Can I Cut my Catback, & Keep JBA LT Headers, Stock Midpipes,
Discussion in 'Performance and Tuning' started by trdprobped17, Sep 1, 2018.
  1. Sep 1, 2018 at 7:05 PM
    trdprobped17
    trdprobped17 [OP] New Member
    I just got my JBA LT headers in a few days ago. I decided to buy mine once I saw several build posts and the great results. I am going to tackle the installation within the next week or so. I was wondering if I could keep my stock mid-pipes, and just shorten my catbacks instead? It would be easier for my to cut and weld the cutbacks instead of trying to mod the mid pipes to keep my cats. What are your thoughts?
  2. Sep 1, 2018 at 7:10 PM
    trdprobped17
  3. Sep 2, 2018 at 7:31 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    You would have to cut the front of the stock mid pipes.
    This is not advisable. They are 2” and the best size is 2.5-3”.
    Also, the stock mid pipes are double wall tubing. Cutting them is easy enough I suppose. But you’d need to weld double wall pipe. There is no correct procedure for this.
    If using a catback designed for an otherwise stock truck you will want to build 2.5” mid pipes with all 4 stock cats.
    Call for details. Www.dirtydeedsindustries.com
  4. Sep 2, 2018 at 9:19 AM
    trdprobped17
    Sounds like a lot of work for someone that is a pro. It may be better if I have you do the midpipes for me instead. I’ll give you a call. Thanks.
    dirtydeeds[QUOTED] likes this.
  5. Sep 2, 2018 at 11:24 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
