Can't Align Due to Lift
Discussion in 'Suspension' started by tony93, Jul 27, 2023.
  1. Jul 29, 2023 at 12:09 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    You're at about 4.5 inches of lift with that combo.
    tony93[OP] likes this.
  2. Jul 29, 2023 at 12:10 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would assume those coil overs are probably the original from new. Probably time to replace anyways. Remove spacer lift, replace coil overs with 1.5-2.5” lift, and replace coachbuiler shackles with stock. And don’t get your alignment done at the dealership.
  3. Jul 29, 2023 at 12:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    He was asking for pics of the cams showing the markings on the face to see if they’re maxed out.
    BeauDacious likes this.
  4. Jul 29, 2023 at 12:35 PM
    tony93
    tony93 [OP] New Member
    2015 Toyota Tundra
    Ah, missed that - just fixed the photos.
    joonbug[QUOTED] likes this.
  5. Jul 29, 2023 at 12:42 PM
    tony93
    2015 Toyota Tundra
    Lol! Found a pair of used OEM shackles for $150. Would driving around on the coachbuilders cause any issues with the leaf springs or should they be good? Not sure if I can afford the coil overs at the moment. Will I be fine with removing the lift and then replacing the coil overs at a later date (6 months)?
  6. Jul 29, 2023 at 12:45 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Uh say what? Used OEM for $150? I'll send you mine for free just pay to ship.
  7. Jul 29, 2023 at 12:48 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Only reason I said to remove the CB is to lower the rear while you’re lowering the front so you won’t have too much rake. I’m just assuming they’re fairly big because you have 4” up front. But the CB shackles are much better than stock and definitely won’t hurt to keep them on. Actually you should figure out which CB shackles you have. If they’re minimal lift I would just keep them if the rake isn’t bad. And you can find oem shackles for less than that. People have takeoffs laying around.
    tony93[QUOTED][OP] likes this.
  8. Jul 29, 2023 at 1:06 PM
    tony93
    2015 Toyota Tundra
    Not sure how much of a lift the coachbuilder shackles are adding but I would assume 3.5 at least (they are 9" in length). From hub to wheel well is ~25.5 and I think stock is 22". I actually like the look of the truck with the lift but feel it's the reason for the bad tire wear.
  9. Jul 29, 2023 at 1:15 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That front spacer stack is a shit show. Definitely get those 1/4 inch plates out of there. Or better yet maybe pull the big on and just leave the two small ones for a 1 inch lift
    Rodtheviking and tony93[OP] like this.
  10. Jul 29, 2023 at 1:20 PM
    tony93
    2015 Toyota Tundra
    Awesome - thank you! Below is my email (I can get you my info and payment for shipping)
    latrineturbo@yahoo.com
    Thank again - really appreciate it!
  11. Jul 29, 2023 at 1:29 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    He's got 3 sizes: +1, +2, +3. The +1 gives you .625" of lift, the +2 gives you 1.25", and the +3 gives you 1.75" of lift.
  12. Jul 29, 2023 at 1:31 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    PM'd you
  13. Jul 29, 2023 at 3:45 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That sounds like a plus 3. Which makes sense you have 1.75 lift rear and 3.5 at least in the front sitting level. Your gonna be amazed how much better it rides when you fix the front with less lift.
    Now that youve measured the lift, it makes sense why they can’t align it. That is way too much for the stock uca to handle. Even if they fixed the camber, its gonna handle like crap compared to a stock truck
