Carrier Bearing...Sorry have to ask
Discussion in 'General Tundra Discussion' started by TXRailRoadBandit73, Oct 19, 2017.
  1. Oct 19, 2017 at 1:40 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Hello Ladies n Gents...sorry have to ask this again if i have before I am sorry...but was crawling under Tundy checking everything to see if ok.. I noticed that the center carrier bearing has no drop spacer to make my drive line straight... I spoke with Rough Country tech guy he said if ther no shaking I don't need it... this true???
  2. Oct 19, 2017 at 1:54 PM
    Nevermind got my info
    831Tun likes this.
  3. Oct 19, 2017 at 1:57 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    What was the answer?
  4. Oct 19, 2017 at 2:13 PM
    Not needed
  5. Oct 19, 2017 at 4:28 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    How was that determined?
    Am on a 6 inch lift like you, and After I installed my homemade spacers, the acel is smoother ( before it was like riding over the graded road shoulders).
    What makes your without different to mine?
    RC says they don’t include it into their lift kit as some tundras comes with a single drive shaft....
  6. Oct 19, 2017 at 4:36 PM
    Les7311
  7. Oct 19, 2017 at 4:48 PM
    I have a split drive shaft
  8. Oct 19, 2017 at 4:52 PM
    They said if ther no shakin it wasn't needed
  9. Oct 19, 2017 at 5:03 PM
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    When in have needed a carrier bearing drop was when I did the rear shackle. I developed a shudder. On this truck I did a block and didn't get a shudder, so if you have a shudder you need a drop kit if not then your golden.
  10. Oct 19, 2017 at 8:18 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    If you go over to tacomaworld there is a long article on how to check your driveline angles. It’s about more than the shudder. You can have premature wear on that joint as the rubber donut gets worn over time.
    -Jon
  11. Oct 19, 2017 at 8:33 PM
    I have no shudder at all it's all smooth...just slight angle right at carrier bearing ... Rough Country told me if no shudder i dont need it
  12. Oct 19, 2017 at 9:14 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
  13. Sep 26, 2018 at 9:05 PM
    Rica25
    Ricardo
    Tulare
  14. Sep 26, 2018 at 9:47 PM
    Post #6
    Rica25[QUOTED] likes this.
  15. Sep 27, 2018 at 6:13 AM
    Rica25
    Ricardo
    Tulare
    That shows it being done......I wanted to see a picture of what it look like if it needs to be done......what lift do you have? Aramirez73
  16. Sep 27, 2018 at 6:17 AM
    Rica25
    Ricardo
    Tulare
    I have a very minimal shudder at take off only I was going to do it more do to the angle of the shaft it does not seem right to me
  17. Sep 27, 2018 at 6:37 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I use this size spacer on a 6 inch lift in addition to a block, AAL, Shackles and airbags. Smooth as butter on takeoff.
    I did indeed have the takeoff shudder until I installed this spacer.IMG_20150612_130928.jpg
  18. Sep 27, 2018 at 6:39 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I have a 2-3 inch lift in the front, more like a leveling kit. I did a 1/4 spacer on mine just because.
  19. Sep 27, 2018 at 7:02 AM
    I bought my Tundra used, when I pulled servive records from dealer, they sent it to get lifted, it has a RC 6" lift, and I found out that the rear crossmember is not cut like the Instructions say to do, past year been debating to go with Fabtec 4" kit, IDK I've been looking at the PRO
  20. Sep 27, 2018 at 7:05 AM
    But here's the thing, ever since I've had mine, I feel no such shudder at all, I'm on a 6" lift, on 35's, 20x10 wheels, +20 believe, tires flush with fender flares
    jeremyd likes this.
  21. Sep 27, 2018 at 7:12 AM
    RC has a carrier bearing drop kit, that comes in flat rectangular pieces
  22. Jan 4, 2020 at 2:56 PM
    The Shaggy Fox
    The Shaggy Fox Astronaut Cat
    I just installed the RC one, although I think it's undersized for my lift. But the install was simple (had three shims per side) and quick.
    You can use from one to three of the shims, depending on your needs.
    Rica25 likes this.
  23. Jan 4, 2020 at 9:24 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    If it's not shaking you don't (need) it.
    Mine was not shaking but did it anyway.
    Rica25 likes this.
  24. Jan 5, 2020 at 1:24 PM
    The Shaggy Fox
    It's still getting a little shaky. Seems a bit better than it was, but still noticeable.
    Going to try a more dramatic drop.
    Should there be any angle remaining, or is it straight when it comes from the factory?
  25. Jan 5, 2020 at 8:26 PM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    When I lifted my truck with 1-1/2" shackles( I know, small lift but I like to understand how things work) I first calculated the factory angles as a reference. Then recalculated everything with the 1.5" lift to see what size carrier bearing spacer would give me the best angles.
    Followed these three rules on the Spicer page:
    Basic Rules:
    Rule 1: Universal joint operating angles at each end of a driveshaft should always be at least one-half degree
    Rule 2: Universal joint operating angles on each end of a driveshaft should always be equal within one degree of each other (one half degree for motor homes and shafts in front of transfer cases or auxiliary devices)
    Rule 3: For vibration-free performance, universal joint operating angles should not be larger than three degrees. If they are, make sure they do not exceed the maximum recommended angles.
    Everything needed to get your angles as close as possible to ideal is on this Spicer page. Great calculator and information. With a few calculations you can figure out what will work without a bunch of trial and error.
    Hopefully this will help someone.
    https://spicerparts.com/calculators/driveline-operating-angle-calculator
    Click on the i in the circle above the calculator to open up a bunch of info.
