can caster adjustment prevent body mount rubbing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Henry2019, Sep 3, 2020.
  1. Sep 3, 2020 at 10:35 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    I am currently rubbing on the corner of my body mount. So i was wondering theoretically if i were to adjust my caster slightly, the rubbing would go away? Can anyone chime in on this one?
    thank you
  2. Sep 3, 2020 at 10:39 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'm not sure what my caster is set to, but it's pretty far forward and I don't touch the body mount at all with 35x11 tires on stock wheels. I rub the sway bar and my shock resi at full lock, but never hit the body mount at ride height. So to answer your question, potentially yes, it could stop your rubbing.
    Henry2019[OP] likes this.
  3. Sep 3, 2020 at 11:09 AM
    TXTundra2722
    2015 Black Tundra
    If you're running aftermarket UCA... the answer is yes. Usually the sweet sweet spot is between 4-5 on castor.
    **edit**
    Tire/wheel size play a role here and also whether you still have stock front bumper. Pushing the tires forward can push them into your bumper if you're running stock.
  4. Sep 3, 2020 at 11:11 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Caster will definitely affect it... but putting wheels on the truck with correct offset makes the biggest difference.
    +18 to +25mm offset (approx 1") is the sweet spot.
    I have 35x12.5 tires on mine with +25 offset and they dont touch anything at all. (I did remove the flaps and front plastic)
    KevinK, Inquiringone, Elduder and 2 others like this.
  5. Sep 3, 2020 at 11:16 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Yup,
    Info posted thus far is all correct.
    +25 is about the sweet spot on offset.
    Bumping caster will help clear the cab mount.
    If you have Camburg arms, you'll have to have the tech use some choice swear words as they are a bit more difficult as high caster is built in to them, rather than using the cam bolts to adjust.
    Sunnier, KevinK and Henry2019[OP] like this.
  6. Sep 3, 2020 at 11:34 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    Dang which UCA can get 4+ caster?
  7. Sep 3, 2020 at 11:35 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    What lift do you have on your vehicle?
  8. Sep 3, 2020 at 11:35 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
  9. Sep 3, 2020 at 11:39 AM
    snivilous
    SW UT
    Kings at 3-4" and camburgs uppers
  10. Sep 3, 2020 at 11:52 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I bet you his cams are neutral as well.
    Burg builds a lot into their arms.
    Pros and cons to that design.
  11. Sep 3, 2020 at 12:01 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    Isn’t everyones goal is to achieve maximum caster and 0 camber?
    Sunnier, osidepunker and HulkSmurf14 like this.
  12. Sep 3, 2020 at 12:04 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    No, not everyone likes the steering, feel and manors of high caster.
    I believe most people like to stay between 2 to 4.
  13. Sep 3, 2020 at 12:17 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Just a cheap 3/3 Readylift.
  14. Sep 3, 2020 at 12:20 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    About how much do your tires poke out?
  15. Sep 3, 2020 at 1:43 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    If you max out your front cams all the way inward and max out your rear cams all the way outward, that moves your tires as far forward and outward as possible. IDK what that’ll make your tire hit on a Tundra but I know on a Taco, it lets you run large 33’s with no CMC. Adjustable (think SPC) UCA’s are required to make this work.
    Sunnier likes this.
  16. Sep 3, 2020 at 3:16 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    Can you elaborate on “Cams”?
  17. Sep 3, 2020 at 3:17 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    eccentrics
  18. Sep 3, 2020 at 4:25 PM
    The Patriot 1776
    '16 TSS CM 4x4
    The adjustable bolt/washers (2 per side on LCA) that let you adjust camber and caster are call cam bolts.
    Sunnier likes this.
  19. Sep 3, 2020 at 4:27 PM
    Elduder
    Elduder New Member
    SPCs, ran them on my Tacoma and even with 3" up front I was at like 4.9 degrees.
  20. Oct 1, 2020 at 3:39 PM
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    Does anyone know which brand uca will allow for the most caster? I have an aftermarket front bumper ,so not worried about rubbing there. Trying to fit 37s with zero offset wheels and no glass
  21. Oct 1, 2020 at 3:42 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Camburg
    Jman245[QUOTED] likes this.
  22. Oct 1, 2020 at 3:43 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Billet?
  23. Oct 1, 2020 at 3:47 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I think the billet actually place the joint further forward than the tubular, but regarding final adjustment honestly cant say.
    The tubular have a few degrees built in. It's not unusual to see caster in the 7/8 degrees with them.
    Jman245 likes this.
  24. Oct 1, 2020 at 3:51 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I hope so! I can't afford the billet ones but was looking at the balljoint Tubular ones. Thanks!
  25. Oct 1, 2020 at 3:52 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    So I should take a step back honestly...
    What's your suspension setup?
    Because they have such high caster built in, they dont necessarily work the best for everyone. I'm under 3" of lift and they are actually being a hindrance for me getting setup how I want. They work fantastic as an option for 3"+ of lift.
  26. Oct 1, 2020 at 3:58 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I'm currently on 5100s max out with a .25 shim ,so around 3" . My current alignment is maxed out to just over +4° and running 17s with 285/75. I plan on doing a dobinsons 3inch lift in the future . Most of my off road is overlanding and trail roads
  27. Oct 1, 2020 at 4:03 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    But your plans involved 37s and 0 offset, yes?
    So you are planning on doing that on the Robinson 3"?
    I ask because your previous was mentioning future plans while the more recent post was stating more immediate. So just trying to get it all sorted out.
  28. Oct 1, 2020 at 4:04 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Yes, do you think I'll have issues?
  29. Oct 1, 2020 at 4:05 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I believe your going to need to modify your pinch weld, cab mount and inner wheel metal and plastics trying to get that to clear properly.
    Caster itself wont be the fix for that.
    KevinK and Inquiringone like this.
  30. Oct 1, 2020 at 4:14 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I forgot to mention I have a bmc done. What inner wheel metal are you referring too?
