Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. Jan 6, 2023 at 8:20 PM
    #391
    Yoda-Tundra
    Yoda-Tundra New Member
    Justin
    2018 Tundra Limited
    This is the stance and look I want. Nice truck!
    g6t9ed[QUOTED] likes this.
  2. Jan 6, 2023 at 10:04 PM
    #392
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Thanks! I do admit it's on a 2" leveling kit and I want to move to a suspension setup that'll give it a better ride. I've also debated on whether I want to go a size higher, 285/70, to fill in the wheel wells some more. Just hoping it won't rub too badly.
    Yoda-Tundra[QUOTED] likes this.
  3. Jan 7, 2023 at 3:40 AM
    #393
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    since I don’t know how lifted my front end is I’m nervous this size is too small. Luckily I work in parts and will be rolling a tire out to my truck before I buy them. I’m curious how the diameter will compare to the 305/55r20s currently on my truck.
  4. Jan 7, 2023 at 5:09 AM
    #394
    PermaFrostTRD
    Northern NY
    Save your back:
    https://www.tacomaworld.com/tirecalc?tires=305-55r20-275-70r18
    looks to be a .05” diameter difference towards smaller. However on an 18” wheel you get more sidewall “meat” and the optical illusion could make the tire look bigger/better on a lifted truck.
    Yoda-Tundra[QUOTED] and g6t9ed like this.
  5. Jan 7, 2023 at 5:19 AM
    #395
    bflooks
    bflooks New Member
    Metrowest MA
    2.5-3.0" of lift you'll be fine with stock uppers. Of course, that's assuming you're doing a more mild type of lift. If going higher end and are chasing performance, what's another $700 in the journey?
    Get your camber and toe checked on the alignment for that outer wear. As close 0.0 to 0.1 for camber and .12 per side for toe will likely stop it.
  6. Jan 7, 2023 at 7:09 AM
    #396
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    Thanks for the link. I’m good with the current diameter so that’s good. Hopefully the handling will improve with the lower weight and narrower width.
  7. Jan 7, 2023 at 7:12 AM
    #397
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    Thanks. I wish I knew how much lift it had.
  8. Jan 7, 2023 at 7:37 AM
    #398
    PermaFrostTRD
    Northern NY
    Those look like 5100s. So definitely not more than 3” unless there’s some hodgepodge spacer block on top of the coil (doesn’t appear to be in that image).
    5100s have notches where ride height/preload can be changed .75”-3” I believe are the limits. 3 or 4 settings.
  9. Jan 7, 2023 at 9:31 AM
    #399
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    Yes they are 5100s and they have a rusty shim that is 3/4 to an inch thick. Should my upper CA be this low weighted?
    PermaFrostTRD[QUOTED] likes this.
  10. Jan 7, 2023 at 10:12 AM
    #400
    PermaFrostTRD
    Northern NY
    UCA appears to be at its limit or very close to it. Someone with WAAAY more suspension knowledge than me can chime in though.
    jack it up and see how much droop you get. Should be substantial (I don’t have a number, but again *that guy* can chime in).
    Lots of people get away with OEM UCAs on 3-3.5” lift and go camping, and hit those kinds of trails and are fine. I wouldn’t take it to Moab but depends on your usage and if you can get and keep the truck aligned it should be ok.
  11. Jan 7, 2023 at 10:18 AM
    #401
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
  12. Jan 7, 2023 at 12:30 PM
    #402
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    Thanks for the reassurance. I come from Jeeps and this is new territory for me. Loving the truck so far.
    ATV25 and PermaFrostTRD[QUOTED] like this.
  13. Jan 7, 2023 at 12:42 PM
    #403
    PermaFrostTRD
    Northern NY
    Enjoy it. They’re great!!
    Yoda-Tundra[QUOTED] and ATV25 like this.
  14. Jan 8, 2023 at 6:01 AM
    #404
    Benjimckray
    Benjimckray New Member
    Not to change subjects completely here but I see a lot of wicked wheel/ tire combos but unless I'm mistaken 275/70R18 max out at 8.5inch wide wheel.. How are all of you with 9 inch wheels finding the wear on your tires? I'd love to get 9 inch wheels but I don't want to kill the lifespan of my sidewall.. I've looked through a lot of different forums but this seems to be the highest concentration on this wheel/ tire setup I've come across.
  15. Jan 10, 2023 at 9:56 AM
    #405
    Gee Dub
    Gee Dub New Member
    AZ
    2018 SR5 4x4
    Discount tire's website says bfg ko2 275/70r18 fit 7-9.5" rims.
    275mm = 10.827", the tread is wider than my 18x9 rim. And the sidewall bulges a little further past the 9" rim.
    I have noticed extra wear on the outside edge of my front tires only. I had an allignment when they were first installed, and then rotated them and got another allignment (it was off) at 2,950 miles after noticing the odd wear. My tires are e load rated and max out at 80psi. BFG says if I set them to 50psi it matches the max load capacity of my truck, so no 'need' to go higher than 50psi load capacity wise. I've been running them at 42psi for daily driving lately, and had them lower at 38psi when i first noticed the outside edge was rounding off. I suspect that if I were to inflate them higher (and get a less comfy ride) the edge of the tread would possibly lift off the ground and/or have less force on it, yielding less wear on the edges. Conversly if I had the same overall height tire at the same psi, but 12.5" wide tire OR same tire on narrower 8.5" rim, I think the face of the tread would be curved a little more, lifting the edge of the sidewall block off the ground more, inducing less wear.
    Not easy to see in picture but the outside edge is starting to look like a used eraser. If you rub your finger perpendicularly over inside edge it feels like a sharper square, kinda like a dull knife.20221206_082013.jpg
    I've checked about 30 trucks with offroad tires in my work parking lot, EVERY truck seems to have this extra wear on the outside edge of front tires. Maybe it's just from going 70mph through a curve on the interstate.
    P.S.Edit: I need to Chalk my tires, never got around to doing that. Would tell me at which psi the outside edge starts to touch the ground. Maybe I have them too low.
  16. Jan 10, 2023 at 10:35 AM
    #406
    bflooks
    bflooks New Member
    Metrowest MA
    @Gee Dub - not sure you aren't seen incorrect camber and tow here vs pressure. If they didn't set the camber at 0.0 or 0.1, then you'll be experiencing what every Tundra does from the factory. You can search for alignment specs and you'll find a lot about it.
    The chalk test is easy enough to do if you have a straight flat area, but 38 seems low to me for an E tire. This said, I've been wrong before, so YMMV
  17. Jan 10, 2023 at 4:36 PM
    #407
    Gee Dub
    Gee Dub New Member
    AZ
    2018 SR5 4x4
    My initial allignment @Zero miles and 38psi cold, no extra weight, was 0.0 left, 0.1 right.
    Edit for ref: as low as 35 psi on my specific tire is still greater load capacity than I need for daily driving safely.
    2,950 miles later I increased to 42psi cold, rotated and second allignment was 0.2 left, 0.1 right.
    Today I'm a couple hundred miles shy of 5k more miles on this configuration, the front tire's outside edge seem to have about the same amount of rounding that my rears got when they were on the front first.
  18. Jan 14, 2023 at 8:18 AM
    #408
    ajs4
    ajs4 New Member
    AJ
    2018 CM TRD 2WD LMTD
    @Gee Dub i have the exact same tires. Also noticed that slight wear on the outer edge- I think it is from turning/cornering and am not too worried about it.
    Also FYI- I finally chalk tested mine out this AM (had them for 4k miles) and 37/38 psi warm (so 35ish cold) resulted in even pressure across the width of the tread. I have a 2018 2wd crew max- the only extra weight is about 100 from my step rails and 150lbs of sand bags in the back to reduce the bed bounce.
    Gee Dub[QUOTED] likes this.
  19. Jan 15, 2023 at 6:50 AM
    #409
    Gee Dub
    Gee Dub New Member
    AZ
    2018 SR5 4x4
    @ajs4 I've been measuring psi 'cold', before the sun touches a tire. I noticed having more overall rubber/surface area than stock tires, the psi fluctuates more with heat.
    I was chalking my tires yesterday until it rained me out, im at about 5,100 miles since new and gonna rotate/oil change soon. I found my fronts at 71 psi 'warm' were chalking nicely, all of the water siping was contacting the road at least, but a little too high still as the inside edge wasnt all the way down yet.
    My rears at 64 psi were much more overinflated relative to the fronts and I stopped due to rain.
    One very interesting thing; at 38 psi these were relatively squishy and comfy. I had set them to 56 psi cold the other day and they rode much more harshly, like I felt every crack in the road. Then surprisingly at 70psi (cold) they feel better in some regards, but not as comfy when set down in the 30 psi range... rears still too high at 64psi though.
  20. Jan 26, 2023 at 5:21 PM
    #410
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    Finally got the look I was going for. 275/70R18 Goodyear Duratrac on TRD Clone wheels. I would have preferred a a slightly wider offset wheel but couldn’t find an aftermarket wheel I liked. Kept going back to the TRD wheels.
    Tundramafia, WVI, g6t9ed and 3 others like this.
  21. Jan 26, 2023 at 5:23 PM
    #411
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    No more tire poke
  22. Jan 26, 2023 at 5:30 PM
    #412
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Nice. I love duratracs. Looks like you have some lift. What set up do you have?
  23. Jan 26, 2023 at 6:27 PM
    #413
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    Thanks. I wish I could ask the previous owner but it would be against my company’s policy to reach out since I bought it from our wholesale lot. I would love to know all the things he’s done. It has 5110s and shimmed struts. Shackles in the rear. BMC. My guess is 2.5 front and 1 in the rear.
    pro2amendment[QUOTED] and g6t9ed like this.
  24. Mar 8, 2023 at 4:57 PM
    #414
    TP4Sale
    TP4Sale New Member
    Nick
    Grand Junction CO
    2019 White Tundra SR5
    59561D57-9D93-4C6C-9F6C-03C176E0F6AA.jpg 1FEA67E3-0642-4B51-922E-90E05E608DC2.jpg 275/70/r18 KO2 with the SCS F5 uhh just the perfect combo. Just removed the front air dam and no rubbing and I tried (see above). I’ll have to weight them but from the stock steelies and ht don’t think I gained that much per corner.
  25. Mar 8, 2023 at 5:09 PM
    #415
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    275/70r18 Kenda Klever RT
    2” Spacer lift up front and RAS in the rear. Still has a little rake which I like.
    LS3, PermaFrostTRD, JeremyTRD and 2 others like this.
  26. Mar 15, 2023 at 4:06 PM
    #416
    Gobstopper
    Gobstopper New Member
    275/70’s really are the perfect size for these trucks, I miss mine. Went with 285/75/17’s when mine wore out on some Methods. A bit too big and too much offset for me, also doesn’t fit in my garage!
    Gee Dub and ATV25 like this.
  27. Mar 16, 2023 at 4:32 PM
    #417
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    New KO2's, 275 70 18's
    pro2amendment and Gee Dub like this.
  28. Mar 16, 2023 at 6:25 PM
    #418
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Stock shackles?
  29. Mar 17, 2023 at 5:10 AM
    #419
    Eborseti22
    Evan
    Yea stock shackles. I did have the CB 1" Shackles for the rear in hand at one point, but I opted for the RAS for towing and hauling.
  30. Mar 17, 2023 at 6:30 AM
    #420
    MadMaxCanon
    The +1 don't even work with ras, found out the hard way.
