Camping with your 1st Gen
Discussion in '1st Gen Tundras (2000-2006)' started by shaw0531, May 16, 2016.
  1. Sep 19, 2018 at 9:47 AM
    #61
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Love your build! I'd love to see more of your manual hub swap. That was the first question I asked when I joined this forum. Also how does the aluminum utility shell stand up to off-roading? Especially versus a fiberglass shell.
    Casper421 likes this.
  2. Oct 15, 2018 at 9:43 AM
    #62
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Just got back from a week long camping trip at Hell Hole. We cought well over 100 trout. Did a lot of wheeling and ripping around the atv's.20181009_180048.jpg 20181011_164753.jpg 20181011_172128.jpg 20180929_105234.jpg 20180929_105611.jpg 2018-09-24 08.20.49.jpg 20181013_091222.jpg 20181014_103337.jpg 20181010_183259.jpg 20181012_124204.jpg 20181010_154926.jpg
    Voss, Filthyphil, potoghi and 5 others like this.
  3. Oct 15, 2018 at 9:47 AM
    #63
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'm having a hard time squaring the name of the place with the pictures you've posted.
    Also, how'd your Tundra do on the "Jeep Trail?" When I hear "Jeep trail" I think of something too narrow for a Tundra. Maybe that just the PWN in me, though. Great pictures.
  4. Oct 15, 2018 at 9:59 AM
    #64
    Brown Bear
    Nor cal
    03 TRD offroad
    I only made it part of the way with my truck on the Jeep Trail before having to turn around.
  5. Oct 15, 2018 at 10:00 AM
    #65
    Brown Bear
    Nor cal
    03 TRD offroad
    The Jeep Trail is definitely narrow. I got to a spot that I'm not even sure how a Jeep would even fit through. We ended up going back the next day with side by sides and quads and made it all the way around.
  6. Oct 15, 2018 at 10:23 AM
    #66
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Last weekend Fish Creek wash
    Voss, CmdrDaniels, Sunnier and 3 others like this.
  7. Oct 15, 2018 at 2:50 PM
    #67
    Shellback
    Shellback New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Can you share the benefit of installing 05-06 tundra intake retrofit swap?
    Thanks.
  8. Oct 18, 2018 at 12:20 PM
    #68
    toyotech2016
    toyotech2016 New Member
    2016 Tundra 1794 2004 Tundra TRD 2004 Sequoia Limited 1988 4Runner LT
    Sorry I don’t get notifications here. Anyways. The manual hub is from a first gen Tacoma. I took the hub and axles. Hybrid them with my tundra spindle and axles
    The aluminum sell holds up pretty good. I just like that I can drill holes in it and use he internal frame to mount stuff.
    BestGen[QUOTED] likes this.
  9. Oct 18, 2018 at 12:23 PM
    #69
    toyotech2016
    The 00-04 tundra plenum is fixed as a long runner while the 05-06 tundra plenum is a variable runner. 00-04 doesn’t have the ability to control the vsv that operates the variable runner. So I just took the vsv out and hooked it directly letting just vacuum control when the runners switch from long to short. I have noticed a little more pull at lower rpms. It doesn’t take much vacuum before it switches to short runners and you basically in the short runner setting anytime you have more than 15% throttle if I had to guess.
  10. Oct 18, 2018 at 1:05 PM
    #70
    Shellback
    I have to check this out. Thanks
  11. Oct 18, 2018 at 1:26 PM
    #71
    BestGen
    BestGen New Member
    Paul
    I thought it was possible. The parts look the same. Hubs were available up until 2000 I believe. Not positive tho.
    I'll probably go with an aluminum shell with the double rear doors. I really want a Four Wheel Camper but damn they're expensive.
  12. Nov 26, 2018 at 1:01 PM
    #72
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    So Tacoma hubs bolt up? that's Great!
  13. Dec 13, 2018 at 7:18 PM
    #73
    toyotech2016
    The hub is pressed in
    lsaami[QUOTED] likes this.
  14. Dec 14, 2018 at 7:13 AM
    #74
    Professional Hand Model
    Hand Protectors
    Do you have a link tutorial on this modification? In the meantime, I’ll search. Thank you.
  15. Dec 15, 2018 at 11:58 PM
    #75
    toyotech2016
    Sorry I do not. It’s only easy to be retrofitted on go 03-04 tundra and sequoia
    You need everything from 05-06 tundra or 05-07 Sequoia
    Of the top of my head
    plenum (as much stuff attached to it)
    TB
    Fuel rails
    You’ll want to bypass the vsv under the plenum and just connect the two vacuum hoses together.
    Disconnect the battery. Remove your original Plenum, fuel rail and TB
    You’ll need to install your original injectors into the new fuel rail and plenum.
    Also swap the fuel pressure regulator so the original fuel system can be hooked back up
    Now this is the time of you like to just bypass the TB coolant lines and run it back into the engine block.
    Now you can reinstall the newer plenum assembly.
    Once installed. You need to hook up the brake booster. Might need to extend the vacuum hose.
    The vacuum hose under the plenum near the TB is used for the power steering vacuum idle up. You’ll need to use a reducer to connect the two different size hoses.
    Install the newer TB upside down and hook up the vacuum hoses. Hook up the PCV and Anything else that was disconnected.
    Now fire it up and check for any fuel and air leaks. On first test drive and first few hundred miles. Drive it easy till the ecu relearns.
    The biggest noticeable difference with this retrofit is how much better throttle response is. Feels like it woke the truck up. Over time this feeling becomes normal but you still remember/feel better throttle response.
  16. Mar 19, 2019 at 2:08 PM
    #76
    ivythetundra
    ivythetundra New Member
    Ben
    San Pedro, CA
    Sunfire Red Pearl 2001 TRD Tundra 4x4
    Icon 2.5 ext coilovers and 2.0 smoothies(soon to be ADS 2.5 Piggybacks). Camburg UCA TC spindle gussets and Deaver g57s. Machined 16 in Method NVs with 285/75r16 Toyo RT's.
    First post here! This is a little throwback to my first camping trip I ever took a year and a half ago. This was in Johnson Valley after I had first gotten my suspension and work done on my truck. I was addicted after this! Going to superstition next weekend for a quick trip with some friends!
    speedtre, Brown Bear and FirstGenVol like this.
  17. Mar 19, 2019 at 2:15 PM
    #77
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    King of the hammers.
    24 degrees in the mornings. COLD
