cant attach upper control arm after 2" Spacer
Discussion in '1st Gen Tundras (2000-2006)' started by pitbullkid, Jul 10, 2020.
  1. Jul 10, 2020 at 6:57 AM
    pitbullkid
    pitbullkid [OP] New Member
    I installed a 2-inch level kit spacer on my 1st gen tundra. Now I can't seem to get the struts to compress enough to reattach the UCA to the ball joint. Have tried jacking the LCA up but that just raises the truck. Have tried lowering the truck down on itself but that still doesn't seem to get me close enough. Also have tried ratchet straps. Nothing seems to work, any suggestions?
    Should note drivers side went on no problem. Is there something wrong with my struts/shocks? Have had them a few hundred miles and haven't noticed any issues prior.
  2. Jul 10, 2020 at 11:19 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is your swaybar disconnected? Make sure it is unbolted on both sides.
    Are you working with a stock shock and spring assembly? (Aside from the spacer)
  3. Jul 10, 2020 at 12:50 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    This.
    If it's not disconnected do you have both wheels in the air and no weight on either lower control arm?
    I did mine (coilovers not spacers) without disconnecting the sway bar.
    You can also stick a pry bar in the coil and pull down on the UCA or stick the jack upside down between the UCA and fender liner to get it lower.
  4. Jul 10, 2020 at 1:08 PM
    spring compressors, pry bar, curse words, excessive sweating. All were involved in reinstalling the longer than stock strut assemblies on mine.
  5. Jul 10, 2020 at 1:10 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
  6. Jul 10, 2020 at 8:24 PM
    pitbullkid
    I got it in, All I did was buy a couple of bricks and slowly lowered the A-arm down onto it. Did the trick!! Then just used the ratchet strap for minor tweaking
    Darkness and SC_TRD like this.
