Cast Iron Cooking
Discussion in 'Food Talk' started by ColoradoTJ, Oct 11, 2020.
  1. Oct 11, 2020 at 8:23 PM
    Kanobi13
    Kanobi13 New Member
    First thing i do with all my new cast iron i make chicharrones gets nice and seasoned
  2. Oct 11, 2020 at 8:26 PM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    That works too. :D
    I use clarified butter for my stovetop popcorn. That and fine powdered salt. It turns out just like the movie theater.
  3. Oct 11, 2020 at 8:49 PM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    LML 3500HD
    I will have to check
    Great information on cleaning. I haven’t had an issue with Dawn either...with similar drying and seasoning process.
    Outbound[QUOTED] likes this.
  4. Oct 11, 2020 at 8:51 PM
    LML 3500HD
    Damn!!! All in.
  5. Oct 11, 2020 at 8:56 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Forget trucks. This forum makes me cook more stuff!
    i love cast iron. Mother in law bought me an 8 inch skillet 3 years ago. Best present ever! Ive made eggs in it 6 days a week since.
    then i bought a 12 inch skillet for bacon. This one has had maybe 50 lbs of bacon and sausage through it, yet it cannot hold a season worth a darn. I can’t figure it out
    I don’t use soap, but i am ordering a brush to use with hot water. Seems to work good on the youtube
  6. Oct 11, 2020 at 8:58 PM
    LML 3500HD
    I’ll give it a shot the next time we do a pizza. 425*...close enough right?:D
  7. Oct 11, 2020 at 9:07 PM
    LML 3500HD
    maybe try the oven methods? Mine were not fun to cook either.
  8. Oct 11, 2020 at 9:10 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive done the oven thing a few times with it. I wonder if i got it too hot when burning food when it was new?
    re read yours. I have tried the oven treatment at a lower temp. I should try 350.
    ColoradoTJ[OP] likes this.
  9. Oct 11, 2020 at 9:10 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    When you are seasoning, make sure to use very light coats. I wipe them with oil, then wipe them down with a dry towel so they are almost dry. Then cook in the oven. Light coats help it cure on better and you don’t get the gummy finish.
  10. Oct 11, 2020 at 9:29 PM
    dittothat
    dittothat New Member
    Nick
    SD
    2016 MGM Platinum
    Wallygator likes this.
  11. Oct 11, 2020 at 9:30 PM
    LML 3500HD
    Would you elaborate a little on the hard metals and what not? I worked in a steel mill and did welding on the side for a long time and never had any measurable “trace” of hard metal poisoning (blood tests).
    The Finex line of cast iron is top of the line...for sure. I’m just wondering if there are any studies or facts behind these claims. Looking to learn.
    Wallygator, Sundown5oh and Sunnier like this.
  12. Oct 11, 2020 at 9:32 PM
    LML 3500HD
    Great advise. I learned this the hard way with my 8” CI pan.
  13. Oct 11, 2020 at 9:34 PM
    LML 3500HD
    I had to look that one up. :thumbsup:
  14. Oct 11, 2020 at 9:50 PM
    Kanobi13
    Kanobi13 New Member
    Give it a try!!
  15. Oct 11, 2020 at 9:57 PM
    LML 3500HD
    I will.
    Amazing what I learn from all the members on this site.
    Rica25 and Hbjeff like this.
  16. Oct 11, 2020 at 10:00 PM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    I know I will be getting some cast iron skillets and a Dutch oven soon. For country fried steak and chicken specifically and the Dutch oven for all kinds of stuff.
    We currently have Salad master pots and pans. We are never getting rid of those things.
    Wallygator, Rica25 and ColoradoTJ[OP] like this.
  17. Oct 11, 2020 at 10:06 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    You got the right recipe for seasoning, but I do it on the BBQ instead of the oven due to the smoke.
    New cast iron in my opinion needs to be sanded down. It is too bumpy. I use a palm sander with 60 grit sand paper until it is smooth. Then spray it with cooking spray and wipe almost all of it off and put it in the bbq at 400 degrees or so until it stops smoking (20 mins to a half hour).
    The seasoning is there to protect it from rust and gives the oil a low-tension surface to spread out on. Seasoning is not needed unless you sand down your pan, they come pre-seasoned and as long as you keep using them don't ever have to season them again.
    Cleaning is done at the stove with a metal spatula, heat and a paper towel. Will bring it to the sink and rinse with water. Sometimes need water and heat, can drizzle water into a hot pan and will clean almost anything. Cast iron holds flavors well, and I do not like the flavor of soap. But soap will not hurt the finish at all. Also, do not oil the pan after cleaning, oil it again at next use (just gives a sticky mess if oil it). There will still be a thin layer of oil in it after you clean it. If you push your finger into your clean dry pan you will feel the oil.
    Quality metal spatula is key to making a good meal with cast iron.
    Cast iron excels in cooking anything in a thin layer of fat.
    betotundra, Wallygator, MS22 and 2 others like this.
  18. Oct 11, 2020 at 10:08 PM
    LML 3500HD
    Holy hell Pat. 3300.00 for the set of Salad master pots. Now I know where those delicious meals come from!
  19. Oct 11, 2020 at 10:11 PM
    #49
    LML 3500HD
    Great information and experience! Thank you.
    Rica25 likes this.
  20. Oct 11, 2020 at 10:16 PM
    #50
    Grumpy Uncle
    Pat
    CO
    Long story about my brother and stomach cancer. One of the Oncologists told us to stay away from non stick pans and a lot of other things. So after doing some research we went with salad master. And its made in the U.S.A.
  21. Oct 11, 2020 at 10:18 PM
    #51
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I cleaned up mine and in the oven.
    can’t wait to try a dutch oven, but first I’d really like to get a griddle for the grill
    Rica25, TelemarkTumalo, MS22 and 2 others like this.
  22. Oct 11, 2020 at 10:19 PM
    #52
    Grumpy Uncle
    Pat
    CO
    Thanks
  23. Oct 11, 2020 at 10:24 PM
    #53
    Coffee*8)
    Pennsylvania
    + Trans cooler
  24. Oct 11, 2020 at 10:26 PM
    #54
    LML 3500HD
    I know this is a painful topic, but would you do us a solid and maybe go into more detail about what the doctor said? If not, totally understand Pat. Maybe we can chat at our next get together.
  25. Oct 11, 2020 at 10:27 PM
    #55
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    My late grandmothers Wagners pretty much never leave my stove top. I took out her corn stick pan for the pic too. I also have an old Dutch oven lid that fits one of them from her kitchen. I believe one of the skillets belonged to her mother.4BFB36F8-4AC5-4859-AF28-0D151431CC72.jpg
    my more contemporary purchases are an even larger POS Calphalon that I will eventually replace, a nice Lodge Dutch Oven and a couple all purpose Lodge skillets: one in the travel trailer and one in the car camping bin.
  26. Oct 11, 2020 at 10:36 PM
    #56
    Grumpy Uncle
    Pat
    CO
    We can do it at the next get together.
  27. Oct 11, 2020 at 10:50 PM
    #57
    Kanobi13
    Kanobi13 New Member
    Have you tried to find older pans? The "bumpy" is how they cast the newer pans
  28. Oct 11, 2020 at 10:53 PM
    #58
    Kanobi13
    Kanobi13 New Member
    Sorry for the loss. also scored pans from my grandma a Griswald,Wanger and un marked dutch oven
    runCMD[QUOTED] likes this.
  29. Oct 12, 2020 at 12:04 AM
    #59
    Grumpy Uncle
    Pat
    CO
    The type of acid that is is used to make teflon ( I dont remember the name of it) has been linked to testicular and kidney cancer. Not linked to stomach cancer. It has been said to be a possible carcinogenic. My brothers cancer is believed to have been caused by a type of bacterial infection If I remember correctly, eating salty processed smoked meats has a lot to do with it. He was also Hispanic which put him in a higher percentage rate of developing the type of cancer that he had. Genetics also played a part as well.
    The doctor said to avoid cooking with non stick pans and to cook food with stainless steel and or cast iron. Cut back on processed foods, to included canned processed foods. Buy frozen vegetables instead or fresh. Especially foods with processed sugar. Use honey or raw unprocessed cane sugar instead. Somehow cancer fuels on the glucose in the blood. It doesnt make it grow faster. I hope I got that part right. Things like processed flour or things made from it like pasta.
    I am paraphrasing the hell out of a weeks worth of being fire hosed by all of this information.
    So after all of what we had experienced, we are eating better, we cut way the hell back on the quick easy to cook processed food. No way in hell am I giving up grilling and smoking my own meat. I just eat way less processed meat that is high in nitrates. Hotdogs, lunchmeat.
    I am not a doctor, I am a functional meat missle. So take what I say with a grain of salt. There are a lot of holes in there but, that was the gist of it.
  30. Oct 12, 2020 at 2:49 AM
    #60
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I have used cast iron for about 15 years now when it comes to skillets.
    I have 2 lodges, one I use for pizza and the other the 10 inch is my day to day use one.
    I season as I use it, I heat it up, add a little oil if needed, add food, cook, remove food, turn burner to high, take the pan to the sink, turn on hot water, scrub out with a sponge, add dawn dish soap from time to time to laugh at those who fear it, rinse off pan, place on burner let heat dry off pan, add a small splash of any cooking oil handy, rub all over the pan, wipe off any excess, turn off burner place pan on back of stove top to cool, food has rested at this point, then eat.
    I have once re seasoned in the oven, did not remove the pan from the oven, left in there to cool with the oven, then repeated.
    I like that I can from stovetop to oven if needed, can use any type of utensil I want and they get better with time.
    Mine are made by lodge, dont worry and fret about the not smooth as glass surface, just use it, all those bumps and ridges fill in over time and the surface becomes smooth and well seasoned.
