Canadians: Where do you buy your oil and have it recycled?
Discussion in 'Canada' started by SprinterAE86, Nov 2, 2020.
  1. Nov 2, 2020 at 12:31 PM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I usually do my own oil changes and take the used oil in the recycling center. I was trying to shop for oil via Amazon and Walmart and the prices are almost doubled even after the conversion from USD to CND.
    Where do you buy your W0-20 Synthetic and does the provincial recycling center take it or you have to take it to a different facility that specialize in recycling oil only?
    Should I just take it to Toyota?
    Thanks!
  2. Nov 2, 2020 at 12:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    As far as I know, our local county environmental station takes used oil at no charge but that's obviously going to vary substantially depending on where you are.
    I like to buy my oil from Canadian Tire even if it costs a bit more because I want to support Canadian companies and I really don't like Walmart.
  3. Nov 2, 2020 at 1:03 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Check with your local auto parts chain, they sometimes take bulk oil for recycling.
    SprinterAE86[OP] likes this.
  4. Nov 2, 2020 at 1:05 PM
    SprinterAE86
    Ian
    Thanks! I'll check Canadian tire prices and compare. I do want to support local business, but Canadian tire is Canada's Walmart minus the groceries. But since I'm residing in Canada now, I have to support and help the the Canadian economy, since it will benefit the community overall.
  5. Nov 2, 2020 at 1:05 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Walmart and Walmart.
  6. Nov 2, 2020 at 3:19 PM
    SprinterAE86
    Ian
    By the looks of it, I will be spending the same amount DIY and going to Toyota for an Oil Change. I guess, I'll just schedule my oil change in Charlottetown Toyota next week.
  7. Nov 2, 2020 at 3:32 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I use the Flipp app and search for sales and support whoever is cheapest when I need it.
    Locally we can bring used oil to the back of a fire station along with other household chemicals for recycling.
  8. Nov 2, 2020 at 3:36 PM
    Outbound
    Aaron
    Northern Alberta
    I run Mobil 1 so I wait for Chinadian Tire to have a sale then I stock up. I only need to change my oil twice a year so it works out well. I'm also fortunate to work at a place that disposes of oil and grease semi-regularly so I just take it to work and add it to the pile.
  9. Nov 2, 2020 at 5:49 PM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    We also purchase most of our oil at CT. They often have 50% off sales on top motor oils like Mobil 1 and Pennzoil Ultra Plat.
    The local CTs used to accept used oil, but I don’t believe they do anymore. City/Municipal dumps and firehalls often take it- free of charge.
  10. Nov 2, 2020 at 6:16 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I started buying my 0W20 from my local ‘yota dealer. Their regular price per litre worked out to about the same as Mobil 1 AFE on sale at Cambodian Tire, and I no longer have to watch for sales and hoard lube for my personal use.
    Disposal is easy for me, since I work in a shop with a 5000 L used oil tank and a Cleanburn oil furnace.
  11. Nov 25, 2020 at 7:32 PM
    ICECOLDBEER
    ICECOLDBEER New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    Walmart has it in there flyer here 5L mobil 1 $23. I thought that was pretty good. I used to always take it back to Canadian tire but for some reason they stopped accepting used oil. Now I am going to have to go to the dump...
