Cargo Bed Lights not working
Discussion in 'Lighting' started by mart1nezdaniel, Mar 16, 2020.
  1. Mar 16, 2020 at 4:38 PM
    mart1nezdaniel
    mart1nezdaniel [OP] AZ
    Arizona
    Tundra TRD PRO 2017
    My Cargo bed lights are not turning on? Any thoughts on what to check? These came dealer-installed.
  2. Mar 16, 2020 at 4:48 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    maybe your cargo light switch is oFF?
    Squatting Pigeon and TRD-tv like this.
  3. Mar 16, 2020 at 5:06 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  4. Mar 16, 2020 at 5:35 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Not sure which fuse this would be. Any idea?
  5. Mar 16, 2020 at 5:37 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    To me sounds like a loose connection, the cargo lights option kit comes with the cheap t-taps and later or sooner this becomes loose (I know this because it happened to me) You can go under dashboard and check the t-tap I recommend you to replace it with a Positap.
    The wiring is in front of the ECU harness is the only one with black plastic wire loom and have a inline fuse holder
    ElNopal likes this.
  6. Mar 16, 2020 at 5:53 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Fuse for cargo light, I'd imagine, interior fuse panel driver a-pillar lower kick panel.
    All the lights are out yes, upper 3rd brake light in addition to the rear most?
    Being a 17, I'd assume your out of warranty because your asking use for help. Otherwise, I'd say take it to the dealer.
  7. Mar 16, 2020 at 6:21 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Checked fuses. All are good
  8. Mar 16, 2020 at 6:23 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Checked that inline fuse. Looks ok
  9. Mar 16, 2020 at 6:28 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Which tells me the 3rd brake light works, maybe?
    If so, then there is probably an issue with wiring isolated specifically between the rear lights and where they tap into the main harness.
  10. Mar 16, 2020 at 6:58 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Yup. Everything else works fine.
    Anyone know if this type of issue is covered under warranty?
  11. Mar 16, 2020 at 7:15 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Would be under the 3/36k, dont think it'll fly past that.
    Edit: dealer add on so probably only carrys the 12month warranty
  12. Mar 18, 2020 at 8:38 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
  13. Mar 18, 2020 at 9:40 AM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Nothing looks off. I took a look at the inline fuse near the ecu and fuse box. All looks ok. I'm thinking it might be near the wiring harness in the back near the spare tire.
    Gonna take it to the dealer tomorrow to see if they cover it. I'll update the thread then with what the issue was.
  14. Mar 18, 2020 at 9:43 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    If your near Earnhardt off the 60, go see Joe Naggy. Great guy.
    If your Gilbert and san tan 202 area, go see Zach, great guy as well!
  15. Mar 18, 2020 at 9:46 AM
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    Check the connection right near the tow hitch under the truck. I had this issue in the past and that connection came loose. Its where all harness connections come together. The other thing to check is to make sure your splices are tight under left side of driver dashboard.
  16. Mar 18, 2020 at 10:48 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    This is the Red t-tap I’m talking about, check this splice to make sure is tight and making a good connection when mine stopped working I knew it was this thing I replaced it with a positap and all worked again.
    texasrho83 and ElNopal like this.
  17. Mar 18, 2020 at 11:34 AM
    Scoobyvroom
    Scoobyvroom New Member
    2020 Tundra Limited
    In the process of de-chroming....
    Holy buckets, that wire looks way to small to be using a T-tap like that. Strip it and solder if that is the case!
    iHacker and SnrDisregardo like this.
  18. Mar 18, 2020 at 1:33 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  19. Mar 18, 2020 at 1:48 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Edit: What gauge wire do you think this is?
  20. Mar 18, 2020 at 6:23 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    20 gauge you can safely use a RED positap going bigger than that can cut the wire.
    NewImprovedRon and ElNopal like this.
  21. Mar 18, 2020 at 6:47 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Had this issue. Bad ground.
  22. Mar 20, 2020 at 1:04 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Where is the ground at?
  23. Mar 20, 2020 at 1:15 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Dealer just said it's not covered under warranty since this wasnt installed at the Texas factory. They want to charge $100 to diagnose.
  24. Mar 20, 2020 at 2:06 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    It would appear that the ground for a 17 was “tapped” onto the white and black ground wires with the eyelets held tight by the 10mm bolt just underneath the driver’s side kick panel.
    iHacker and texasrho83 like this.
  25. Mar 20, 2020 at 2:42 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    El Nopal shows where it's grounded. I redid the grounds at both lights and kept them local.
    ElNopal likes this.
  26. Jul 14, 2024 at 5:03 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Took me forever to get around to this (literally 4 years). No luck. Replaced the t-tap with a posi-tap connector and no dice. I think I'm just gonna give up at this point.
  27. Jul 14, 2024 at 5:05 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
  28. Jul 14, 2024 at 7:22 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    OEM bed lights have cheap dim LEDS.
    I replaced mine with a $20 set of Amazon lights, had to fit and solder the wiring...
    Amazon.com: Ampper White LED Rock Light for Bed Track, 60 LEDs Cargo Pickup Truck Bed Lighting Kit W/Switch Fuse for Truck Bed, Foot Wells, Under Car, Rail Light and More (20 Pcs) : Automotive
    You've already got the wiring, just test them and make sure the wires are hot when you cut the old lights off.
    If you don't want to put it all together, Matt Gecko makes a nice kit.
    Just email him and tell him you don't need all the wiring.
    You just need enough to connect to your current OEM wiring..
    Motorcycle LED Headlights - MATT GECKO LEDS
  29. Jul 17, 2024 at 11:27 AM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    I like this option. Can you share any pics of your set up? Also, what did you do with the existing lights? did you just leave them in that location even though they aren't functional?
  30. Jul 17, 2024 at 7:07 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I don't have pics of the lights, maybe I can take some tomorrow.
    I will say I taped off the actual lights and painted the wires black.
    I didn't realize the black LED lights had white wires when I bought them.:rolleyes:
    I cut the OEM lights off and trashed them, I used the existing wiring and soldered the Amazon lights in.
    My OEM setup was a little different.
    I have a swing case and couldn't put the OEM lights in both the tailgate rear corners and put one up front.
    I wired the passenger side to the rear passenger side OEM bedlight and the driver's side to the front OEM bedlight.
    02E0EFFB-296C-4323-BEDC-88898E8043E2_zps_f7eebe95fbe6634dd2399979160c7269376cac39.jpg
    I did have the thought of modifying the OEM bed lights with VLED puddle lights.
    Cut the appropriate sized hole in the OEM fixture and wire the VLED puddle lights.
    But having one in the front would have blinded me when I opened the tailgate.
    You might consider mounting some kind of LED light into you existing bedlight.
    That would be easier than doing all the work I did of wiring and mounting them to my bedrail.
    The VLEDs are a bit expensive but very bright.
    I used them for my custom mirror puddle lights.
    Perhaps you could find something on Amazon that would be cheaper and work.
    UNIVERSAL LED PUDDLE LIGHT (vleds.com)
    3gnu04bz_zpsgecrr1ak_6b2c3fba785bd70605925dc2dd44b2a04652db97.pngjq1k2l34_zps6rwjs4ah_f1ce0db7b9b6be6adade7294fa2f153cb3d8fae5.png
    I just got off from a 13 hour work day so I hope this post makes sense..:eek2:
