Cargo break light/ Right rear running lights not working
Discussion in '2nd Gen Tundras (2007-2013)' started by Gbanuelos, Feb 2, 2018.
  1. Feb 2, 2018 at 1:59 PM
    Gbanuelos
    Gbanuelos [OP] New Member
    2009 Tundra
    So I had my taillights replaced with new housings and LED lights recently. They have been working fine. I decided to switch out the rear cargo lights and 3rd brake light to LED’s as well.. well once I did that now my 3rd brake light and right rear running lights on the tail lights won’t work. The white cargo lights do work though.. Any suggestions?? It’s in an 09 Tundra
  2. Feb 2, 2018 at 2:24 PM
    TheBeast The Beach
    polarity issue ? try swapping them around.
  3. Feb 2, 2018 at 3:17 PM
    Gbanuelos
    2009 Tundra
    Switch what around?
  4. Feb 2, 2018 at 3:22 PM
    TheBeast The Beach
    LED polarity
  5. Feb 2, 2018 at 3:26 PM
    Gbanuelos
    2009 Tundra
    I’ll try that again.. I even put the old bulb in there but with the other two being LED’s...
    Would the 3rd brake light affect the running on lights on just one rear tailight?
  6. Feb 2, 2018 at 3:31 PM
    TheBeast The Beach
    it shouldn't. I did the same on mine. with vleds LED. if it's the wrong direction some of them won't light up.
  7. Feb 2, 2018 at 3:33 PM
    15whtrd
    15whtrd Mr. Blonde
    @TheBeast is telling you to take the bulb out and flip it around and reinstall
  8. Feb 2, 2018 at 3:49 PM
    Gbanuelos
    2009 Tundra
    Yea already done that..
  9. Feb 2, 2018 at 3:51 PM
    15whtrd
    15whtrd Mr. Blonde
    Check all the fuses in the engine compartment and on the driver side under the dash.
    Les7311 and Black Wolf like this.
  10. Feb 2, 2018 at 4:19 PM
    Gbanuelos
    2009 Tundra
    Did that too.. what’s weird is the brake lights work on the tail light and the white cargo lights work on the overhead tail light
  11. Feb 2, 2018 at 4:20 PM
    This^^^^^^
  12. Feb 2, 2018 at 4:23 PM
    Make sure the thin leads on the end of the bulb are aligned properly so they make contact with the receptacle...???
    15whtrd likes this.
  13. Feb 2, 2018 at 4:29 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Reverse everything
    Put back the stock light bulbs to rule out they work. Meaning... unplug the LED, stick back your regular bulbs in socket and test.
    On mine, the red connected wire on the led taillight ( have 4 wires on the LED lights) goes to the white wire on truck harness.....
    Hola
    nuclearlemon, 15whtrd and Black Wolf like this.
  14. Feb 2, 2018 at 4:31 PM
    Les7311
  15. Feb 2, 2018 at 5:39 PM
    15whtrd
    15whtrd Mr. Blonde
    Just to be sure. Did you use a fuse checker. I couldn’t think of the name. I have one that lights up and tells you if they are good or bad. You can also check continuity if you have a voltage meter. Sometimes just looking at them doesn’t do the trick. At least pull them out and check that way.
  16. Feb 5, 2018 at 3:25 PM
    Gbanuelos
    2009 Tundra
    So I switched everything around, checked the fuses (tail, stop and cargo) with a fuse checker and they are all good. Checked the voltage and it seems that the 3rd brake light isn’t getting any volts to it..
  17. Feb 5, 2018 at 5:33 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    is that with the leds still in, or with regular bulbs in all the brake lights?
    did you get cheap leds or can-bus compatible leds? my 2010 required can-bus compatible (although i think that may still be an issue)
  18. Feb 5, 2018 at 5:46 PM
    Gbanuelos
    2009 Tundra
    I put back the bulbs that were in there before replacing them with the LED’s... this issue I’m talking about is the 3rd brake light that’s in the middle of the cargo lights over the truck bed. As far as my right rear tail light everything works (hazards, turn signal, brake light) except for the running lights
