Can I disable parking assist and blind spot
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Feb 1, 2018.
  1. Feb 1, 2018 at 12:56 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    would like to disable both systems until I get my bumper replacement, to keep error codes from coming up
    2015 Toyota Tundra 1794 crew max
  2. Feb 1, 2018 at 1:25 PM
    Borgs
    Borgs New Member
    PA
    Can't you just turn them off on the switches on the dash? I think that's what I did when I had my front bumper off and didn't get any warning lights.
  3. Feb 1, 2018 at 1:27 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    You should be able to but I think the blind spot monitor will be back on when you turn off your truck and restart it. That is how my 2018 works, you may want to check your owner's manual.
  4. Feb 1, 2018 at 1:41 PM
    kcaustin66
    kevin
    It will be unplugged from the harness until it is fixed
  5. Feb 2, 2018 at 6:57 AM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Should be no biggie to just turn them off from the buttons on the dash.
  6. Feb 2, 2018 at 7:40 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What bumper are you going with? I've got my parking sensors turned off at the dash right now because I've disconnected the front parking sensors. I Haven't heard of anyone getting the BSM to work with an aftermarket rear bumper but will be attempting it soon.
  7. Feb 2, 2018 at 7:40 AM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    That's how it works on my 2016...dash buttons keep them off until pushed again.
    HUTCHJ[QUOTED] and 831Tun like this.
  8. Feb 2, 2018 at 12:29 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    If I am not mistaking the rear bumper corners are made out of plastic or ABS because the blind spot monitor is mounted behind them. Since aftermarket bumpers are usually made out of metal the only way to get them working would be to make a cut out and mount the sensors in there so they can "read".
    ChucklesToy and 831Tun[QUOTED] like this.
  9. Feb 2, 2018 at 1:27 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, that's pretty much it. I plan to mount them outside of the metal. The rear bumper showed up 10 min. ago and I haven't even unpacked it. But, when I'm done I'll be sure to post pics.
  10. Feb 2, 2018 at 2:26 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    Ici Magnum makes a rear bumper that works. There is a YouTube video from SEMA in 2015 that shows it.
  11. Feb 2, 2018 at 7:52 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Not sure what that would look like and the sensors would be really susceptible to damage. Probably would be a better idea to cut a hole on each side and then trim it until the sensors just fit through it and mount them flush with the metal. I know, it is more work but it sure would look better.
  12. Feb 2, 2018 at 8:49 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for that info. I planning to try it with the new Westin Outlaw bumper.
  13. Feb 2, 2018 at 9:34 PM
    kcaustin66
    kevin
    About the blind spot sensor is it the outside hole in the bumper, or is it the larger sensor that mounts at the very end of each bumper under the plastic. The Reason I ask is until my new bumper parts come in. I have a different bumper on with chrome end panels and I really like it. Also the wire harness is just a basic one for the license plate lights.
    Also is there only 2 sensors in the front bumper at the end panels. I am wanting to install a bull bar but I don’t want it to be in the way of anything thanks guys
  14. Feb 2, 2018 at 10:02 PM
    ChucklesToy
    Chuck
    Round Rock, TX
    BSM is the large sensor behind the rear bumper at the end under the plastic; parking assist is the small hole in bumper. Yes, two sensors in the front.
  15. Dec 14, 2018 at 6:56 PM
    alyosha01
    alyosha01 New Member
    Did you ever mounted the BSM on the Westin Outlaw rear bumper? I am looking at this set up. II wa rear-ended a few days ago and I have placed an order of this bumper. I know it doesn't support the BSM but I am thinking about a way to adapt brackets and cut "windows" and attach plastic covers so that the BSM can read.
    831Tun[QUOTED] likes this.
  16. Dec 14, 2018 at 7:11 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think it can be done and sounds like you're on the right track. I haven't done it 'cause I'll be changing bumpers again. I might try to work the BSM into the fiberglass bed sides when the truck goes LT.
    alyosha01[QUOTED] likes this.
  17. Dec 14, 2018 at 7:57 PM
    kcaustin66
    kevin
    I have been looking at bull bar but should not get in the way (at least on my 2015 Tundra 1794). I replace the rear bumper with a chrome. Just don’t press the button to turn on. Like the chrome better wanted something a little stronger, plastic end panels on a truck doesn’t make since to me.
