Carplay Audio sucks compared to bluetooth
Discussion in '2.5 Gen Tundras (2014-2021)' started by VTYOTER, Oct 6, 2021.
  1. Oct 6, 2021 at 6:46 AM
    VTYOTER
    VTYOTER [OP] Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Anyone know why the sound is noticeable worse when play music through carplay vs just playing it through bluetooth on the entune system? The bass and mids in Carplay is terrible? I love everything else about carplay, so it seems like I may be missing something..
  2. Oct 6, 2021 at 6:49 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I had to change the bass, mid, and treble for each source. Seems the head unit does not apply the changes across all sources. My CarPlay sounds better after I made the adjustments.
    War Machine likes this.
  3. Oct 6, 2021 at 6:55 AM
    VTYOTER
    VTYOTER [OP] Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    I think I tried that, but I'll try again. I also updated spotify this morning so we'll see if that helps.
  4. Oct 6, 2021 at 8:01 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Look into your Spotify settings too- make sure you’re not using low quality when streaming over cellular (using you have an unlimited plan)
    ToyoMafia and L_S_SHOE like this.
  5. Oct 6, 2021 at 8:11 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Not trying to totally hijack the thread, but am I the only one experiencing a 1-3 second lag when I take a Bluetooth call over the wireless carplay? I have upgraded the firmware and it does not seem to help much. It is better at times, but the problem makes it very difficult to carry a conversation.
  6. Oct 6, 2021 at 8:13 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    could be your phone. my phone does it sometimes. but my wife's newer phone is instant. we're both using Android.
  7. Oct 6, 2021 at 8:15 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks. I'm due for a new phone. I'll see how the new one acts when I get it.
  8. Oct 6, 2021 at 8:17 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I had this same problem until I realized I had to adjust all of the EQ Levels for each input. I upgraded my sound system, and the tech that installed it had fine tuned all of my EQs, but only on my Bluetooth, once I matched them it sounded fine.
    I've had that problem intermittently ever since I bought my truck, even on the newest iPhone - and this is with wired CarPlay.
  9. Oct 6, 2021 at 9:48 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Check your settings on you head unit. Each source has its own EQ settings.
    ToyoMafia likes this.
  10. Oct 6, 2021 at 9:59 AM
    VTYOTER
    VTYOTER [OP] Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    nailed it! Sounds so much better. I also adjusted the equalizer in Spotify to hit the bass a little harder.
    So one or a combination of these things helped:
    - Updated Spotify
    - Put quality on “very high” for WiFi and cellular
    - Changed the EQ in spotify settings, made it a little heavier in the bass
    - checked EQ setting in the head unit (though I think i accidentally did this the other day so I dont think this was the answer)
    Regardless the sound is 100% better than it was.
    Regarding phone calls, I have an 11 Pro, but no delay so far on the 2 calls I have taken.
    thanks team!
  11. Oct 6, 2021 at 12:05 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Apple=problem...my Android Auto is awesome
  12. Oct 6, 2021 at 12:10 PM
    VTYOTER
    VTYOTER [OP] Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    nope, not any more, just user error. Sounds amazing
    MTRock, RainMan_PNW and 50Shades like this.
  13. Oct 6, 2021 at 12:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Po-TAY-to / Po-TAH-to
    Used both...don't really give a shit which one is in my hands as long as it just works as a damn phone and internet device.
  14. Oct 6, 2021 at 1:00 PM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    No One asked you if you gave a shit cupcake!!
  15. Oct 6, 2021 at 1:17 PM
    VTYOTER
    VTYOTER [OP] Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    slow down cowboy.
  16. Oct 6, 2021 at 1:30 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My brother recently discovered that the sound quality on Spotify is much worse for metal than for other genres for some reason.
    RainMan_PNW likes this.
  17. Oct 6, 2021 at 1:44 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    I have the temporary Sirius access with the new vehicle, and it sounds much worse than the FM radio. Maybe I need to check the EQ on that.
    glowblue likes this.
  18. Oct 6, 2021 at 1:46 PM
    Dsptundra
    Austin TX Area
    I found the satellite radio horrible for sound quality no matter what I did. Sounded like it was coming from the bottom of a can.
    Kratos[QUOTED] likes this.
  19. Oct 6, 2021 at 1:53 PM
    VTYOTER
    VTYOTER [OP] Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    It sounds like it is coming from outer space! :rocket:
  20. Oct 6, 2021 at 4:28 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    And this helps the OP how, cupcake?
  21. Oct 6, 2021 at 4:28 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    i've had no problems whatsoever. mine is a 21, so maybe that makes a difference?
    jewsNbrews likes this.
  22. Oct 6, 2021 at 4:29 PM
    VTYOTER
    VTYOTER [OP] Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    Mine’s a 21 too but like I mentioned problem is solved!
  23. Oct 6, 2021 at 4:55 PM
  24. Oct 6, 2021 at 5:18 PM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
  25. Oct 6, 2021 at 7:07 PM
    Darth_cholo
    Darth_cholo New Member
    2019 no android auto/carplay crew dang it. Satellite radio quality sucks once you get used to higher quality streaming. Google music on "always high quality". Tried Tidal that has lossless but library and integration wasn't as good. CD's still the best.
  26. Oct 7, 2021 at 4:15 AM
    War Machine
    War Machine SSEM # 5 3MW
    Android is noticeably worse at helping with spelling, grammar, capitalization, and punctuation, and nobody asked about cupcakes. Shit or otherwise.
    Does Android have a social skills app?
  27. Oct 7, 2021 at 4:18 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    do y'all remember way back....when sirius and/or XM was un-compressed?
    it was nice....now it sux. way too compressed. I left many moons ago.
  28. Oct 7, 2021 at 4:26 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    correct me here...
    If you are plugged in and using carplay...you can modify the EQ settings on your iphone & it will matter. i use "late night"
    using bluetooth...it bypasses the headphone stuff and sends raw signal to the head unit.
  29. Oct 7, 2021 at 5:00 AM
    War Machine
    I only use wired. I haven’t checked since I got the 2021 Tundra with CarPlay (before or after I put the Tech12volts system in) so I don’t know if it overrides the current OEM headunit or the maestro.
    I know it overrode the settings on both the factory headunit and the aftermarket Kenwood one in my 2017.
  30. Oct 7, 2021 at 5:04 AM
    War Machine
    I’ve always found that a wired connection sounds way better than Bluetooth, no matter what phone or vehicle I have. My old iPod Classic always sounded better than my phone did also, so I used that for music until it finally gave up the ghost.
