Can the springs on my coil overs change ride height?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TexasYota2019, May 27, 2021.
  1. May 27, 2021 at 6:04 AM
    TexasYota2019
    TexasYota2019 [OP] New Member
    Houston, Texas
    2018 Black Tundra Sr5
    35" Ridge Grapplers 20x10 Fuel Wheels 4.5” fox 2.5 CO Lift
    My friend and I changed my front coil overs this past weekend and now it looks like my truck is nose diving. My truck has a 4 inch pro Comp lift with the stock coil overs and it used to sit perfectly level. We changed the whole front component (spring and shock). But now that we changed it out I’m rubbing in different spots and not sitting level. Is it possible that the spring was an oversized aftermarket part? I'm also noticed that when I turn right at slow speeds (5-10mph) there is a moan/high pitched drone sound coming from my front driver side wheel well. I have looked everywhere and the closest thing I've found was on a tacoma forum about the brake shield rubbing just a bit, anyone have a possible culprit?
  2. May 27, 2021 at 6:33 AM
    2mchfun
    Springs have a huge impact on ride height. If a crewmax, some coil overs will not give advertised lift. Sometimes you need to keep the heavier stock spring. There is a whole bunch of stuff to consider and research.
  3. May 27, 2021 at 6:38 AM
    2mchfun
    You may have taken out spacers when you changed your coilovers. Sounds like it. Have pics of it b4 and after???
  4. May 27, 2021 at 6:39 AM
    TexasYota2019
    Houston, Texas
    Ok them I'm almost certain those springs are the issue then. The shocks we put in were duralast OEM spec'd so hopefully we can swap out the springs and it will fix the issue.
  5. May 27, 2021 at 6:41 AM
    TexasYota2019
    Houston, Texas
    can't be the spacer, we did that on the first install and I couldn't even turn my wheels without sounding like the truck was going to fall off the frame lol. Next day we ripped it apart and put the coil spacers back on and it definitely helped. Let me run out and snap a pic of the after. Best pic I have of before is in my profile picture.
  6. May 27, 2021 at 6:41 AM
    2mchfun
    Like previously stated I think you have left spacers on old assemblies.
  7. May 27, 2021 at 6:44 AM
    2mchfun
    Sounds to me like you should be seeking someone who is a little more experienced to work on it. The front end of the truck being worked on by inexperienced people could get someone hurt or killed.
    Rodtheviking likes this.
  8. May 27, 2021 at 6:47 AM
    cain0725
    cain0725 New Member
    utube it! most shops have 21 year olds working on your crap, some are good, most suck
    Gravy likes this.
  9. May 27, 2021 at 6:50 AM
    TexasYota2019
    Houston, Texas
    Both spacers are in place, only thing that doesn't look right to me is that this spring seems a little less beefy than the one that is pictures
    This is before we changed out the front coil-overs
    And this is after, I tried to take them at the same angle.
  10. May 27, 2021 at 7:00 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    So the spring in the pic above is the new coilover? Where did the spacer on top of it come from? I can't tell a difference in ride height in your before/after pics. Looks like very similar front height to me.
  11. May 27, 2021 at 7:05 AM
    2mchfun
    Probably weak springs causes nosedive when braking and over bumps dips etc.
  12. May 27, 2021 at 7:06 AM
    TexasYota2019
    Houston, Texas
    Yes, I bought the new coilover as a complete piece. Then we got a spring compressor from auto zone so that we could get the spacer off of the coilover that was previously installed on the truck and put it on the new coilover. Where I think we messed up is not reusing the spring. So essentially we should have only replaced the shock.
    Barrett50 likes this.
  13. May 27, 2021 at 7:09 AM
    2mchfun
    Man that suspension is a nightmare with two big spacers in there. I would change the entire lift if it was my truck.
  14. May 27, 2021 at 7:12 AM
    2mchfun
    You should have coilovers that fit with your desired lift, not just swap shocks.
    Gravy, FrogmanTundra and TRDFerguson like this.
  15. May 27, 2021 at 7:12 AM
    TexasYota2019
    Houston, Texas
    I've been contemplating crying once and fixing this nightmare that I got into. I have definitely learned my lesson of buying a truck with the lift already installed from the dealership. I think with my lift they cut my crossmember and everyone I've talked to has said it's going to be a nightmare and a bank breaker to switch around.
    2mchfun[QUOTED] likes this.
  16. May 27, 2021 at 7:12 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    :eek::eek::eek::eek::eek2::eek2::eek2::eek2:
    FrogmanTundra, Geo4x4 and 2mchfun like this.
  17. May 27, 2021 at 7:18 AM
    2mchfun
    Just be careful with the spring compressor, very, very dangerous. Best to have a shop swap any springs.
    1UP likes this.
  18. May 27, 2021 at 7:21 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Agreed. The off road springs on our trucks are no joke.
    1UP, Barrett50 and 2mchfun[QUOTED] like this.
  19. May 27, 2021 at 7:26 AM
    TexasYota2019
    Houston, Texas
    you're making me feel bad lol. I now know that I messed up when purchasing this truck. Next one will definitely be a proper lift from BDS.
  20. May 27, 2021 at 7:31 AM
    2mchfun
    Just got to say the truth, making you feel good is not helping anything, that is what the seller did, now look.
    FrogmanTundra likes this.
  21. May 27, 2021 at 7:33 AM
    TexasYota2019
    Houston, Texas
    any idea as to what the cost would be to end up doing this right?
  22. May 27, 2021 at 7:36 AM
    2mchfun
    Depends on many factors, diy, shop, components, new, used, personal connections, etc.
  23. May 27, 2021 at 7:40 AM
    BlackSheep
    Scott
    Kansas City, MO
    yeah that question is too generic to answer accurately. holy hell, i didn't notice at first that you have TWO spacers on there. i can't even imagine the ride quality of that truck, and i'm sure it's not safe, either.
    One thing to consider is if you want to keep that 4" of lift up front is you should really replace your stock upper control arms. 3" lift is generally the max you can go without swapping those. It'll throw off your alignment and probably hit the coil spring in droop situations.
    2mchfun likes this.
  24. May 27, 2021 at 7:42 AM
    2mchfun
    Maybe not the factory spindles so maybe not
  25. May 27, 2021 at 7:43 AM
    BlackSheep
    Scott
    Kansas City, MO
    didn't realize that
  26. May 27, 2021 at 7:47 AM
    TexasYota2019
    Houston, Texas
    At this point I'm considering trading it in and starting fresh.
  27. May 27, 2021 at 7:48 AM
    2mchfun
    Yes, several aftermarket spindles are available and change the geometry in various ways. But, I do like my adjustable UCAs, no doubt.
  28. May 27, 2021 at 7:50 AM
    2mchfun
    Just one problem, shortages and high prices right now. Maybe sell and ride the bus or carpool until things settle down and chips are available.
  29. May 27, 2021 at 8:02 AM
    2mchfun
    Seems to me like you could look at your truck and a stock truck side by side and determine what is different, then decide. Might also find your desired distance from upper to lower shock mount and look for coilovers that will fit. Beware of all the other things that may out of whack, front differential, sway bar, bump stops, brake line locations front and back, carrier bearing, maybe rear shock extenders, shackles, etc. Lots of things to get right when lifting.
  30. May 27, 2021 at 8:06 AM
    2mchfun
    On top of that you may want to consider rear traction bars to control your axle wrap. Personally I have the BDS version.
