D803-AEBB-45B3-81F6-1F2A64A02255.jpg C288540E-3AA8-4A9F-94DC-0DF448CE2F46.jpg
  29. Jan 14, 2021 at 6:32 PM
    #269
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That is one smooth pan!
  30. Jan 14, 2021 at 6:43 PM
    #270
    It really is. This is my co-workers pan. We just put it in the oven at 400*F and do an additional seasoning along with my griddle that got messed up the other night.
