Can I go lower than 2.5/1 level?
Discussion in 'Suspension' started by bvail410, Jul 13, 2015.
  1. Jul 13, 2015 at 9:20 PM
    bvail410
    bvail410 [OP] New Member
    Tundra
    Let's see them!
    I am buying my truck soon. Going to be White Platinum 2014-2016. Anyone know if the 2016 will have push button start?
    Thanks so much in advance as I am shopping my wheel and tire combo now and wish to not lift but would consider leveling kit. Anyone know if I can go any lower than the 2.5/1 level and would it do any good?
  2. Jul 13, 2015 at 9:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You can do just a 1.5"-2" spacer in the front to level it out. Toytec sells one. I also have one up for sale in the marketplace if your interested.
    There are some good links in my sig for wheel and tire setups.
  3. Jul 13, 2015 at 9:33 PM
    bvail410
    Tundra
    A White Platinum? Does this spacer setup do anything to the ride?
  4. Jul 13, 2015 at 9:51 PM
    csuviper
    Broomfield, CO
  5. Jul 13, 2015 at 9:52 PM
    csuviper
    Broomfield, CO
  6. Jul 13, 2015 at 9:59 PM
    csuviper
    Broomfield, CO
    It's a small spacer lift so it is not going to affect the suspension much. Cheap way to level the truck and fit a little bigger tires in the front.
    Had it on my truck when I bought it and had it on for a little while. Road like a stock truck still.
  7. Jul 13, 2015 at 10:00 PM
    bvail410
    Tundra
    Awesome Thanks,
  8. Jul 26, 2015 at 11:05 PM
    Texastrav
    Texastrav New Member
    2015 Tundra limited CM 4x4
    Brand spanking new, need mod ideas!
    I leveled my 2015 tundra with 2" spacers. Anyone know the biggest tire set up I could put on there without rubbing? I'm clueless on tires. I actually like the rims on my limited tundra, to they make aggressive tires to fit that 20" rim? Lol. No one probably does that if they do..what would be a good option to go with?
  9. Jul 27, 2015 at 9:04 AM
    csuviper
    Broomfield, CO
    Your question can be answered by looking at the info in the wheel and tire link in my sig below.
  10. Jul 28, 2015 at 6:45 AM
    Texastrav
    So with just the front lifeted 2" (leveled) , how big of tires can you fit on a 20" rim?
  11. Jul 28, 2015 at 7:59 AM
    csuviper
    Broomfield, CO
    • 20″ rims: 285/60 R20 – 4/10ths wider and 1.5 inches taller than factory.
  12. Jul 28, 2015 at 9:58 AM
    Texastrav
    Nice! Thank you
  13. Oct 17, 2015 at 8:32 PM
    Kelly92127
    Kelly92127 New Member
    Texastrav,
    Did you ever put those 285/60/20's on your Crewmax? I'd like to see pics if you did. And what level did you end up with?
  14. Oct 18, 2015 at 7:50 AM
    Texastrav
    No I haven't kelly, I did find a pic online that shows what it would look like on my platinum stock rims.
  15. Oct 18, 2015 at 7:51 AM
    Texastrav
    That's obviously not a 2014 or 15 though
  16. Oct 18, 2015 at 7:59 AM
    Texastrav
    Here is my truck
  17. Oct 18, 2015 at 8:08 AM
    Kelly92127
    Thanks.. Looks exactly like mine. In the coming weeks I'm going to add a level and 285/60/20's. I'll post pics once I pull the trigger.
  18. Oct 18, 2015 at 8:34 AM
    Texastrav
    awesome, can't wait to see them. Ill probably get min right after you. Mine is leveled but I would like to sit up a bit higher. Idk what kind of tire I'd go with tho. How aggressive??
  19. Oct 19, 2015 at 2:18 PM
    Airbagged
    Airbagged New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    Here is my 2015, I have it lifted about 2.5-3" in the front with fox coil overs and 3/4-1" in the rear using Coachbuilders +1 shackles
  20. Oct 19, 2015 at 2:30 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Leveled in the front no lift in the rear 35x12.5x18" Toyo RT's on Fuel 18x9" with a +20 Offset. I had to remove the front plastic from the front bumper and the front mud flaps. All I have is a very slight rub on the front bumper at full lock in reverse.
    BlkTundra16 likes this.
