Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. Aug 14, 2018 at 5:23 AM
    #61
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Same here with 275/70 Ridge Graps.
  2. Aug 14, 2018 at 6:46 AM
    #62
    Twinky
    07 double cab work horse
    I am a tad confused now. I have 295/70 R18 nitto terra's and i didnt see anything visually that seemed different from what i thought was stock...
    What would be required to run that set? Bare minimum i guess?
  3. Aug 14, 2018 at 6:51 AM
    #63
    Kilos
    Kilos YotaPro
    Brett
    AZ
    2017 TRD Pro Barcelona Red
    Icon Stage 6 suspension Method NVs matte black w/Toyo Tires 35x12.5s SDHQ Sliders Cab mount chop Precision LED interior lights (6000k) GTR reverse LEDs 20% acrylic tint (heat resistant) Inyati spray in bedliner Black TRD Pro bed inserts Vivid Racing Leather wrapped steering wheel AJT Designs TRD shift knob AJT key fob Morimoto LED fog lights Full JL Audio sound system upgrade Kenwood 995S HU
    Stock wheels, stock TRD Pro suspension, no spacers, etc. Nitto Terra Grapplers.
  4. Aug 14, 2018 at 7:40 AM
    #64
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I have 275/70 R18 KO2s on mine. ADS suspension - about 3.25" up front and 1" in rear. My wheels are +30 offset. That wheel/tire combo fit fine when I was at stock height prior to the lift. tundra.jpg
    Big J and equin like this.
  5. Aug 14, 2018 at 2:48 PM
    #65
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Anyone try this size on stock suspension with Goodyear Duratracs?
  6. Aug 14, 2018 at 6:37 PM
    #66
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Do you have any more pics of your truck, maybe from the front as well? I have a pretty similar setup with a 2” lift, curious how the 3” would look if i don’t bump up to 295’s.
  7. Aug 14, 2018 at 10:10 PM
    #67
    Atomic City Tundra
    Devin
    New Mexico
    I'll see if I can dig some up tomorrow.
  8. Aug 15, 2018 at 9:11 AM
    #68
    Atomic City Tundra
    Devin
    New Mexico
    I don't have any good ones from the front. I attached one more focused on the BHLM I did for the headlights, and another angle of my truck after the lift.
    Big J, equin and parker44[QUOTED] like this.
  9. Aug 18, 2018 at 1:44 PM
    #69
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Anyone got 5100's on middle setting with 275/70/R18? Please post pics.
    Mikekoot likes this.
  10. Aug 18, 2018 at 5:05 PM
    #70
    zeke7681
    zeke7681 New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    20180829_155144.jpg IMG_20180829_174822_104.jpg On Thursday I'll post pics of my 275/70/18 Ridge Grapplers on Black Ray10s. I can't wait to get these stock wheels and tires off.
  11. Oct 23, 2018 at 5:04 PM
    #71
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    Does the middle setting make the truck level?
  12. Oct 27, 2018 at 1:10 PM
    #72
    iamsmokey
    Oahu, HI
    Yes it does.
    Mikekoot[QUOTED] likes this.
  13. Oct 29, 2018 at 12:40 PM
    #73
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Stock suspension with 275/70R18's.
    I'm about to add 5100's, not sure if I'm going top or middle setting yet.
    Big J, Mikekoot and 15whtrd like this.
  14. Oct 30, 2018 at 8:53 AM
    #74
    sonusfaber
    sonusfaber New Member
    2008 Electric Blue 5.7 4Dr
    Thanks for all the replies and pics. Anyone with stock 2nd gen 2WD running LT275/70/R18 tires? I got some Falkens on what appears to be a good deal. Hoping they fit without any rubbing issues. My only real concern is the upper control arm or the spring just under it rubbing against the inner side of the tire. Thanks to all.
  15. Oct 30, 2018 at 8:58 AM
    #75
    15whtrd
    15whtrd Mr. Blonde
    It won’t rub the UCA or the spring. Those tires are the same width as the stock size.
  16. Oct 30, 2018 at 9:04 AM
    #76
    sonusfaber
    Hey 15, thank you for the reply. I am going to run it in the calc, but just going off the basics...my 2nd gen comes with P255/70/R18 tires. Just using falcons own specs that tire is 10.2 inches. The spec on the LT275/70/R18 tire is 11.3. So that puts us at .5 inches wide on either side. That seems like almost nothing. The tire would have to be much taller to hit the UCA i would think (because the tire starts curving in as it goes up). So my only real concern is the spring.
    As as exercise in though...let's say im in mid mount and they are going to rub...where would i shop to get a spacer on very short notice? There is a 4 x 4 shop in town here...Chattanooga, TN. Any other places that would have something that quick just .5 inch or so? Thanks again...I appreciate your reply.
  17. Oct 30, 2018 at 9:12 AM
    #77
    15whtrd
    15whtrd Mr. Blonde
    You shouldn’t need a spacer. The size I posted in the tire calculator is my stock tire size and the larger one you were thinking about. Both of our trucks came with the same (for the most part) suspension. Same ride height etc.
    I’m going to assume you’re wheels have a +60 offset the same as mine. If anything I would be more concerned with the tire rubbing the top of the wheel well during compression. But I think many have fit this size tire on their stock trucks. If anything let the tire shop try them on and you could check the clearances for yourself. Then make a decision based off of that. I think there are also quite a few that fit the 295 70 18 on stock wheels without hitting the UCA. Obviously these folks have a lift but that doesn’t change the clearances on the control arms or spring.
  18. Oct 30, 2018 at 11:11 AM
    #78
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    275 70/R18 Nitto Ridge Grapplers on Fuel Trophy +20 Offset. Bilstein 6112s on the middle setting, 5160s in the rear at stock height. Sits about dead level. Had a little rubbing in reverse at full lock - front flaps removed and used a heat gun to massage the plastic away from the tires. No UCA rub or other mods to the suspension since it sits at the 'magic height" of below 3". No diff drop or skid plate spacers needed. Very happy with the ride.
  19. Nov 1, 2018 at 8:38 PM
    #79
    sonusfaber
    Thanks again 15...and you were right. I got the LT 275/70/R18 in and they fit without any clearance issue. I have attached pics, hoping they upload without an issue. If so I will re-upload.
    Edit to add though...my plastic wheel center caps burst on contact. I was in the shop. Took nothing for them to shatter. I will have to hit up ebay or something to get them replaced.
    #79
    Mikekoot and 15whtrd[QUOTED] like this.
  20. Nov 2, 2018 at 9:28 AM
    #80
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Ridge Grapplers 275/70 with 1.5” front lift. Had them on stock and work perfect.
    EFB969BC-3154-469D-A963-FB2BDEBE3BBE.jpg 306C941C-930E-48C7-9C64-24F81D2F74BD.jpg
  21. Nov 2, 2018 at 10:11 AM
    #81
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    Not the greatest angle. But Falken Wildpeak A/T. Probably won’t buy again due to the weight of them but they perform well.
    silverstreak16, Rica25 and Chucho like this.
  22. Nov 2, 2018 at 10:31 AM
    #82
    sonusfaber
    Thanks for the input...What about the weight is the turn off? I just got these on my 5.7. Most tires are going to be around the same 60-70 at that size I would think.
    Rica25 likes this.
  23. Nov 2, 2018 at 10:33 AM
    #83
    DecalsByDesign
    Eagle, CO
    It seemed that as soon as I switched from the stock Michelin’s to these my mileage went down 3mpg.... that’s quite a bit.
    Rica25 likes this.
  24. Nov 2, 2018 at 10:36 AM
    #84
    DecalsByDesign
    Eagle, CO
    @sonusfaber discount tire says 61 for falken and 53 for Nitto Terragrappler G2. That’s 32 pounds which doesn’t seem like much but I imagine it could play a pretty big difference. BUT the falkens were so cheap. After selling stock tires and rebates they came out to 500$ :rofl::rofl:
    OR18TRD likes this.
  25. Nov 2, 2018 at 11:01 AM
    #85
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    275/70R18 KO2s. Trd off road with the TRD PRO suspension. No shims or spacers added.
    CC193F54-26C7-41D8-8E72-54996C9320A8.jpg 660F05D4-B85A-42EE-AB1B-CAF59CFAF5BE.jpg 8129F6F6-E338-440E-8ED0-0703E741F449.jpg 04B275A7-9D97-44D2-A260-D34AB50705C0.jpg 24AA3217-CE12-4E6A-A4A6-75F792CAAFDD.jpg
  26. Nov 7, 2018 at 9:40 AM
    #86
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    2016 SR5 offroad, stock
  27. Nov 7, 2018 at 9:56 AM
    #87
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Are there any tires in this size or 285/65r18 with a standard load rating? Everything I've seen has an E1 load rating, which obviously is why these are all so freaking heavy. I want to bump up a size but also don't want to take a huge MPG hit just because they're so heavy.
    15whtrd likes this.
  28. Nov 7, 2018 at 10:02 AM
    #88
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    Trimming?
  29. Nov 7, 2018 at 10:19 AM
    #89
    Mikekoot
    Mikekoot New Member
    Canadia
  30. Nov 7, 2018 at 10:38 AM
    #90
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    Bone stock with 275/70/18 KO2. Zero issues.5C3A4AE6-D690-461B-B22A-16DA6656D572.jpg
