Can I use my 255/70R18 tires on these wheels?
Discussion in 'Wheels & Tires' started by Scion, Nov 8, 2017.
  1. Nov 8, 2017 at 8:46 PM
    Scion
    Scion [OP] New Member
    New to the forum, first post.
    I know nothing about wheels and tires. I usually leave everything stock.
    I purchased a 2017 Tundra SR-5 2WD. It came with stock 18inch Styld Stl Wheels. The tires are P255/70R18.
    I was look at Tirerack.com for some new wheels, but wanted to use my current tires on the new wheels. The wheels I am looking at are listed below.
    My question is, is this possible to do? On Tirerack.com it say the required tire size is 275/65-18. Would I be able to use my stock tires that are 255/70R18? Any help is appreciated.https://www.tirerack.com/wheels/Whe...=Tundra+2wd&autoYear=2017&autoModClar=CrewMax
    OEM:
    Wheel I want:
    Tacogrande likes this.
  2. Nov 8, 2017 at 8:54 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome !
    :worthless:
  3. Nov 8, 2017 at 9:14 PM
    Scion
    Pics added
  4. Nov 8, 2017 at 9:22 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Yes, they'll work. almost identical in circumference. Your tires are about .75" narrower but still wider than a 9" rim. Your tires are roughly 10" wide.
    Rex Kramer and Scion[OP] like this.
  5. Nov 8, 2017 at 9:23 PM
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    I believe you are reading that wrong... it sta
    Rec. Tire Size = recommended not required. Your old tires should work fine on those wheels. There is also a website that will simulate the two tire sizes and allow you to compare them in inches if unsure.
    Scion[QUOTED][OP] likes this.
  6. Nov 8, 2017 at 9:24 PM
    ChristianEKR
    ChristianEKR New Member
    2017 Quicksand CrewMax SR5
    Welcome! I’m right there with you, the stock 18”s are badddddd. What I’m pretty sure I’m doing is buying TRD rims and tires off craigslist. OEM for like eight hunnit fiddy (sometimes more sometimes less). Rims are nowish priority, there’s other stuff I need to do first that is more about functionality (linex the bed, linex the chrome bumperettes, Yakima rack and basket, hoop steps) and rims/tires are just a cosmetic thing that drives me nuts (along with my giant chrome grille which I’m replacing with a TRD Pro grille nowish too). I have a wife, business, mortgage, and a kid so I really have to pick my battles. I can sneak little stuff like emblems and antennae in though!
    Skeezo, Scion[OP] and 831Tun like this.
  7. Nov 8, 2017 at 9:29 PM
    Scion
    Thanks so much for the quick reply. I'm so happy! I can get wheels, and still save some money by using the stock tires. :D
  8. Nov 8, 2017 at 9:29 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon! I'm not much help with the tire thing... plenty of help here though...
    Scion[OP] likes this.
  9. Nov 8, 2017 at 9:31 PM
    Scion
    Very true!
  10. Nov 8, 2017 at 9:43 PM
    ChristianEKR
    Question- would the 25mm offset require modification? If no, I’m all in on them rims too. They’re the snizz
  11. Nov 8, 2017 at 9:53 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    25mm is a sweet spot offset for our trucks. I'm at +28 w/ 34.5" tires. The truck will look much better with a +25 than with the stock +60
  12. Nov 9, 2017 at 7:48 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  13. Nov 9, 2017 at 8:32 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I had stock tires on 18x9 for quite a while before upsizing to larger tires. Make sure to post some pictures when you get the wheels. Perhaps this chart will help.
  14. Nov 9, 2017 at 9:39 AM
    para38s
    para38s New Member
    I am actually thinking of doing the same thing. Please post some photos once it's done.
  15. Sep 2, 2019 at 4:57 PM
    quietflight72
    quietflight72 New Member
    Rob
    Auburndale Fl
    2019 Tundra SR5
    Did you ever use your stock tires on new wheels? If so, could you show me?
