Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. Jan 6, 2022 at 9:25 AM
    #331
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Stock wheels +60 offset or aftermarket wheels with less offset?
    AJGallo41 likes this.
  2. Jan 6, 2022 at 9:37 AM
    #332
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Hooked my neighbor up with a Goodyear coupon…here are his LT275/70r18 Duratracs on an otherwise completely stock ‘20 Limited TRD Off Road. He’s had them for a week and no rubbing so far. You can see that he didn’t even have to remove the little mud flaps in front of the front wheels. :headbang:
  3. Jan 6, 2022 at 11:32 PM
    #333
    intoxicatedjedi
    intoxicatedjedi New Member
    2021 Voo Doo Blue Tundra Sport Premium
    3/1 Toytec Lift w/Rear Shackles
    Aftermarket wheels. +18mm offset.
  4. Feb 2, 2022 at 10:06 AM
    #334
    Rebel Toy
    Rebel Toy New Member
    2020 Tundra Limited
    3-1 Low Range lift, Bilstein 5100, 285/70/18 Nitto Ridge Grappler, Fuel Quake Wheels Flowmaster 40 exhaust
    2020-2.jpg275/70/18 BFG K02, fuel Kranks, 3/1 low range lift, no rub, kept mud flaps
  5. Feb 2, 2022 at 10:27 AM
    #335
    sabet
    sabet New Member
    275/70/18 Nitto RG on stock trd offroad suspension. No modification, no rubbing, no flaps to remove, no speedometer to adjust, just perfect!
  6. Feb 6, 2022 at 5:53 AM
    #336
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Maybe a dumb question but is anyone concerned about the speedometer difference going from factory tires to this tire? Did anyone try to correct the speedometer?
    Noticed my trucks onboard speedometer actually reads 1 mph slower than my gps on stock tires already. Strongly considering switching to this tire once my originals need replacing
  7. Feb 6, 2022 at 5:59 AM
    #337
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Not concerned about 1mph personally...
    Clemsonman14 likes this.
  8. Feb 6, 2022 at 6:45 AM
    #338
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    At 65 your adjusted mph is 67.5 so it's not that far off. If you get OCD about this I am sure there are products on the market to allow you to adjust / calibrate your speedo. I can get really picky about some things but this is not one of them.
  9. Feb 6, 2022 at 8:16 AM
    #339
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I plan on going this tire size soon. I noticed that even with factory tires, my speed is a consistent 2 mph slow all the time on the speedometer compared to GPS. With the 275/70s it should be almost perfect without any calibration.
    Gee Dub and Clemsonman14[QUOTED] like this.
  10. Feb 6, 2022 at 8:30 AM
    #340
    Clemsonman14
    That’s what I’m thinking as well. Already looks to be a little off so bigger tires may actually bring it more in line with the actual speed of the truck
    HulkSmurf14 likes this.
  11. Feb 6, 2022 at 9:51 AM
    #341
    MadMaxCanon
    I think the calculator I used shows it will be the closest with this size. Any larger and it would start going the other way. Of course, every truck may be different
    Clemsonman14[QUOTED] likes this.
  12. Feb 21, 2022 at 10:00 AM
    #342
    Cuda021312
    Cuda021312 New Member
    2021 MBM TRD Sport Premium CM
    Awesome looking Tundra!
    Did you experience any rubbing issues on stock height with 275 70 18? The Methods and Ray 10's have the exact same offset but I'm going with KO2's. I don't want any rubbing and or have to trim or remove anything. Would you recommend 275 65 18 instead? Thanks! :thumbsup:
  13. Mar 3, 2022 at 1:36 PM
    #343
    MER
    MER New Member
    18' Limited CM 4x4 Off Road
    Just installed Ray10’s with 275/70/18 Toyo Open Country AT3’s on a 2018 Limited Off-Road with stock suspension. I was rubbing at full lock in reverse on the front mud flaps, so had to remove them. I still like this size tire over the stock 275/65/18.
  14. Mar 3, 2022 at 4:35 PM
    #344
    Cuda021312
    Thank you for the info. So you encountered rubbing issues on the front flaps only? Is there a sufficient amount of clearance everywhere else? If that's the case, I may just remove the front flaps. :thumbsup:
  15. Mar 3, 2022 at 4:57 PM
    #345
    MER
    MER New Member
    yup, i only had rubbing on the front mud flaps.
    Cuda021312[QUOTED] likes this.
  16. Mar 4, 2022 at 3:27 AM
    #346
    Cuda021312
    Thank you! :thumbsup:
  17. Mar 4, 2022 at 4:10 AM
    #347
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Start the video at 7:30
    I did 275/70 and mine rubbed like hell front and rear flaps both. Took a heat gun to the splash guards behind the wheels and was able to get them to barely clear. Had to shim the bumper out to make it stop rubbing. Removing the little aero flaps wasn't enough.
    https://www.youtube.com/watch?v=NIaa-DdjfNk&t=469s
    Tundra14Platinum and Gee Dub like this.
  18. Mar 11, 2022 at 6:56 AM
    #348
    MightyTundraGA
    MightyTundraGA New Member
    Here are the Ray10s on Cooper XLT's - 275/70/18. 1.75 in Rough Country leveling kit on the front. Rear is stock. Only thing they had to remove was the mud flap in front of the front tire.
    ATV25 and jewsNbrews like this.
  19. Mar 15, 2022 at 10:30 AM
    #349
    frichco228
    Here is my 2016 with 275/70-18s and a 2/1 lift. Eibach Pro Truck 2.0 set at 2 inches and RAS HD for an inch in the rear.
  20. Apr 7, 2022 at 7:07 PM
    #350
    2018TundraLimited
    2018TundraLimited New Member
    2018 Silver Tundra Limited TRD
    Looks great! I’m curious how your ride quality is after the suspension upgrades compared to stock? Better, worse or the same?
  21. Apr 7, 2022 at 7:50 PM
    #351
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    275 70 r18 nitto ridge grappler. 5100s middle setting in the front +25 offset. Removed front mud flap no rubbing after that.
  22. Apr 8, 2022 at 6:11 AM
    #352
    frichco228
    They feel similar to the off road package shocks, but better. Handle bumps better, stop the nose dive when braking, handle better. Valving is better than stock, which I think is digressive stock. Great for a daily driver wanting some extra height, easy to live with and a good value performance and cost wise. Certainly un upgrade. Quite happy for what I spent!
  23. Apr 30, 2022 at 6:12 PM
    #353
    splitfuse
    splitfuse Dr. Tundra
    AB-CAN
    2020 Cement Tundra Crew TRD
    275/70R18 BFG KO2s on black powder coated 2020 TRD Off Road wheels. Factory suspension. Zero rub around town, haven’t had it off pavement yet to test at full susp articulation….
  24. May 3, 2022 at 10:28 AM
    #354
    cuaround
    cuaround New Member
    Your truck looks great. I have been going back and forth to level or not level my 21. But after seeing yours, Im probably just going to do the same BFG's and leave the suspension as is. By chance do you have any more pics at different angles?
    splitfuse[QUOTED] likes this.
  25. May 3, 2022 at 8:08 PM
    #355
    splitfuse
    AB-CAN
    Thanks! Here’s a few more angles.
  26. May 3, 2022 at 8:17 PM
    #356
    BamatundraSC
    BamatundraSC New Member
    Greer, SC
    2021 SR5 CM
    TRD Pro grille, color matched hood bulge, TRD Pro headlights, color matched front bumper end caps, Rough Country two inch loaded front struts, Matte black SCS Ray10’s, Cooper Rugged Trek 275/70/18, Rough Country tri fold hard bed cover, Dirty deeds 12” exhaust
    Mine was the same way. I went with 275/70 Cooper Rugged Treks and now my speedo matches GPS
  27. May 3, 2022 at 8:21 PM
    #357
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    275/70 Cooper Rugged Treks on SCS RAY 10’s. 2” Rough Country loaded struts on the front, stock height rear. I had to take off mud flaps to keep from rubbing.9818FFFE-E21B-4DE1-97DA-5FCE36685114.jpg
    frichco228 and jewsNbrews like this.
  28. May 3, 2022 at 11:44 PM
    #358
    MadMaxCanon
    Thx for confirmation. Did u notice any mileage hit?
  29. May 4, 2022 at 4:41 AM
    #359
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    I lost 1 mpg around town. I haven’t taken a road trip with these tires yet so I don’t know how much it will drop on the highway
    MadMaxCanon[QUOTED] likes this.
  30. May 11, 2022 at 11:57 AM
    #360
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    2019 Silver Sky Limited Crewmax
    Diamondback SE RCI skid plate Husky Mats WeatherTech bed-liner SCS Ray10's Eibach Stage 2 coilovers Toyo AT3 275/70/18 RAS HD Tuffy console safe
    SCS Ray10's 275/70/18 Toyo AT3 eibach 2.0 set from eibach installing RAS HD in rear tomorrow
