Cargo/courtesy light wire
Discussion in 'Lighting' started by 17Mica, Jan 3, 2019.
  1. Jan 3, 2019 at 4:33 AM
    17Mica
    17Mica [OP] New Member
    Trying to wire aftermarket RECON Big Rig Ice Lights, having difficulty locating the Courtesy or Cargo Light wire, also is this wire present on both sides of cab in the wiring harness under the threshold cover?
  2. Jan 3, 2019 at 5:12 AM
    War Machine
    War Machine SSEM # 5 3MW
  3. Jan 3, 2019 at 6:49 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Driver side kick plate. I think it's a skinny brown wire depending on what year you truck is.
  4. Jan 3, 2019 at 7:36 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Pudge likes this.
  5. Nov 20, 2020 at 7:07 PM
    andymckinnon
    andymckinnon New Member
    Andy
    2011 White Tundra SR5 double cab
    How do you wire it up with a relay? And what size of relay?
  6. Nov 21, 2020 at 8:38 AM
    andymckinnon
    Andy
    Thank you much! I am installing bed leds... but they are at about 9amp draw...so when I tapped into the cargo light... the lights wouldn't come on
  7. Nov 21, 2020 at 9:12 AM
    andymckinnon
    Andy
    So I'm thinking I still use your wiring through relay instructions and use the trigger wire from the cargo lamps rocker switch right? (If so which wire in the rocker switch?)
  8. Nov 21, 2020 at 1:21 PM
    andymckinnon
    Andy
    Maybe I got it wrong then??... the strip has 60 5730 SMD LEDs... which when i looked up said they draw .15 ampere each... is that 9amp? [60x.15=9amp]... but on that same table is says they power each is 0.5 w... wouldn't that mean 30 watts?
  9. Nov 21, 2020 at 4:28 PM
    andymckinnon
    Andy
    Yah, gonna use them all... was this amperage still too much for tapping into the cargo wire? Cuz it wouldn't come on
  10. Nov 22, 2020 at 8:34 AM
    andymckinnon
    Andy
    I did use t-taps and the cargo light never lost connection it was always working... I will try again with positaps... do I need to worry about the t-taps that are still on the wire since it never caused the cargo light to not work?
  11. Nov 22, 2020 at 9:55 AM
    andymckinnon
    Andy
    I used a multimeter to check and grounded the lights on an existing ground in the panel
  12. Jan 28, 2021 at 11:15 AM
    Born-Riding
    Born-Riding New Member
    Barrett
    2021 Tundra crewman TRD PRO
    I was thinking of setting mine up in a similar way. The two relay diagrams below should work correct? They are opposites but same outcome...... just use the cargo light wire as the trigger, correct?
  13. Jan 29, 2021 at 2:38 PM
    Born-Riding
    Barrett
    good point. thank you! unfortunately i think they have changed the wiring for the 2021 TRD Pro. its not either of the pink wires under the kick board, its not the blue(2018) like you stated in an earlier post, i can't find anything online about it so i guess i will start probing in the morning........
  14. Jan 29, 2021 at 2:41 PM
    Born-Riding
    Barrett
    also i found this, which was my first thought, but i found a post where you said not to tap at the switch, but i did not understand why? would you mind explaining if you have time. thanks
  15. Jan 30, 2021 at 9:53 AM
    Born-Riding
    Barrett
    update: the purple wire will not work as it is reversed
  16. Feb 1, 2021 at 9:10 AM
    Born-Riding
    Barrett
    2021 tundra Crewmax TRD PRO cargo trigger wire is 1 of the 2 pink small wires under drivers side rear scuff panel. CONFIRMED
    NewImprovedRon likes this.
  17. Apr 7, 2021 at 12:05 PM
    dooododoo
    dooododoo New Member
    MGM '17 CM OR
    Fortin EVO-ONE Remote Start iBoard Running Boards (Black 5") LED interior lights Line-X Bed Plasti-Dip Emblems
    I like the idea of tapping at the rear driver side. But my question is... where do you exactly route the wire from inside to the outside?
  18. Apr 7, 2021 at 12:44 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    There is an easy to access (from above) grommet under the carpet. The tank blocks the grommet from the bottom side but it's easy to feed down from the top to the frame rail.
    Pop the grommet out, prep your wire lengths and put it inside a loom, then feed it all from the inside of the truck out and put the grommet back in place.
  19. Apr 7, 2021 at 1:39 PM
    dooododoo
    MGM '17 CM OR
    Thanks! There's actually 2 of them. One bigger and one smaller one. I used the smaller one because it provided a better route to under the sill scuff plate.
