Can someone help is this too good to be true or should work
Discussion in '2nd Gen Tundras (2007-2013)' started by MOSTTX13, Jun 8, 2018.
  1. Jun 8, 2018 at 1:30 PM
    MOSTTX13
    MOSTTX13 [OP] New Member
    2011 Toyota Tundra Crew MAx
    Memphis Audio 12s, Mayhem Beast 20S Amp Terrain Grippers
  2. Jun 8, 2018 at 2:14 PM
    15whtrd
    15whtrd Mr. Blonde
    Save your money man. You have to pull everything apart just to put those spacers in. I’ve heard the ride isn’t the best and you risk blowing your shocks out. If you do decide to put spacers in you have to extend your bump stops because your shocks will bottom out before the bump stops contact.
    They will lift your truck no doubt.
    There are quite a few people around here that run them without issues. But save your coin and your valuable time and get some proper shocks and springs upfront.
