"CarPlay connection error"
Discussion in 'Audio & Video' started by Silver23, Apr 17, 2023.
  1. Apr 17, 2023 at 7:37 AM
    Silver23
    Silver23 [OP] New Member
    2023 Silver 1794 TRD
    Recently had the TRD lift installed and not sure if they performed any updates to the radio but I later noticed that my phone wasn't connected. I go through the connection procedure and I get the error for carplay connection (see photo). The pairing number on my phone and the screen is the same. It appears to connect but when I click "yes" for carplay, I get the error. I also noticed that I started getting warnings on the Toyota app saying the doors are unlocked and/or back passenger window is down. I've clicked "forget this device" several times to start over but nothing works.
  2. Apr 17, 2023 at 7:48 AM
    Silver23
    yes, I have restarted my phone. It's very annoying because when I start the connection procedure, it will show as connected on my phone (under bluetooth). But once I go through the prompts on the radio screen, it give the error when I choose carplay.
  3. Apr 17, 2023 at 10:45 AM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    Sometimes if you plug your phone into the jack to the right of the controls on the dash it will reconnect. Mine has done this as well. Also happens with car play in my wife's Subaru. Its a car play thing. Hers always connects when plugged in.
    What kind of lift did you get?
  4. Apr 17, 2023 at 6:05 PM
    Silver23
    This afternoon, I plugged my phone using the USB. While plugged, everything worked fine. When I unplug it, there's no connection. I'm stumped.
  5. Apr 18, 2023 at 8:18 AM
    troutback
    I have had similar issues. PIA when trying to make a phone call while driving. If I try to call using the steering wheel controls if often tells me to connect my phone. When I call from the phone it will connect. Once connected I am then able to use the steering wheel controls.
  6. May 3, 2023 at 1:43 PM
    Silver23
    Stopped by my dealer on Saturday; the tech on duty couldn't figure it out. We were able to connect the phone to the truck via bluetooth but during the pairing process, we had to select "no" when it asked if i want to use apple car play. If I select "yes", it won't connect at all. My dealership is about 80 miles away; guess I'll wait until my first dealership oil change to have them check it out
  7. May 3, 2023 at 8:31 PM
    Isma9el
    Isma9el New Member
    2023 Tundra Limited Trd off-road lunar rock
    Had a similar issue, solution is to turn off your phones wifi, select phone and hit connect. That should fix it. Not sure why but if your phone is connected to something else through wifi example maybe a dash cam or maybe just WiFi alone, it doesn’t cooperate with CarPlay.
  8. Sep 10, 2023 at 1:58 PM
    surfmc
    surfmc New Member
    2023 Tundra 1794 off-road
    Did you ever get this figured out/fixed? I’m having the same issue.
  9. Sep 10, 2023 at 7:23 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    I am not saying that's what you're experiencing but when I was having issues with CarPlay connection it was because my son's iPhone or iPad was connected to my personal hotspot. So the issue definitely lies with the phone WiFi.
    MikeP5257 likes this.
  10. Sep 11, 2023 at 7:51 AM
    surfmc
    surfmc New Member
    Great, thanks! Yeah, I just tried it with a different phone and it worked. Much better to have it on my phone side and not the truck.
  11. Sep 11, 2023 at 9:48 AM
    brutalitybob
    brutalitybob New Member
    Same issue here - any luck on what may fix it? Seems to be a service/connection issue even though i have it plugged in USB...
  12. Sep 11, 2023 at 12:19 PM
    surfmc
    surfmc New Member
    Here’s what I think I did, and I got it to work this morning. (I have 2 phones, so was trying originally to make one join CarPlay and one join just via Bluetooth and stay on wifi, and was messing with iPhone settings, causing the issue).
    1. I turned Auto-Join back ON on the “smartphone_connect…” wifi network.
    2. In iphone settings I went to CarPlay, clicked the tundra, and turned both settings ON “CarPlay” & “enhanced intervention.” (I had turned one off while messing with stuff).
    I think that was it. Hope that helps!
    wilfred and Talkin_Tundras like this.
  13. Sep 11, 2023 at 12:31 PM
    Tom
    Tom New Member
    My iPhone is connected and makes phone calls using the wifi. I never connected by Bluetooth. Hope that helps. If you talk a lot while driving connect using the usb to the right for uninterrupted connection.
  14. Sep 11, 2023 at 12:41 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    silly apple owners
  15. Sep 11, 2023 at 12:59 PM
    Platinum_Tundra
    Platinum_Tundra New Member
    2023 Platinum Tundra
    This fixed my issue. It's strange that wifi would cause a carplay issue.
    surfmc[QUOTED] likes this.
  16. Oct 28, 2023 at 2:09 AM
    Kingnaz
    Kingnaz New Member
    2023 Tundra TRD PRO cockpit red
    Man you just saved me a two hour drive to my dealer. Thank You!
  17. Jan 16, 2024 at 1:31 PM
    BlackThunder#187
    BlackThunder#187 New Member
    2022 Midnight SR5 4x4
    I have spent HOURS trying to figure out why I lost my wireless CarPlay. THIS was the solution!!! Thank you so much. I went to the dealer so much I think I’m banned. I could connect to any truck in their lot except my own! You need to send this to Toyota corporate, as I spent way to much time on the phone with them too trying to figure this out. Thanks again.
  18. Feb 2, 2024 at 6:22 AM
    MikeP5257
    MikeP5257 New Member
    2018 Tundra
    none
    Myself, I think it's a Apple iphone issue. Everytime I start having connection problems with my Tundra, I need to update my ios on my iphone. Once I update the ios, everything starts working okay, until the next update is needed. I think Apple has programmed bugs into their software, in order, to get users to update to the newest operating system. I'm seriously thinking of switching to Android.
  19. Mar 7, 2024 at 2:42 PM
    Talkin_Tundras
    Talkin_Tundras New Member
    ‘22 Tundra Limited
    Too early to say if this is a permanent fix, but it did seem to help just now. For anyone needing a little more info with #1, you have to log off CarPlay in order to find that WiFi network. Disable CarPlay, go to your phones WiFi selection and it will be there. Change the setting as described, then go back and turn back on CarPlay in the truck.
  20. Mar 7, 2024 at 2:55 PM
    Breathing Borla
    Northern Illinois
    there is also new software out, 2050
    ryanwgregg likes this.
  21. Mar 7, 2024 at 3:10 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Where did you see this?
  22. Mar 7, 2024 at 3:41 PM
    iforceAZ
    iforceAZ New Member
    I hear you. I just have a little more faith in Apple to protect my privacy than I do Google. Google's business model is to collect all my data and sell it.
    I know I shouldn't trust any of them. But like I said, I trust Apple a little more.
  23. Mar 30, 2024 at 5:05 PM
    wilfred
    wilfred New Member
    This worked for me! Thank you!
  24. Apr 14, 2024 at 12:36 PM
    22tundra_capstone
    22tundra_capstone New Member
    Helpful thread, thanks guys.
  25. Apr 24, 2024 at 11:37 AM
    jshipman874
    jshipman874 New Member
    Jeff
    2023 Tundra 4x4 Hybrid 1794
    I am having the same problem.
    My truck is on software version 2050.
    I did not have the problem, before the 2050 update.
    Sometimes CarPlay connects, sometimes it just says "CarPlay connection error.
    Very frustrating. :(
  26. Apr 25, 2024 at 6:16 PM
    muskytuck
    muskytuck New Member
    08 Crew Max
    I have a similar issue with carplay with my aftermarket hu. Sometimes when i start the truck it auto starts carplay and life is good. Others it connects to my hu via bluetooth but not carplay. In settings under general i go to carplay and them turn on and off, it also seems related to LTT from carplay, if those dont connect it correctly i then open Amazon music or waze from my phone and refresh the content by clicking on a new station, and then it usually works. Definitely a pain in the ass.
    On a side note, i recently purchased a fukin tuned throttle device and without realizing that it wont work with carplay as it is presently you cant connect bluetooth to carplay and the app that is needed for the throttle device to work at the same time. There was a mention above about connecting via wi fi but ive yet to be able to make that work in my truck. The company rep for FT told me they are currently working on an update that will allow and work with carplay but didnt know when that will happen.
    Hey android db, ive had both phones for years dont act like your os is some revelation without flaw. Maybe find something else thats actually worth noting to set yourself apart from everyone as superior, that is if your self worth is reliant on complete strangers and the type of phone they have.
