Car to Car communications
Discussion in 'Audio & Video' started by BlueBottle, Dec 27, 2017.
What type of Car to Car communications do you use?
  1. FRS/GMRS radios
    21 vote(s)
    38.9%
  2. CB
    10 vote(s)
    18.5%
  3. Ham
    19 vote(s)
    35.2%
  4. Other
    4 vote(s)
    7.4%
  5. None
    11 vote(s)
    20.4%
  6. Dual Band
    8 vote(s)
    14.8%
Multiple votes are allowed.
  1. Dec 28, 2017 at 12:26 PM
    #61
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  2. Dec 28, 2017 at 12:28 PM
    #62
    Sunnier
    Sunny
    San Diego, CA
    Thanks! I got all the way to the cart at the Rugged sale... then managed to pull myself away. Probably better to spend today's money on Husky floorliners today. I hope I don't regret letting this HUGE sale pass though... like I did the Black Friday sales on Huskys.
  3. Dec 28, 2017 at 12:37 PM
    #63
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Sorry guys, haven’t been checking into this all day. $117 is a hell of a deal for the link posted above. The antenna alone in this kit is normally $50 by itself. This is pretty much the setup I run, minus the direct 12v connection. This same antenna is what I mentioned earlier, called their ducky antenna. If you are going to use it as an in car radio then that’s the best way. You could also get a 2nd one if you wanted a battery setup you could use outside of the car, or just grab a battery/charger combo and swap it in when you need it.
    Again, just to clear up. Baofengs are good radios and I own a couple, but after I bought the rugged, I would run a rugged simply because of the support and customer service they provide.
    Based on this sale, I may be expanding into a com system with headsets for my jeep. Prices are cheap!!
  4. Dec 28, 2017 at 12:45 PM
    #64
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Thanks buddie. Think I’ll pull the trigger on this setup!
  5. Dec 28, 2017 at 1:07 PM
    #65
    Sunnier
    Sunny
    San Diego, CA
    @the_midwesterner are you still online? If I buy, I'm thinking about the Ruggen radio you posted, but with the magnetic antenna mount. I understand I don't have to keep the antenna attached full time, jut put it upon when I'm using it? Run the connection coax cable through an open window?
    Any thoughts on this, anyone?
    dcsleeper408 likes this.
  6. Dec 28, 2017 at 1:08 PM
    #66
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    You’ll be fine. I would just run it through the door. Unless you plan to run the window open the whole time.
  7. Dec 28, 2017 at 1:53 PM
    #67
    the_midwesterner
    Luis
    None, yet....
    This is all personal preference bud. Just depends on what you are doing. I ALWAYS hard mount my antennas. Simply because the magnet ones may get stuck on top of sand/dust/silt and if it moved around while Offroad, it may kill your paint. Unless you are getting the hard mounted radio, I’d say you’ll be just fine with the ducky antenna, or the other more expensive one they have. About the only other reason to get the extension and a mag/hard mount antenna is if you plan on keeping the handheld in the truck full time.
  8. Dec 28, 2017 at 3:16 PM
    #68
    the_midwesterner
    Luis
    None, yet....
    Just to show you guys that I am not a baofeng hater, ha!
    Pictured, from left to right:
    - RM-25R going into my tundra
    - 5 watt baofeng with Rugged ducky antenna
    - HX400 with handheld mic. I used this in my jeep before I got the permanent car mount. Kind of a terrible radio from a programming perspective since it was mandatory to use a laptop, but otherwise a super stout radio quality wise. I’ve beat the shit out of this thing and it just keeps going.
    Not pictured, which I also own:
    - rugged radio blue handheld (rebranded baofeng) with ducky antenna. Can’t find it at the moment.
    - RM-25R permanently mounted in my jeep
    Overall, I’d say I’m pretty much set on radios. Just trying to learn more about HAM and the use for them.
  9. Dec 28, 2017 at 4:56 PM
    #69
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I'm all for paying a little more for good customer service, but the $85 regular price that they list is out of control. The sale price might be worth if it you really like blue. If I was in the market for another handheld, I would go for either the red UV-5R V2+ (red would be good for a loaner on the trails) or the BF-F8HP (8 watts and a big battery).
    If anyone is looking for a better antenna, check out Nagoya Antennas on Amazon. I have both the NA-717 and NA-810. It is always nice to have options.
    Sunnier, dcsleeper408 and joonbug like this.
  10. Dec 29, 2017 at 9:31 AM
    #70
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Welp I pulled the trigger and bought the rugged trail kit while it was on sale. Their sale is gone and they are regular price now. I’m sure they will have sales on the next holiday for anyone that wants in. Thanks for everyone’s help!
    Sunnier and dcsleeper408 like this.
  11. Dec 29, 2017 at 9:32 AM
    #71
    BlueBottle
    '16 Platinum 4x4
    See fine print
    To the guys w the technician license, what’s the best way for someone that wants to get it? Online? Links?
  12. Dec 29, 2017 at 9:45 AM
    #72
    GodlessPro
    Matthew
    NorCal
    If you are willing to give up a Saturday, look for a local HAM club that is running a class. Otherwise, get the ARRL license manual, read through it and then use a flash card app to practice until you are getting 90% of the questions right. The nice thing is that it is a set pool of questions, so when you take the test, there is a good chance you will recognize the questions that you practiced with. In the Bay Area it should be easy to find a club that is administering tests just about any Saturday morning. If you practice enough it shouldn't take you more than 30 minutes from the time you arrive until the time you walk out with a passing score and slip of paper.
    Check the earlier post from @smslavin he had some links that might help.
  13. Dec 29, 2017 at 10:44 AM
    #73
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    There are other sites but I will probably go to this one when they have something more local before DV
    http://www.baears.com/
  14. Dec 29, 2017 at 10:50 AM
    #74
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    The actual test will have to be taken in person. Use the ARRL site to find a club local to you and ask about their testing schedule. You can also find a local HRO store and ask them. The test will probably be given by someone old enough to be your grandfather but those guys go back to morse code and the days of building radios by scratch. They’ve forgotten more than you and I will ever know. Worth it to get to know a few of them.
  15. Dec 29, 2017 at 11:04 AM
    #75
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Lmk I’ll join you!
    Thanks!
    dcsleeper408[QUOTED] likes this.
  16. Feb 10, 2018 at 3:45 AM
    #76
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Ok what is the best if ease of setup is priority 1 that still works well
    Sunnier likes this.
  17. Feb 10, 2018 at 5:40 AM
    #77
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
  18. Feb 10, 2018 at 5:43 AM
    #78
    MT Madman
    Hawk Point MO
    Ditto, look here http://www.arrl.org/find-a-club
  19. Feb 11, 2018 at 4:46 PM
    #79
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Well I ended up buying the baofeng uv_82 .....just got to figure out how to program
    GodlessPro likes this.
  20. Feb 11, 2018 at 6:15 PM
    #80
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I use chirp to program.
  21. Feb 12, 2018 at 8:46 AM
    #81
    GodlessPro
    Matthew
    NorCal
    Stulloh and dcsleeper408 like this.
  22. Feb 14, 2018 at 12:41 AM
    #82
    Sunnier
    Sunny
    San Diego, CA
    For those of us that don't even know what we don't know, what is this 'programming'? Asking b/c I bought a radio, set it using the buttons on the radio to a frequency someone knew worked where we were traveling, and off it went.
    Please can one of you give a synopsis of what CHIRP does, or post a link to somewhere we can read about it?
  23. Feb 14, 2018 at 1:07 AM
    #83
    We use two way radios when backing up the TT if we are in a tight spot. That way I can radio to the wife she is about to hit something. Lol.
    I used to think having a CB would be cool. My current Jeep when stock(ish) came with a CB. I think it lasted two trips out with people/groups I didn’t know well. It was like a football radio commentary on the CB. I finally told three people to shut the hell up, cut my CB cord and it has been awesome ever since. I see no use at all for a CB radio in the type of off roading I do.
    Sunnier likes this.
  24. Feb 14, 2018 at 1:31 AM
    #84
    Sunnier
    Sunny
    San Diego, CA
    10-4. Copy. I hear you, good buddy! Loud and clear. Over and out.
    :anonymous: Is this pretty much what it was like?
  25. Feb 14, 2018 at 5:55 AM
    #85
    Yes only way more annoying.
    Sunnier[QUOTED] likes this.
  26. Feb 14, 2018 at 7:31 AM
    #86
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    CHIRP is to program those frequencies you commonly use.
    example:
    147.xxx would be ch.1 on your radio
    147.7xx would be ch.2 on your radio
    and so forth.
    CHIRP also gives you the option to program settings, save channel list
    here a really long and fun video you can watch.
    https://www.youtube.com/watch?v=-cUmyElf1MI&t=1534s
  27. Feb 14, 2018 at 2:17 PM
    #87
    Sunnier
    Sunny
    San Diego, CA
    Tech video = fun. Haha! :confused:
    Thanks for the info! :fistbump:
  28. Feb 14, 2018 at 2:21 PM
    #88
    CCLA
    CCLA New Member
    Check out the Zello app. You can do car to car or create a channel and do a broadcast to everyone on that channel
    Sunnier likes this.
  29. Feb 14, 2018 at 2:59 PM
    #89
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Zello app needs cellular data or wifi to work.
    BlueBottle[OP] likes this.
  30. Feb 14, 2018 at 4:52 PM
    #90
    BlueBottle
    '16 Platinum 4x4
    See fine print
    But I have reception in the mall!?
