Can you permanently disable the PCS?
Discussion in '3rd Gen Tundras (2022+)' started by BokChoylentGreen, Jul 24, 2022.
  1. Aug 20, 2022 at 3:30 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Wow...that's appalling.
    Officially not buying a Jeep ever now. I always knew they were pieces of shit but the fact that an issue like that was ever released to the public destroys the 2% chance I was ever going to get one.
  2. Aug 20, 2022 at 4:55 PM
    Brett B
    Brett B New Member
    Your PCS should not have that many false positives. Maybe try taking it to another dealer or asking your existing one to escalate to this issue to the regional quality representative. Depending on your state you may even have lemon laws that will get their attention if they fail to repair an issue after 3 tries.
    The radar behind the grill and the camera in the windshield need to be calibrated for the PCS to work properly. Potentially one of these units needs to be replaced, or it was not calibrated properly during production. A mis-calibrated radar would certainly have many false positives like you are experiencing. If you can get it to mis-activate in the same spot as described above, try taking video of it from inside the cab while driving. Then you can show them the video to hopefully get some attention. You should not have to physically block the camera to keep the PCS from throwing multiple false positives during normal driving.
  3. Sep 12, 2022 at 12:36 PM
    crowdedstr
    crowdedstr New Member
    Northern WI
    Sounds like someone's never experienced the joy of their new truck slamming on the brakes out of nowhere for a non-existent 'safety' threat :)
    I was going ~60mph the first time it happened and nearly sh*t myself. Thank god nobody was immediately behind me.
    kirkb, Gene_in_FL and 9OH1 like this.
  4. Sep 12, 2022 at 3:57 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    You haven't lived if you didn't put your truck in Reverse, and opened your driver side front door while backing up!
    :wave:
    crowdedstr[QUOTED], 9OH1 and AND like this.
  5. Sep 13, 2022 at 6:23 AM
    rpjones68
    rpjones68 New Member
    2022 Blueprint Limited 4x4 TRD Offroad
    We had our back neighbor's jeep pop out of park in his driveway and roll down the hill thru my fence and into my next door neighbor's yard where it hit a tree. Luckily nobody was hurt and most of the damage was to the jeep.
  6. Aug 18, 2023 at 11:18 AM
    mudflap5
    mudflap5 New Member
    I know this post is a little old, but I was trying to turn off PCS with Techstream, or at least have it "Store the State" of pcs. That option does not show up under customization on TS v.18.0... What version are you using?
    Thanks
    -Paul
  7. Aug 18, 2023 at 3:06 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    This also prevents you from getting the brakes slammed when someone purposefully cuts you off. It's a thing with Teslas that's been spreading. Just cut them off, no need to brake check, Tesla will brake itself. Same here with the Tundra.
  8. Aug 18, 2023 at 4:58 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Allow me to rebut, please. :)
    Jeeps ARE pieces of shit. Not "were". They "were" fabulous vehicles in their time. I own an excellent example of the most capable Jeep ever made, and the last one worth owning: the 2006 TJ.
    Jeep committed suicide the following year, taking along with them the legendary 4L AMC straight six engine.
    Now they truly ARE pieces of shit, full of nanny gear, and little rubber ducks.
    Soupbean77 likes this.
  9. Aug 18, 2023 at 8:12 PM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    Got to ask the obvious......have you tried a different Dealer?
  10. Aug 19, 2023 at 9:47 AM
    mudflap5
    mudflap5 New Member
    I just want to get TS working properly for this and a few other settings. Not interested in going to a dealer for anything. Used Carista initially, but I would think TS should be able to do anything Carista can do, and a whole lot more.
  11. Aug 19, 2023 at 9:42 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Theres the Answer !! Techstream setting to eliminate default ON
    nodak67 likes this.
  12. Sep 1, 2023 at 12:06 PM
    Sixty9Four20
    2023 TuRD Pro
    Too bad I can't use a burner account to get another trial on carista - tried. Will have to use the partners phone.
  13. Oct 25, 2023 at 6:59 AM
    Tyson_501
    Tyson_501 New Member
    Ty
    U.P. of Michigan
    2018 Tundra SR5 CrewMax - Magnetic Gray
    Resurrecting this thread again. Has anyone successfully disabled PCS permanently through Tech Stream or other method? Had a buddy get a snowplow installed on his 23 Platinum and even with PCS disabled in his dash menu, the truck still doesn't want to cooperate. The truck will make it about 50' at speeds less than 10 mph and it will jack the brakes. I know of two other guys in town with plows on 22 SR5's and they don't have any issues.
  14. Oct 25, 2023 at 9:42 PM
    PNW Tundra Mike
    Back in So Cal
    And if he just pushes the lower dash button? Still brakes?
  15. Oct 26, 2023 at 7:29 AM
    Tyson_501
    Ty
    U.P. of Michigan
    Correct. Any dash menu sequence or pushing the lower dash button does not disable the feature completely and it will still apply braking for some reason.
  16. Feb 3, 2024 at 9:04 AM
    Mainetundra1
    Mainetundra1 New Member
    2022 tundra limited trd
    Leveling kit
    Was an answer ever located to disable this? I am trying to install a snow plow on a 2022 Limited and the brakes lock up every time we move forward. So frustrating. I have tried turning off the PCS in the dash, but it doesn't work. Any suggestions welcome!
  17. Feb 3, 2024 at 9:50 AM
    PNW Tundra Mike
    Back in So Cal
    Very odd. My 23’s PCS does not apply the brakes when turned off with the lower dash button. (and it doesn’t reset to On with every start cycle) It still alerts/beeps when I pull up to or back up to anything but no slamming in the brakes. No option in Carista to disable it. Did you try Tow/Haul mode? Its supposed to disable at least the rear sensors so you can back up to your trailer (per the manual). Maybe the fronts are off too? Some here have reported it works, and others not. You’d think for applications like yours Toyota would have to be able to disable it somehow. I wondered if winching equip or a tow strap out front, if you had hooks, would also set it off.
    Mattedfred likes this.
  18. Aug 22, 2025 at 3:20 PM
    Nio9
    Nio9 New Member
    Brums- it doesn't matter why he wants it off! The F'n point is Toyota programming & coding sucks., I turn my PCS off with a trailer on back & in reverse it still slams on brakes- I sense a law suite! Toyota is becoming less of a great manufacturer, they are trying everything & perfecting little.
  19. Aug 22, 2025 at 3:22 PM
    #49
    Breathing Borla
    AZ
    you know that was like from 3 years ago right? lol
    kirkb likes this.
  20. Aug 22, 2025 at 3:25 PM
    #50
    Nio9
    Nio9 New Member
  21. Aug 22, 2025 at 3:30 PM
    #51
    Nio9
    Nio9 New Member
    It's annoying why people ask stupid question- the button shows PCS off & it still activates, that's an issue- there are so many problems with the new gen Tundra Toyota should be embarrassed.
  22. Aug 22, 2025 at 3:31 PM
    #52
    Nio9
    Nio9 New Member
    Not to mention it can be a real hazard
  23. Aug 22, 2025 at 3:31 PM
    #53
    Breathing Borla
    AZ
    ok man, have at it.
    kirkb likes this.
  24. Aug 22, 2025 at 3:47 PM
    #54
    Nio9
    Nio9 New Member
    I guess when Toyota starts profiting again after all those engine replacements they'll start releasing firmware updates for there hasty faulty early release glitchy software.
  25. Aug 22, 2025 at 3:49 PM
    #55
    Breathing Borla
    AZ
    let's try this another way
    did you try and hit the button that looks like a car hitting a little cone? try that and back up your trailer.
    and you only have to hit that once and it stays off, mines been off since I bought the truck
    kirkb likes this.
  26. Aug 22, 2025 at 3:51 PM
    #56
    Nio9
    Nio9 New Member
    That's helpful, I forgot about that button- all kept saying put in tow mode & turn off PCS. I will try it & post update, thank you!
  27. Aug 22, 2025 at 4:07 PM
    #57
    Breathing Borla
    AZ
    ya, I think what your having problems with is that, not PCS.
    you cant back up shit with that on, try it and report back.
  28. Aug 24, 2025 at 12:26 PM
    #58
    stretch2323
    stretch2323 New Member
    They have a harness to disable this
  29. Aug 24, 2025 at 12:27 PM
    #59
    stretch2323
  30. Aug 24, 2025 at 12:27 PM
    #60
    stretch2323
