Can you reprogram TPMS Maximum pressure
Discussion in 'Wheels & Tires' started by RJN55, Mar 4, 2019.
  1. Mar 4, 2019 at 12:31 PM
    RJN55
    RJN55 [OP] New Member
    2018 Tundra LIMITED DC (Flares, Rear Sway Bars, Timbrens, B&W Gooseneck Hitch, Running Boards, Visors, 18 inch rims with 10 ply Michelin AT/2's, Bed Lights, Tow Mirrors
    I swapped tires on my new 2018 Ltd. I'm now running 10 ply LT Michelins like I did on my 07.
    I will run at 70-80 psi when I'm loaded with my draft horses (trailer).
    The TPMS display seems to max out at 50 psi.
    Is this changeable?
    (Note I'm still happy as it will warn me if one drops, i'd just like to see the actual pressures)
    Thanks
  2. May 4, 2019 at 8:18 AM
    RJN55
    bump
  3. May 4, 2019 at 8:30 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Have you tried bumping pressure up and then doing a reset from the button on the dash?
  4. May 4, 2019 at 9:17 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'd try what Danny said. If that doesnt work you can maybe look into techstream and see if it can be set that way
  5. May 4, 2019 at 9:28 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Places like Discount Tire can program. They might be able to "re-range" them. Not sure if all have the same ranges.
  6. May 4, 2019 at 3:11 PM
    RJN55
    Haven't tried a 'reset'. Have been running at 80 psi (and it shows 50 psi) for months now. Was 35 before my tire swap. Will try tonight. thanks for the idea.
  7. Jul 22, 2021 at 9:59 AM
    jeb
    jeb New Member
    2019 TUNDRA SR5
    Bumping this. Lot's of us running over 50psi. Anyone find fix for changing max readout so it's accurate?
