Can I tow 31ft camp trailer w/ platinum?
Discussion in 'Towing & Hauling' started by mixnchris20, Jan 21, 2019.
  1. Jan 21, 2019 at 8:38 PM
    mixnchris20
    mixnchris20 [OP] New Member
    2017 Toyota Tundra Platinum silver
    3 inch lift
    Hey guys, I am looking at a 31ft atlas camp trailer. Dry weight 7083 and truck is rated for 8800.
    From what I have read, getting a super spring, and anti sway hitch should get me there but wanting to know if anyone has experience. Also curious about mirror options?
  2. Jan 21, 2019 at 9:16 PM
    Welcome Chris, from CO.
    There are so many threads on this topic. Check out our towing section. Just this weekend I did a couple detailed replies with weight ratings, etc.
    Sunnier, jeremyd, Lake.Life24 and 2 others like this.
  3. Jan 21, 2019 at 9:20 PM
    Welcome from NY.
    I pull a 20' open car trailer and the weight is about 4,600 pounds. I don't even feel it behind me. Your pulling about 2,400 pounds more, I don't see a problem. Just remember you are close and that's not counting passengers, luggage and other things.
    I'm sure the real pro's will chime in.
  4. Jan 22, 2019 at 4:17 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    You need to know your TW and then your payload as well before you can calculate if your able to pull the trailer safely. Colorado tj had a great response in another thread about this helping the lady figure it out.
  5. Jan 22, 2019 at 4:18 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
  6. Jan 22, 2019 at 4:31 AM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Welcome!
    My opinion is that is way too much trailer for a Tundra. Yeah, it will move it. Might not even be overweight. But if you are gonna be making frequent trips with it and your family in the truck, no way. I wouldn’t want to do that in any half ton.
    The low payload rating of the Tundra is what will get you.
  7. Jan 22, 2019 at 5:44 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Calculate the load using GCWR. I’ll bet you that trailer will put you over the limit
  8. Jan 22, 2019 at 5:59 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Dry weight is meaningless. You need to know the weight when it’s loaded with water, gear, propane etc. That stuff could easily add up to close to 800-900 lbs. more. Just the water tank in my TT weighs 250#
  9. Jan 22, 2019 at 6:07 AM
    15whtrd
    15whtrd Mr. Blonde
    The rule that I have set for myself has been, I don’t want a trailer heavier than the truck I’m towing it with. Especially in a half ton form. Not because you can’t tow it, but because I don’t want what I’m hauling pushing me around. So all the trailers I look at I shoot for 4 to 6000 pounds give or take.
    OR18TRD, Markman and jeremyd like this.
  10. Jan 22, 2019 at 6:18 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Everyone is aware of SAE j2807 and the required tests? Right?
    The Tundra was the first 1/2 ton to use the standard. The Tundra is rated to tow what the OP is asking and still have reserve in gcvwr.
    I have more of an issue with people in 3/4-1 tons towing at 75-80 mph, than a person towing at 80-90% of capacity.
    koditten likes this.
  11. Jan 22, 2019 at 6:26 AM
    gladecreekwy
    J
    Jackson Wyoming
    Don’t know how you can say that without knowing the true weight of that trailer. He gave the dry weight which really means nothing.
  12. Feb 6, 2019 at 6:56 PM
    Wbaird1984
    Wbaird1984 New Member
    Wendell
    2013 Toyota tundra 4x4 cm
    Stock
    2013 Toyota tundra 4x4 cm weight distribution and sway bar vs 2019 prowler 30lx coming in at 33ft and 11in rounded up to 34 basically. Trailer weighs in close to 6800lbs, and pulls it like a champ.
  13. Feb 6, 2019 at 7:03 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    5-6 mpg is coming your way.
    Coolhardy likes this.
  14. Feb 6, 2019 at 7:04 PM
    Wbaird1984
    Wendell
    Stock
    Actually was pulling in close to 9! The weight distribution hitch and sway bar makes a heck of a difference.
    BTBAKER likes this.
  15. Feb 6, 2019 at 7:07 PM
    koditten
    Kirk
    Midland of the Mitten
    I get 9 dragging an 8k 5th wheel. The truck loves 4th gear at 65mph.
    Wbaird1984 likes this.
  16. Feb 6, 2019 at 7:11 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    20180725_133408.jpg 20180725_133420.jpg I pull a 35.6 foot 2019 coachmen catalina weight 7700 lbs. 8000 with family stuff
    5.7 v8
    410 rear end
    Slotted drilled rotors
    Heavy duty breaks
    Cold air Intake (no improvement in power)
    And use a sway hitch tows fine
    400 miles round trip no issues did it all summer long every other week truck says it rated for 9800 towing With family of 4 and a dog. Plus stuff in the bed. I keep the speed to about 60 -65
  17. Feb 6, 2019 at 7:17 PM
    Wbaird1984
    Wendell
    Stock
    Sounds great, I was thinking about the 5th wheel but didn't trust the short bed and the 5th wheel hitch system they have for the short beds. Good towing fellas
  18. Feb 6, 2019 at 8:55 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    @ColoradoTJ This board is wearing you out bro ! But it's still nice to help people.
