Cargo containment...??
Discussion in '2.5 Gen Tundras (2014-2021)' started by tgo, Oct 27, 2018.
  1. Aug 8, 2019 at 6:01 PM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    Should use USPS....
  2. Aug 8, 2019 at 6:31 PM
    biebs96
    PA
    This is what I have...
    2x4 hinged in the middle with locking pin for easy storage within the bed or floor of rear seat.
    Two harbor freight ammo boxes for tie down/rope/bungee/hitch storage
    Fits in both the front and rear slotted portions of the factory bedliner. 94F85743-F2FA-4413-AB2F-4BDA7244AE9E.jpg
  3. Aug 9, 2019 at 6:12 AM
    Corpus Christi, TX
    Postal Service has much more successful delivery percentages at a fraction of the cost versus private shippers...they deliver WAY more stuff than anyone else. Unfortunately accidents happen.
  4. Aug 9, 2019 at 6:16 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I’ve posted this before, it’s just a piece of black stained pressure treated lumber that fits in the side grooves, braced to a 4x4 for added stability that also sits in the floor groove.
    I already had most of it from scrap, this small can of Behr Weatherproofing was around $5, plenty leftover for touchups.
    19Tundra77 and Black Wolf like this.
  5. Aug 9, 2019 at 7:24 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    I'll respond again, I think you should make these and market them, hahaha. Can you post up your dimensions of each piece? I'm going to make one of these bad boys myself.
    Black Wolf likes this.
  6. Aug 9, 2019 at 7:32 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    I use the bed extender and some instacrates from costco. The crates tuck in perfectly on the side when not needed. I always carry tie-downs as well if I need to prevent things from sliding around.
  7. Aug 9, 2019 at 7:55 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Lol, it's ridiculously easy to make. I'm using a 2x8 so it'll come out without opening my DB lid. A 2x10 will cover more height. It's about 66" wide. The 4x4 is about 18" I think. Measure twice, cut once.
    Note the 4x4 is a touch lower than the board because it sits in the groove, put them in, draw a pencil mark, then brace them together with whatever you can find. I might have also used some wood glue and long deck screws I had laying around screwed in from the other side. The 4x4 prevents the long board from rattling back and forth because the side grooves are wider than the wood. I guess someone could add shims on either end or a wider plank instead but it would be trickier to get in/out and have to go in directly from the top.
    If it's new PT lumber, dry it out in the sun before applying stain.
    I really like that reverse extender idea except my breaker bar and small things would still slide through to the back.
