Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. Oct 3, 2021 at 2:44 PM
    #301
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    What!? Is this the only A/T tire in this size that isn't LT? Been hoping for an SL 275/70/18
  2. Oct 3, 2021 at 2:55 PM
    #302
    gvanburen
    gvanburen New Member
    Sandy, OR
    2021 Limited CM - Army Green
    I don't know if this is the only one, but just happened to come across it while searching. It is a 4-ply, 46lb tire versus the 10-ply, 60lb E load.
    xJuice[QUOTED] likes this.
  3. Oct 6, 2021 at 2:48 PM
    #303
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    How do you like the 6112's compared to stock suspension for on/off road ride and handling.
    Just into a 2021 Sport and although decent in the corners it's a little on the harsher side. I'm looking at options and would be interested in how the Bilstein's compare to Toytech, the Fox Pro offroad, or Elka as I'd be looking at a 2.5 body non resi for the upgrade.
    Had Fox 2.0 on my F150 which were ok and another lower priced option.
  4. Oct 6, 2021 at 4:11 PM
    #304
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I installed the 5100's which is the extra step of disassembly of my original in my garage with a spring compressor. the spring compressor I was a little nervous about but was super easy. A little bit of a pain but I dropped the lower control arm and pulled out that way, was pretty easy
  5. Oct 6, 2021 at 4:23 PM
    #305
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Great tires, no road noise
  6. Oct 6, 2021 at 6:09 PM
    #306
    GatorBodine
    GatorBodine New Member
    I know this is a tire thread, but what did you do to the cover the chrome on the door handles? I need to do something, not ready to spend the coin on replacement handles for the smart key entry feature.
  7. Oct 7, 2021 at 9:12 AM
    #307
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    whats under the cover tho? looks like a Mclaren
    jewsNbrews likes this.
  8. Oct 11, 2021 at 11:03 AM
    #308
    gvanburen
    Sandy, OR
    I also wasn't ready to spend $500+ for color matched smart key handles so I just ended up using plastidip. For the rear door handles, I ended up removing them entirely from the truck to tape and spray. For the front handles, I left the handles on because I didn't want to take apart the door to unplug the smart sensor and just taped and sprayed in place.
  9. Oct 11, 2021 at 12:14 PM
    #309
    GatorBodine
    My reasons exactly, I'm not in the mood to remove the door panels on a brand new truck. I'll probably pastidip the handles but I did consider replacing the rear ones because its easier. But my OCD will get to me knowing the rear replacement won't match the plastidip fronts. How is your plastidip holding up?
    1794TX likes this.
  10. Oct 11, 2021 at 12:28 PM
    #310
    gvanburen
    Sandy, OR
    I actually like how the handles look with the green and matte black plastidip. I only put it on a few weeks ago, but had plastidipped handles on my 4Runner for years and they held up great. For high usage areas, I will usually do a lot of thin coats - it seems to work pretty well.
  11. Oct 12, 2021 at 11:09 AM
    #311
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I had these ST MAXX mounted today...I'm happy when comparing what I had prior!
    Cooper RTX:
    Cooper ST MAXX
    Made the 12" of snow we got less workto drive in!
    WVI and jewsNbrews like this.
  12. Oct 12, 2021 at 11:11 AM
    #312
    GatorBodine
    stock suspension?
  13. Oct 12, 2021 at 11:15 AM
    #313
    HulkSmurf14
    2014 Tundra Limited
    Falcon...I'm up ~1" up front front - you might note a slight slump in the rear...I have 600lbs of tube sand in there and need to click the rear Falcons to level 2 this winter...steroidal traction is key!
    Tundra14Platinum and jewsNbrews like this.
  14. Oct 14, 2021 at 7:36 PM
    #314
    Coloradonative75
    Coloradonative75 New Member
    Dave
    Aurora Colorado
    2020 4x4 limited
    Are-z series topper, bedrug,
    Front 1.9 bilstein 6112. Rear toytech 1.5 shackles. PRO wheels. Just a perfect stance IMHO. Cooper Discoverer AT3 XLT. I'd certainly recommend the Coopers as well. Excellent tire. Fairly aggressive but rides smoothly and quiet. 20210909_151724.jpg
  15. Oct 21, 2021 at 5:17 PM
    #315
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    SO EXCITED!!! I’m having 275/70R18 AT3 XLT’s mounted tomorrow am. $1100 installed, seams reasonable in today’s world. Camping this weekend, but will post picks next week. Stock 2020 SR5, hopefully they don’t rub. I’m also trying to lock down 5100’s set at 2.5" from @kenny1794…fingers crossed.
    jewsNbrews and pro2amendment like this.
  16. Oct 21, 2021 at 5:19 PM
    #316
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    they will not rub with stock wheels and stock suspension. enjoy!
  17. Oct 21, 2021 at 5:36 PM
    #317
    EZDoes It
    Ed
    Thanks for the info. Still looking forward to leveling with the 5100’s. I guess there are worse additions then Tundra mods…right?
  18. Oct 21, 2021 at 7:43 PM
    #318
    TexAirUh
    TexAirUh New Member
    NEPA
    2021 Cement Tundra Limited TRD O/R
    275/70/18 Nitto Ridge Grapplers
    Cuda021312, WVI, EZDoes It and 3 others like this.
  19. Oct 23, 2021 at 8:05 AM
    #319
    EZDoes It
    Ed
    Alright here they are. 275/70R18 XLT’s. Pretty much had them installed and towed to camp. Between the Cooper’s on the truck and the new Endurance on the trailer it tied like a dream. The stock Michelin’s had too soft of a side wall. The Cooper’s ride much softer than I thought they would for 10 plys. Very happy with the set up so far.
  20. Oct 23, 2021 at 8:56 AM
    #320
    Bigstick
    Bigstick New Member
    Cody
    2018 MGM TRD Offroad
    I also just got these tires, they are the stock tires for the new F 150 tremor. They look great and big and yet are like 46 lbs a pop. About 1 mpg hit around town. The other sl looking. Know of is the Grabbber APT, but that tire is mild looking.
  21. Oct 23, 2021 at 9:06 AM
    #321
    EZDoes It
    Ed
    Not sure about around town yet. I was getting about 10 mpg towing now I’m down to 9 mpg on this first trip with them. Well worth the loss for looks and towing benefits, IMO.
  22. Oct 23, 2021 at 9:14 AM
    #322
    Bigstick
    Bigstick New Member
    Cody
  23. Oct 23, 2021 at 1:06 PM
    #323
    Bigstick
    Bigstick New Member
    Cody
  24. Oct 25, 2021 at 7:30 AM
    #324
    VadersTundy
    VadersTundy New Member
    2019 black sr5 crewmax
    What side steps do you have? We tow a grand design camper with our tundra as well!
  25. Oct 25, 2021 at 7:35 AM
    #325
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    275/70-18 Trail Grapplers.4934BC98-EC76-4F3C-B521-C7EEF93A344C.jpg 9D5E023C-F274-4E4F-9707-A8358343F676.jpg
    3Thumbs and Steve18 like this.
  26. Oct 25, 2021 at 7:45 AM
    #326
    EZDoes It
    Ed
    Truck is factory running boards, camper has the fold up as it’s a ‘19. I wasn’t sure WiFi he you were asking about. I like the new style on campers, but didn’t want to wait for a new model. They’re shitting them out so fast right now , I’m not sure if quality is keeping up.
  27. Dec 27, 2021 at 11:00 AM
    #327
    Liv2hunt
    Liv2hunt New Member
    Just put the AT3’s on a few hours ago they are 275 70 r18 it’s a 2020 with the ready lift 3/1.. so far so good
  28. Jan 6, 2022 at 12:25 AM
    #328
    intoxicatedjedi
    intoxicatedjedi New Member
    2021 Voo Doo Blue Tundra Sport Premium
    3/1 Toytec Lift w/Rear Shackles
    Has anyone had rubbing issues with 275/70R18's on a 3/1 lift with adjustable UCAs? The shop that did the install had the right front wheel buried into the front bumper, when I took it back to them to double check the alignment all they did was start trimming. Anyone else have issues like this or is this alignment shop the issue?
  29. Jan 6, 2022 at 3:43 AM
    #329
    Liv2hunt
    Liv2hunt New Member
    I have not had any rubbing issues. I have turned the wheel hard in both directions going up my drive way and down while turning the wheel.. Before I bought the tires my passenger side LCA bolts were loose. I was getting some bad clicking sounds when cutting the wheel while parking. I tightened them. The casters moved my arm moved but my steering wheel straightened out and it drives straight on the highway... That might be it maybe have the casters turned so the wheel is farther out.
  30. Jan 6, 2022 at 4:48 AM
    #330
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    What gear ratio is ur truck? If you have the 4.10 ratio bigger tires will put more of a strain on ur transmission than if you have the 4.30 ratio and you will see a bigger decrease in mpg. You can always put in new gears to fix that though and get 4.88 or 5.29 depending on how big ur tires are and what you do. After i put 35s on my truck my speedometer is now off by 5miles once i go over 45 mph.
