Cargo Lights with Reverse Lights
Discussion in 'Lighting' started by astro-jason, May 24, 2018.
  1. May 24, 2018 at 3:48 AM
    astro-jason
    astro-jason [OP] New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    I was wondering if anyone has done this, Making it so the cargo lights come on with the reverse lights. Just thinking if the lights are up higher = better visibility. Lighting up the entire back of the truck and beyond with current reverse lights, without cutting the bumper for lights, I like the look of stock.
    -Jason
  2. Jun 6, 2018 at 8:50 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I've turned on my cargo lights to see if they help when backing up...they don't really add any usable light. And I upgraded to LED bulbs in the cargo lights which are very bright. Probably not worth the effort
    4x4_Angel, jewsNbrews and 831Tun like this.
  3. Jun 7, 2018 at 3:26 AM
    Same here.
  4. Jun 7, 2018 at 3:36 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Do you have a link for the product?
  5. Jul 24, 2018 at 7:36 AM
    krtrav
    krtrav New Member
    2016 Tundra SR5 TSS
    How long was the harness to run to the battery?
    I’ve got a 16 CM and want to run a harness to the battery with an aux switch in the cab.
