Can anyone confirm the OEM cam shaft seal brand?
Discussion in '1st Gen Tundras (2000-2006)' started by theSteels, Feb 23, 2021.
  1. Feb 23, 2021 at 7:49 PM
    theSteels
    theSteels [OP] New Member
    Will be doing a timing belt job soon and will change out the cam and crank seals. I ordered online and received my cam seals and the brand is "Stone"(made in Japan). Are these OEM?
  2. Feb 24, 2021 at 3:58 AM
    Professional Hand Model
    Hand Protectors
    Here is a pic of @theblurry1 cam seal replacement which looks just like the ones I put in on my truck. I do not remember ‘Stone’ being written on anything anywhere on my Crank or Cam Seals.
    Did your seals come in a Toyota Baggy? Where did you order?
    theblurry1 likes this.
  3. Feb 24, 2021 at 5:18 AM
    theSteels
    Amazon..seller said it was an oem part. I'll call a dealer to confirm.
  4. Feb 24, 2021 at 6:36 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Parts like that, hard to get at seals, etc. I always go to Toyota directly to make sure I get real OEM. Good idea to check now.
    des2mtn likes this.
  5. Feb 24, 2021 at 8:43 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If I search for a Husqvarna chain saw carburetor on Amazon, they will provide an array of Chinese brands of that carburetor that all look identical to the original (not made by Husqvarna). All will be priced well below the Husqvarna price. Reviews may vary widely.
    When shopping Amazon, look for descriptions that say "Replacement for Toyota XXXXX-XXXXX", or "Replaces OEM part", or similar. When you see that, it is definitely a knock-off part. Restrict your ordering to an official Toyota dealer if you want the parts to be genuine Toyota. In the case of Aisin or Denso, those will be the exact same as Toyota's part because they supply Toyota.
    In the case of oil seals, National is a well-known brand when there is an interchangeable seal commercially available. Stone is not a brand of seal I know, and it doesn't sound Nippon to me (Made in Japan?).
    Tundra2 likes this.
  6. Feb 24, 2021 at 6:06 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Great question, I ordered mine straight from Toyota and I actually think it came in a Stone bag. Make sure to apply grease.
  7. Feb 24, 2021 at 6:34 PM
    Vizsla
    Vizsla 2 = 2.5
    Ishino/Stone manufactures gaskets for many oem applications, and have for a very long time. They also produce them for non oem replacement parts, same thing just cheaper usually. Good stuff.
  8. Feb 27, 2021 at 5:46 PM
    theSteels
    Oem part is in toyota branded packaging and different from from stone seal.
