Can you name it?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DMBfan, Sep 18, 2018.
  1. Sep 18, 2018 at 8:26 PM
    DMBfan
    DMBfan [OP] New Member
    I was installing a Tekonsha P3 brake controller on my 2015 Tundra SR5 (but found the harness is wrong now looking for the right one) and noticed an extra harness (black one). What is it it for and where can I get the device to hook it up?
  2. Sep 18, 2018 at 8:34 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I have the same plug, don't know what it's for. I'm watching this, so I guess we'll both find out together.
  3. Sep 18, 2018 at 9:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think that's the plug for the parking sensor on/ off switch.
    joonbug and GiantsFanDan like this.
  4. Sep 18, 2018 at 11:16 PM
    K6BRY
    K6BRY New Member
    2017 Black Tundra TRD 3/1 Lift Sittin' on 34s
    Maybe where the switch goes for the rear roll down window?
  5. Sep 19, 2018 at 12:47 AM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    You need the wiring adapter. 3017-p. That should be for 2015 tundras
    Pudge likes this.
  6. Sep 19, 2018 at 12:48 AM
    Steve Tundra
    Steven
    2022 4x4 platinum
    Should be about 12-15$ on eBay.
  7. Sep 20, 2018 at 10:58 PM
    Rudy4536
    Rudy4536 New Member
    2007 sr5
    Are you sure your brake plug doesn't have a cover snapped over it? my 2007 had a cover i had to remove.
    Good luck
  8. Sep 21, 2018 at 4:29 AM
    koditten
    koditten New Member
    I don't have that new of a tundra. Is the pics of anywhere near the glove box? That plug was used for a glove box light in older Toyota trucks.
  9. Sep 21, 2018 at 5:41 AM
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    I thought the brake controller harness was in the driver footwell under the side cover near the dead pedal? Did it move?
  10. Sep 22, 2018 at 10:28 AM
    DMBfan
    I have a 2015 SR5 Crewmax. The Tekonsha is hooked up via a harness plugged into the brake controller behind the panel located to the right of the steering column.
    I just can't figure out what the hell that plug is for.
  11. Sep 22, 2018 at 11:14 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Because it's in the panel wiring, I'm guessing it's for tilting headlights (top right).
    As for the correct P3 harness, this is what it looks like, I have one.
  12. Sep 22, 2018 at 12:26 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This is the other side of the steering column. Where the tow haul button is. I think my truck has the nannies button and parking sensor button there
    JoshuaA[QUOTED] likes this.
  13. Sep 22, 2018 at 12:44 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    You're right, I'm looking at the wrong side as those were the first 3 switches I thought of. Upon closer inspection at OP's pic, they are all the same size switches which is the right side and I'm missing the first one. If that's a parking sensor switch, bingo!
  14. Oct 14, 2018 at 3:49 PM
    BigE
    BigE New Member
    2014 set white
    What is the best brake controller, oem or p3?
  15. Oct 14, 2018 at 4:00 PM
    Pudge
    CT
    Anything but OEM seems to be preferred
    JoshuaA and BigE like this.
