Cast Iron Cooking
Discussion in 'Food Talk' started by ColoradoTJ, Oct 11, 2020.
  1. May 12, 2021 at 9:09 PM
    #331
    Kanobi13
    Kanobi13 New Member
    Try aluminum and salt see how much it pulls off
    ColoradoTJ[OP] and Pudge[QUOTED] like this.
  2. May 14, 2021 at 9:41 AM
    #332
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
  3. May 14, 2021 at 9:52 AM
    #333
    Outbound
    Aaron
    Northern Alberta
    Try the salt as mentioned earlier. I'd also give one of those chainmail scrubbers a try. Worst case, you strip and re-season I guess.
    JLS in WA and Pudge[QUOTED] like this.
  4. May 27, 2021 at 4:19 PM
    #334
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Triple Cast Iron breakfast for supper.
    Finnish Pancakes with caramelized bananas and bacon crumble.
  5. May 27, 2021 at 5:37 PM
    #335
    Kanobi13
    Kanobi13 New Member
    Looks good!!
  6. May 28, 2021 at 9:50 PM
    #336
    CoCotton
    CoCotton New Member
    2015 Platinum
    Carnitas in a cast iron dutch oven. Delicious.
  7. Jun 23, 2021 at 11:25 AM
    #337
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    Anyone have any tips for a better pan fried steak? Currently my process is
    Remove steaks, let sit until close to room temp
    Heat up cast iron on high with canola oil
    S/p garlic powder and smoked paprika right before it goes on
    Butter/rosemary after first flip, baste
    I think my heat might be too high as I get a lot of grey between the outside and center. I've also tried salting as I take it out of the fridge and let it sit, but I don't get a great sear and yes I pat it with paper towel to remove the moisture.
    I've read maybe I'm on too high of heat? Seasoning timing? Let me know boys. Thanks
  8. Jun 23, 2021 at 11:35 AM
    #338
    ColoradoTJ [OP] Certified tow LEO Staff Member
    Try grape seed/flax oil.
    HARPER306[QUOTED] likes this.
  9. Jun 23, 2021 at 11:37 AM
    #339
    HARPER306
    SK, Canada
    I think my old lady might kill me if I come home with more oil but I'll give it a shot anyways. Any other tips? Ive read maybe I should start the pan on low, then medium, then med - high while adding oil for cooking to make sure it's nice and hot. Everytime I've done it, I just put it to 1 below max, throw the canola oil in at the start, and put the steak in when it just starts to smoke
  10. Jun 23, 2021 at 11:40 AM
    #340
    ArcticEd
    ArcticEd New Member
    Jacksonville
    '24 Plat Hybrid Crewmax 6.5 CSM
    Care to share recipe?
  11. Jun 23, 2021 at 11:40 AM
    #341
    I heat the pan up on medium and get it hot, then take it to desired temp. Having a higher temp oil will help reduce burning the oil.
    HARPER306 likes this.
  12. Jun 23, 2021 at 11:43 AM
    #342
    BravoDeltaRomeo
    Bruce
    MB Canada
    2 PANS, reverse sear
    Low and Slow until it's 10* off of what you want your internal temp. Flipping it often.
    While it's cooking, get another Cast Iron screaming hot and sear it 30sec on each side or until it's got the crust you want.
  13. Jun 23, 2021 at 11:44 AM
    #343
    HARPER306
    SK, Canada
    Ah I had thought canola was one of the ones on the upper scale of the smoke point. I'll give the grapeseed a shot.
    If I'm wanting to cook for others (terrifying thought), what would be involved for cleaning out the pan between finished steak/second steak? I'm assuming any added basting butter/rosemary/oil should be wiped out at the least and fresh oil added?
  14. Jun 23, 2021 at 11:47 AM
    #344
    HARPER306
    SK, Canada
    I have done the reverse sear a couple times and it did work out nicely, however, I am usually quite impatient and not very forward thinking. That results in me wanting the steak now and not an hour lol. Trying to get a better handle on the searing/crust before I dive into reverse searing and sous vide a bit more.
    I'm also pretty green when it comes to cast iron. I had a pan that I had a nice season on and then I left it on the stove with a burner on accidentally and the thing actually warped as well as scorched all the seasoning. I have a new pan now that's finally seasoned pretty nice so I'm getting back into it
  15. Jun 23, 2021 at 12:49 PM
    #345
    Kanobi13
    Kanobi13 New Member
  16. Jun 23, 2021 at 12:55 PM
    #346
    It sure is depending on what you have.
    Maybe all you need to do is turn down the heat a bit.
    BravoDeltaRomeo likes this.
  17. Jun 23, 2021 at 2:27 PM
    #347
    HARPER306
    SK, Canada
    I have a steak sitting out rn that I will be experimenting with the heat on. Will turn it down to med after searing each side
  18. Jun 23, 2021 at 2:59 PM
    #348
    HARPER306
    SK, Canada
    Well boys, warmed up the pan in the oven this time, then turned it down to med after first flip. Small sample size but maybe that's all I needed to change.. This one is quite good. Slight bit overcooked but awesome crust
  19. Jun 23, 2021 at 3:02 PM
    #349
    Well now I’m hungry. That looks great!
  20. Jun 23, 2021 at 3:22 PM
    #350
    Kanobi13
    Kanobi13 New Member
    Ata boy!!!! Honestly with cast iron its all about heat regulation
  21. Jun 23, 2021 at 3:39 PM
    #351
    HARPER306
    SK, Canada
    Haha thanks, yea still learning lots. I don't do a lot of cooking(thankfully my old lady loves to) but I like to eat so I figured I might as well start learning something. Plus she loves when I cook for her ;)
    Basically all I did different was pan in the oven at 400 for 25ish mins, then switch to med after first flip. I made a ribeye a couple weeks ago that was the best I'd made, this one dummied that one
    JMB and ColoradoTJ[OP] like this.
  22. Jun 29, 2021 at 4:55 PM
    #352
    CoCotton
    CoCotton New Member
    2015 Platinum
    I use a Big Green Egg, but any smoker will do. Perform your typical shoulder smoking ritual but kick the temperature up; no need to low and slow with carnitas IMO. Below is a screengrab of the spreadsheet I use to keep the recipe in. Add an extra jalapeno if you want more kick. I've also included some links from another forum I use as a go by.
    https://eggheadforum.com/discussion/1181812/mojo-smoked-pork-carnitas-tacos/p1
    https://eggheadforum.com/discussion/1171671/carnitas-or-something-like-that/p1
    https://eggheadforum.com/discussion/1213659/weekend-carnitas-pic-heavy-and-long
    ArcticEd[QUOTED] likes this.
  23. Jun 29, 2021 at 6:58 PM
    #353
    ArcticEd
    ArcticEd New Member
    Jacksonville
    Awesome - thank you for sharing & links. Love Carnitas
    CoCotton likes this.
  24. Jul 10, 2021 at 4:05 PM
    #354
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    Tomatoes finally coming in, about a week later than usual. BLTs tonight.
    Taco-Spike, Cpl_Punishment and TILLY like this.
  25. Jul 10, 2021 at 4:16 PM
    #355
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    What Cast Iron was meant for. No Ketchup on these fried eggs though, scrambled only. :)
  26. Jul 10, 2021 at 4:53 PM
    #356
    JMB
    Chesapeake, VA
    You are absolutely correct on the ketchup etiquette.
    TILLY[QUOTED] likes this.
  27. Jul 16, 2021 at 5:12 PM
    #357
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    On the pellet grill tonight; crab stuffed flounder, scallops and shrimp. Served with mashed potatoes and peas.
    MS22, DaBoro54, JMB and 2 others like this.
  28. Jul 17, 2021 at 4:52 PM
    #358
    JMB
    Chesapeake, VA
    Brats, will hit the grill for a few minutes later.
    Cpl_Punishment, TILLY and Hbjeff like this.
  29. Aug 21, 2021 at 11:32 AM
    #359
    BravoDeltaRomeo
    Bruce
    MB Canada
    I've wanted one of these for a few years now, but they were nowhere to be found.
    Amazon had a few in stock the other day, $150 cad, so I took a chance. I was expecting a notice saying not available etc, but it showed up.
    Lodge Sportsman Grill (made in USA :oldglory:)
  30. Aug 21, 2021 at 11:45 AM
    #360
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    While cooking on iron, I use a very stiff steel spatula to scrape any burned bits off. You can sling the result into the garbage or the sink, and wipe the pan out with some wadded paper towel if needed, this should only take seconds.
