Carrier bearing drop question
Discussion in 'General Tundra Discussion' started by Sumo91, Dec 16, 2021.
  1. Jan 17, 2022 at 8:21 AM
    2mchfun
    I run the BDS recoil bars, expensive but very solid product. No regrets.
  2. Jan 17, 2022 at 9:33 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I think 0.8 degree working angle on the TC is perfect, I wouldn't mess with it. You don't want u-joints exactly at 0 degrees because it will not lubricate the joints properly.
    The working angle on the diff is overclocked at 6 degrees vs 4 degrees at the CB. Should get a leaf spring shim between 1.5-2.5 degrees and put it on so that the thicker edge of the shim is facing the rear of the truck. This will increase the angle at the diff and bring your diff working angle down closer to 4 degrees - the 0 degree not lubricating the joints still applies here so you don't want them both exactly at 4 degrees. $.02
  3. Jan 17, 2022 at 12:10 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Cruzer likes this.
  4. Jan 17, 2022 at 12:31 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I wonder what the driveshaft RPM relates to in speed on our trucks :confused:
    Unfortunately, the bigger the lift the bigger the op angles. Would have to increase the angle at the TC - probably not going to get much out of that.
  5. Jan 17, 2022 at 12:57 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you divide the engine RPM by the trans ratio (then the t-case ratio, but that's 1:1) then you get the drive shaft RPM
  6. Jan 17, 2022 at 4:27 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Are new spring packs needed with these and if so, wouldn't they take care of the axle wrap issue? This truck wont be seeing any taxing environments.
    Since playing with the CB spacing is easy enough I'll probably try adjusting it a little more and recheck the angles. Wanted to avoid having to shim the leafs. Seems like as long as there's 0.5 deg working angle at tcase it should be good.
    Cruzer[QUOTED] likes this.
  7. Jan 17, 2022 at 4:35 PM
    2mchfun
    No, new springs are not required. I did replace mine with Dobinson's 5+2 HD packs because I haul heavy loads at times. Made sense for me to do it all one time for a long time.
  8. Jan 17, 2022 at 5:45 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Sounds like a plan!
