Can i change transfercase oil? 2001 Tundra 174k light miles 1 owner.
Discussion in '1st Gen Tundras (2000-2006)' started by Overlander5, Oct 2, 2023.
  1. Oct 2, 2023 at 12:12 AM
    Overlander5
    Overlander5 [OP] New Member
    2001 standard cab 1 owner
    2001 standard cab 8ft bed v8 4wd pristine example. Painted jade mica if it helps :). As stated, truck is a grocery getter. Grandpa's old boat hauler, now mine. Has like maybe 300 miles hauling 2000 lbs total. So light haul usage) Maybe 50 miles in 20 years in 4wd. I have no idea if the transfer case was ever changed. Been wrenching on it for the last few years. Yet to come across a seized bolt thanks to texas weather. What am i in for with this transfer case. Engine and transmission have received 6000 mile/ 6 month 30000 mile oil changes religiously since purchased. Transfer case isnt slipping. Goes to work every time. I just know i cant leave it be.
  2. Oct 2, 2023 at 5:36 AM
    Mr Badwrench
    Mr Badwrench New Member
    Give it a shot. Remove the filler plug first and see how the oil looks. I've never seen my t case oil dirty.
    Overlander5[OP] and KNABORES like this.
  3. Oct 2, 2023 at 5:41 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
  4. Oct 2, 2023 at 5:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Change it. I can't see any reason why you shouldn't. I would do all the fluids. Front/rear diff, brake, power steering, transmission.
    Mr.bee and KNABORES like this.
  5. Oct 2, 2023 at 5:53 AM
    shifty` In South Dakota Trouble ain't hard to find
    Change it. It's the rear diff you need to be concerned about, if it's LSD, but only concern is fluid type.
    Meanwhile, read that thread @Jason.C linked, from end to end. It'll equip you with the knowledge you need to keep the truck running and functioning as more than just a boat anchor.
    dirtnsmores likes this.
  6. Oct 2, 2023 at 11:57 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I just drained the oil out of both my front diff and transfer case a couple days ago. there’s currently about 220k miles on my truck. My brother-in-law bought the truck when it had about 180k miles on it. He isn’t that mechanically inclined so i’m pretty sure he never serviced them. Maybe somebody changed the fluids in the past, but both were REALLY clean in mine!
    KNABORES likes this.
  7. Oct 2, 2023 at 6:27 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Toyota 75W is crazy expensive so many use Ravenol 75W. Get two crush washers for the 24mm drain plugs. Loosen fill plug first before draining. Fill to just dripping out of fill hole. Torque value is 27 ft-lb. Easy
  8. Nov 3, 2023 at 8:19 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    So is the consensus that Ravenol 75w the right fluid for the transfer case on a 06 double cab. Or do you guys recommend OEM?
  9. Nov 3, 2023 at 4:40 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I did valvoline synthetic 75w90. You'll get all kind of answers here. That worked for me in all 3 spots. If you have an LSD rear you gotta treat it to the right stuff or it'll complain about it.
    dirtnsmores[QUOTED] likes this.
  10. Nov 3, 2023 at 4:45 PM
    Mobil1 75w90 full syn here. And LSD rear, so naturally 80w90 Lucas.
  11. Nov 3, 2023 at 5:18 PM
    dirtnsmores
    Southern CA
    I did the right Lucas oil for the rear. I already have oil for the front differential. Just making sure I get the right stuff for the transfer case
  12. Nov 3, 2023 at 5:27 PM
    I used same M1 synthetic in TC and front diff.
  13. Dec 1, 2023 at 6:12 PM
    Overlander5
    Did the change. Oil was light brown. No issues since. Thanks all.
    whodatschrome and dirtnsmores like this.
  14. Dec 1, 2023 at 7:28 PM
    whodatschrome
    lots of dents
    A couple things...
    It seems like an engine oil change every 6k is quite a stretch...but then again oil change frequency recommendations are probably like having an oil thread on a forum.
    I do like the idea of changing the transmission fluid every 30k. I have done this with my mother’s 2008 Odyssey that she bought brand new. I also flush her power steering fluid at the same time.
    Your transfer case shouldn’t ever slip...like ever. There’s nothing inside our t-cases that has clutch plates.
  15. Dec 1, 2023 at 7:49 PM
    Overlander5
    To be fair, the 6k is a call back to when i was ignorant and fell for the old wives tale of " it needs conventional". A little research told me pennzoils high mileage synthetic blend was fine. That being said, $77 every 6 months isnt really a hassle. Diff/tcase change went well, but front diff oil was black. Idk what to think about that.
  16. Dec 1, 2023 at 9:11 PM
    whodatschrome
    lots of dents
    I wouldn’t worry about the front diff oil being black....unless there was a WHOLE bunch of ferrous fuzzies on the magnetic oil drain plug.
  17. Dec 2, 2023 at 7:36 AM
    GreenMachineDream
    GreenMachineDream New Member
    West Central, OH
    2002 Tundra SR5, 4WD, RCLB, Metallic Green
    When I bought my 02 RCLB earlier this year I changed EVERY fluid (Engine, ATF, Coolant, Power Steering, Brake fluid, Front Diff, TC, Rear Diff). Good insurance, especially when there's no maintenance records...
    whodatschrome likes this.
  18. Dec 2, 2023 at 8:33 AM
    Or you could be like mine, here are pics of rear/tc/rear drains for me: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1549#post-3084622
    Saving you a click for thefront diff photo, this is what came out of mine for the first few seconds ... I have my suspicions the PO had never had a drain/fill done on the front diff. But the magnet didn't look bad (pics of magnet sludge are one reply down in that last link).
    Needless to say ... the important thing here is just that you're changing fluids, and using the right fluid for the job. Oh, and changing these fluids, plus lubing the drivetrain, is probably one of the first things you should be doing when you get your 1st gen.
  19. Dec 2, 2023 at 11:32 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    My god...
  20. Dec 2, 2023 at 12:05 PM
    Had I found lots of shards on the magnet, or it drained this color the whole time, I'd have been concerned. I wasn't happy with that initial sludge, but what followed was a bit more normal. I am happy the fluids are refreshed, and I'm interested to see what comes out next change.
    DarkMint[QUOTED] likes this.
  21. Dec 2, 2023 at 12:32 PM
    whodatschrome
    lots of dents
    That’s actually the color i was expecting to come out of my tundra‘s axle. But someone must have changed it not too many 1000’s of miles ago. Pretty much all of my jeeps (both CJ and YJ), dodge cummins, old fords, ect have all had oil that color.
    shifty`[QUOTED] likes this.
  22. Dec 2, 2023 at 1:55 PM
    Overlander5
    Literally the same. Magnet sludge and all. No real shards though.
