Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. May 11, 2022 at 1:06 PM
    #361
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Nice! I run the same, Eibach 2.0, RAS in the rear, so 2/1 lift with 275/70s 2-1 lift and 27570s-2.jpg and
  2. Jul 5, 2022 at 9:45 AM
    #362
    frichco228
    Can someone with +18 offset wheels, can you post some pics, normal side and them some of the poke please.
  3. Jul 9, 2022 at 9:56 PM
    #363
    Gee Dub
    Gee Dub New Member
    AZ
    2018 SR5 4x4
    BFG KO2 275/70r18, @40psi
    Method 705, 18x9, +25mm, 6.00" backspacing.
    2018 SR5 4x4 stock suspension w/34k miles.
    Rubs mud flap in reverse at full lock.
    Shiny mark where it kisses the front mud flap.
    These inch taller E loads are squishier than my stock 255/70r18 D loads.
    Speedo matchs GPS perfectly now
    Dr.Nut and jewsNbrews like this.
  4. Sep 4, 2022 at 5:02 PM
    #364
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Cooper Discoverer ATP II. Truck is leveled.
  5. Sep 22, 2022 at 8:09 PM
    #365
    ajs4
    ajs4 New Member
    AJ
    2018 CM TRD 2WD LMTD
    2FD2A909-BA50-443A-B428-3228F1399A8F.jpg 275/70/18 KO2s on 2018 with stock TRD wheels and stock ride height. Small hit to gas mileage :)notsure:)- I still fill it up every 2 weeks. No rubbin, plenty of room. A little bouncy @ 40 PSI but I rode the stock Michelins at 35 because 30/33 was too soft and marshmellowy in corners and there’s not much difference in stiffness/bounce (I also always keep about 250 lbs in the bed which greatly reduces backend bounce/jitter IMO). Visually these look literally 2x better than the stock 275/65/18 Michelin LTX AT2s.
    BJBlixt, St2946, frichco228 and 3 others like this.
  6. Sep 22, 2022 at 11:31 PM
    #366
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Idk if I shared this here previously but just in case.... 20210904_114854.jpg 20210904_103812.jpg
    0600, huntsonora, KNABORES and 6 others like this.
  7. Sep 23, 2022 at 12:16 AM
    #367
    18" TRD Off Road Wheels
    And what lift are you running that makes those 275s look small? Need the context to make the pics have value.
  8. Dec 7, 2022 at 8:58 AM
    #368
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    Bought AT3W's last nite. Stock, no level/lift yet. I'll check to see if/where it rubs later today.
    Before (LTX's):
    After:
    Flying Tundra!
  9. Dec 7, 2022 at 9:05 AM
    #369
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    TRD Pro wheels and suspension. Falken Wildpeak AT3W 275/70R18
    Gee Dub and jewsNbrews like this.
  10. Dec 7, 2022 at 9:20 AM
    #370
    frichco228
    You should not have any rubbing with 275/70s and stock suspension with stock wheels. Plenty of clearance for those. 285/70s fit stock as well.
  11. Dec 7, 2022 at 11:46 AM
    #371
    BPKlein
    BPKlein New Member
    2021 SR5 TRD OR Cavalry Blue CM
    275/70-18 General Grabber ATx (SL 4 ply)
    SCS 18x9 +25offset
    Front tires rubbed the back mud flap ever so slightly at full wheel lock.
    B5100 middle setting front / B4600 rear
    1ish MPG loss on the highway
  12. Dec 7, 2022 at 11:48 AM
    #372
    dherring256
    2018 MGM SR5
    Fuzzy Dice
    Wanted to add: I get damn good MPG with this setup, at ~70mph.
  13. Dec 8, 2022 at 4:03 PM
    #373
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Don't have any pics yet, but had Cooper Rugged Trucks LT275/70R18 put on my Tundra last night. I hadn't seen them in anything other than pictures on the internet. They are way more aggressive looking in person and quite a bit bigger than the Cooper ATP II I saw in the tire shop parking lot on another Tundra in the same size. The power loss was immediately noticeable as well much more bumpy ride on concrete roads at 30-40MPH. I low hum typical of AT tires but at 65-70MPH they are pretty annoying. Haven't hit the interstate yet to see how loud they are at 75-80MPH but I doubt they'll be quieter. Tundra was hunting for the right gear on a stretch of highway going up a hill where it never has before. They look pretty cool, but I'll probably see if the shop will swap these out for something shorter and lighter.
    Kwe1982, pro2amendment and jewsNbrews like this.
  14. Dec 13, 2022 at 6:58 AM
    #374
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Either the truck is learning the new tires or I'm getting used to the power loss, but it doesn't seem as bad with 200 miles on them now. Still noticeable from a dead stop but not the dead pedal feel like it had the first few days. They're also now pretty quiet up to about 50mph o_O
    Kwe1982, JeremyTRD and jewsNbrews like this.
  15. Dec 14, 2022 at 8:10 PM
    #375
    tundraowner1
    tundraowner1 New Member
    I have a 2016 Platinum 4x4 tundra Crew Cab stock tires, 275/55R20. I am planning to install the General Grabber. Can you please guide me what tire size Ill need to go with? Do I need to change the wheel? or do I need to make a change to the height etc? doesnt this tire rub on the sides on is too wide?
    thanks!
  16. Dec 14, 2022 at 10:11 PM
    #376
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    i would take a good look at 275/60/20 if you want some more fill but not lift the truck.
  17. Dec 14, 2022 at 11:43 PM
    #377
    tundraowner1
    I am looking for General grabber atx for my truck. I do see the 275/55R20 available in its size but their website somehow says it isnt a fit for tundra 2016.
  18. Dec 15, 2022 at 8:51 AM
    frichco228
    Dont worry about that, it is because that size tire is larger than what came on the truck stock. Tundras can fit 34 tall, 11ish wide tires, no lift with stock wheels so you are good.
    tundraowner1[QUOTED] and Hbjeff like this.
  19. Dec 15, 2022 at 5:18 PM
    #379
    tundraowner1
    Thank you. I just found 275/55/r20 General grabber ATX. Once I have those installed will share the pics. Thanks again!
  20. Dec 15, 2022 at 5:25 PM
    #380
    tundraowner1
    Whats the back cover called? How much does it cost?
    Thanks!
  21. Dec 19, 2022 at 5:38 PM
    #381
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    275/70r18 Baja Boss AT’s, stock suspension no rub
  22. Dec 24, 2022 at 11:57 AM
    #382
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Have you driven in any snow yet with those? Looks great
  23. Dec 24, 2022 at 12:23 PM
    #383
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    It’s my dads truck, yes he has and says the tires work well.
  24. Dec 24, 2022 at 6:29 PM
    #384
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    I put some snow claws 275 70 18’s on my 07 tundra, they look way better than the 275 65 18’s stock tires. I’ll be looking to get the copper rugged treks for my summer tires, anyone got pics of them on your truck.
    mine has bilsteins on the second notch and a little bit of air in my rear bags, I’ll take more pics at 5lbs of air pressure to level it out a little more.
    jewsNbrews likes this.
  25. Dec 25, 2022 at 5:11 AM
    #385
    BPKlein
    BPKlein New Member
    About 10 posts up there is a pic of rugged treks.
  26. Dec 28, 2022 at 4:38 PM
    #386
    Dr.Nut
    Dr.Nut New Member
    2011 Tundra CrewMax 5.7L
    Looking great, man! My friend recently acquired this 2018 SR5 4x4 and we'll start modding it next year. He's debating on getting either KO2 or General grabber, and looking at SCS and method wheels! I'll show that setup to him.
    Gee Dub[QUOTED] likes this.
  27. Jan 1, 2023 at 11:28 AM
    #387
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
  28. Jan 6, 2023 at 7:24 PM
    #388
    Yoda-Tundra
    Yoda-Tundra New Member
    Justin
    2018 Tundra Limited
    I’m not crazy about the negative offset 20s on my new-to-me 18 Crewmax. I bought TRD clone wheels and want to run 275/70R18 ATs.
    I have a 2.5 or maybe 3in lift in the front. The current tires are wearing on the outer tread pretty bad. Do you think I will need upper control arms to correct the alignment or should a shop be able to correct with an alignment?
    I’m wanting this look.
  29. Jan 6, 2023 at 7:41 PM
    #389
    biebs96
    PA
    Where are you located? I know I have seen this truck before.
  30. Jan 6, 2023 at 7:48 PM
    #390
    Yoda-Tundra
    Justin
    2018 Tundra Limited
    Northern Virginia Dulles Area
