Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. May 30, 2020 at 9:25 AM
    #241
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    F15FBD6E-2977-4877-BA56-AF36501BE4E2.jpg 4EFC1071-24AC-486B-A9F9-6C0BB295C02A.jpg I just put these on today. I swapped out my 20” stock wheels for 18” TRD with Falken wildpeaks 275/70R18LT. There was rubbing at full turn on the skid plate. I have Bilstein 5110 on the middle setting with original springs. My tire shop bent the plate up in about ten minutes. It’s all good now. I haven’t really hit the road with them yet but I will let you guys know how they ride.
  2. May 30, 2020 at 12:19 PM
    #242
    TundraLLama
    Massachusetts
    I had the same exact problem. Did you use your original springs over again?
  3. May 30, 2020 at 9:52 PM
    #243
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    B075DA75-B470-4275-9B12-97359BF020B5.jpg C1155282-96B7-41A4-AA1C-01AD1B46F44C.jpg Stock Suspension:( no rubbing,
    275/70/18 KO2’s
  4. May 31, 2020 at 5:33 AM
    #244
    TundraLLama
    Massachusetts
    Here’s a few more. Slight road noise. But I’m coming from a road tire. I like it.
    It reminds me what I spent my money on.386ACF0E-4D55-4F12-BDF9-544E8C9D6EAE.jpg54B3D488-BED9-4F5F-BF40-F101C64E248D.jpg37354F60-15BB-4A5F-A615-BDF5500F5292.jpg600F933B-1CBF-4B76-968F-DCE85A9A3271.jpg
  5. May 31, 2020 at 12:24 PM
    #245
    The_Bob88
    The_Bob88 New Member
    08 Tundra Crewmax
    Yea
  6. May 31, 2020 at 12:42 PM
    #246
    Ilovemytundra38901
    Ilovemytundra38901 New Member
    I have a 2015 trd off-road trim. I'm looking to put either 275/70 r18 nittos or ko2s on mine. Truthfully I've never cared much for the lifted look. Between having a elderly father and use my truck mostly for towing a boat to go fishing. All I truly care about is having good tires for not so well maintained boat landings. With that being said, as far as I know, the only reason you want a lifted or leveled truck is to fit bigger tires and a desired look. Is there any other reason to level my tundra (spacers is what I'd go with currently due to $) seeing as others aren't having rubbing issues?
  7. May 31, 2020 at 12:42 PM
    #247
    Yzed608
    Yzed608 New Member
    Wisconsin
    If these are +25 offset this tells me the stock TRD +60 wheels and 1.25" spacers would fit on stock TRD suspension (+25 to +60 is 1.38" difference). Did you do any major trimming?
  8. Jun 1, 2020 at 5:28 AM
    #248
    Yzed608
    Yzed608 New Member
    Wisconsin
    So I didn't realize the SCS wheels were 9" and the stocks are 8".
    275/65/18, 8" +60 vs. 275/70/18, 9" +25. Mainly for my own informational purposes ;).
  9. Sep 18, 2020 at 8:27 AM
    #249
    Knollie81
    Knollie81 New Member
    2014 Silver Tundra DC SR5 4x4 (Stock)
    Some great looking trucks and pics. Thanks everyone for sharing...its really helpful. Still a little confused though...will 275/70r18 Cooper Discoverer XLTs rub or not rub on a stock 2014 Tundra DC 4x4 SR5? I'm looking at these tires as a change up from Michelin 275/65r18 LTX M/S2s and I thought they'd work fine as it only would be about a 1" difference in height of the tire. However, after reading a few of the posts in this thread I'm not really convinced it'll work and am trying to avoid going down the rabbit hole of $$$$ to install lifts, spacers, etc. to make it work.
    Thoughts appreciated!
  10. Sep 18, 2020 at 9:28 AM
    #250
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Will work if no other modifications such as lift or aftermarket rims. A lift actually caused mine to rub on the factory skid. Just bent it in with a mallet.
    Knollie81 likes this.
  11. Sep 18, 2020 at 9:44 AM
    #251
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    275/70-18 fit perfect all stock- stock suspension and rims. Here are a couple pics of mine with that size.
  12. Sep 18, 2020 at 10:26 AM
    #252
    Knollie81
    Looks great! Since you appear to have TRD options, any idea if itll be compatible with SR5? I'm still not smart enough on how all the trucks differ as far as options, etc but I love that stock look you have. Same thing I'm shooting for.
  13. Sep 18, 2020 at 10:35 AM
    #253
    frichco228
    My truck is a SR5 with the TRD Off road package, SR5 upgrade package, convenience package. But yes, you will have no issue running 275/70-18 on any stock 3rd gen Tundra regardless of trim level with stock 18 inch wheels. That size also works with aftermarket wheels, as long as the offsets are not too extreme.
  14. Sep 19, 2020 at 5:19 AM
    #254
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Yeah I dont think the off road pkg changes size of anything on the sr5 as far as what you're doing. Different shocks and rims but I believe same specs as far as lift, rim size, offset etc. The Trd pro does have differences w front being lifted more.
  15. Sep 19, 2020 at 5:52 AM
    #255
    VENUSDOOM
    VENUSDOOM New Member
    2020 Tundra SR5 SX
    I have a 3"/2" readylift and have 275/70/18 tires on my stock wheels. The Kenda tires specs are a tad bigger in overall diameter than the traditional math says. I could fit larger tires but the problem is I couldn't fit in the garage. Still love the truck and the way it looks though.
    316KS_Runner and jewsNbrews like this.
  16. Sep 21, 2020 at 9:01 AM
    #256
    Knollie81
    Pulled trigger and ordered the 275/70r18 Cooper Discoverer XLTs this morning through Discount Tire. Thanks everyone for the help and fingers crossed just to be sure there will be no rubbing. Either way, I will report back with pics and a follow up.
  17. Sep 21, 2020 at 9:14 AM
    #257
    18" TRD Off Road Wheels
    Lifting and tires are not just for looks, though many install them for that reason alone. In practical terms the bigger tires get you more ground clearance. That's of little use to pavement trucks, but if you deal with deep snow or go into rougher terrain it makes a huge difference.
  18. Sep 21, 2020 at 11:00 AM
    #258
    AZBoatHauler
    So.Arizona
    No lift will prevent the "skid" plate rubbing people experience going to a bigger tire. That is a product of wheel offset (lateral clearance) not ride height. Easiest way to address it is to bend or trim the plate. Took about 30 seconds with a jigsaw to do both sides on mine.
    pro2amendment likes this.
  19. Feb 24, 2021 at 8:03 AM
    #259
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Update from OP here. I've got pictures buried in here of my 2017 stock wheels and suspension on 275/70r18 Ridge Grapplers that did not rub. I have since sold that truck for a 2020 and did 6112's at 1.9" running the same size in Trail Grapplers and again no rub.
  20. Feb 24, 2021 at 8:18 AM
    #260
    AZBoatHauler
    So.Arizona
    How’s the road noise with the new tires? Trying to decide if I want another set of Ridge Grapplers or try something else. Thanks.
  21. Feb 24, 2021 at 8:50 AM
    #261
    Rngr188
    Chad
    Harrison AR
    @AZBoatHauler I've got about 22k on them now. Compared to my previous Ridge Grapplers yes they are louder but not horrible, I can't here them over the radio at a decent volume and most of the time can't here them over my 8" BAmuffler. They are loudest on fresh pavement. Honestly though I enjoy the sound of a mud tire. This things grip and I love them. When they wear out I'll probably get another set if I don't get Toyo AT3 which we have on our 4runner and I'm very impressed with them.
    AZBoatHauler likes this.
  22. Mar 23, 2021 at 2:06 PM
    #262
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    Had a set of Michelin LTX A/T2, 275/70/18 installed today. Similar tire to what came original on the truck. Initial impression - it feels familiar with a little more float going on (maybe due to the increased size or tire rating?). I was worried going from a P rated tire to an E rated tire it would ride a lot worse. After 13 miles, it seems to ride pretty nice.
  23. Mar 25, 2021 at 7:40 AM
    #263
    RanchTracker98
    RanchTracker98 New Member
    2018 Cement TRD offroad
    F487B11F-2E63-4D94-9B5A-80C0BEE8CF91.jpg A2633E13-FD04-4A2A-8942-8DFBDF32565B.jpg
    Bilstein 5100 @ middle setting, 275/70 r18 KO2
  24. Mar 28, 2021 at 1:00 PM
    #264
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Anybody have pictures in this size of Micky Thompson ATZ P3 or Cooper ST Maxx? I’m trying to decide between either of those or Duratracs.
  25. Mar 28, 2021 at 1:24 PM
    #265
    Candella66
    Candella66 New Member
    2016 sr5 crewmax
    Seats , 20 inch rims, Qi charger, remote starter,katskinz seats, extang bed cover, pop’n’lock tailgate, color matched honeycomb grill and hood bulge,
    64D2E3EF-78EF-4908-83BB-35D214C38E4A.jpg These are p275 65r 18. I swapped out for 20’s. 86CDBD0D-47E6-427C-BD75-0280091BFA3B.jpg 86CDBD0D-47E6-427C-BD75-0280091BFA3B.jpg
    Tundra14Platinum likes this.
  26. Jun 7, 2021 at 7:44 PM
    #266
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Bump for more pics!!
  27. Jun 7, 2021 at 9:35 PM
    #267
    Franco4x4
    Franco4x4 New Member
    2019 tundra CM
    Are you on stock suspension? Any rub?
  28. Jun 7, 2021 at 9:43 PM
    #268
    Franco4x4
    2019 tundra CM
    Is that a 25 offset? Any rub?
  29. Jun 8, 2021 at 5:19 PM
    #269
    frichco228
    I had previously posted a picture of my 275/70 Cooper XLTs. They had factory defects and had to be replace. Went with Wildpeaks this time, same size but they are visibly larger than the XLTs!
  30. Jun 8, 2021 at 6:15 PM
    #270
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
