Camping with Florida AF - a continued saga
Discussion in 'Outdoors' started by Florida AF, Apr 21, 2025.
  1. Apr 29, 2025 at 12:43 PM
    That's reasonable for a destination campground.
    that campground is a shithole right next to the busy highway.
  2. Apr 29, 2025 at 12:45 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Do you have a set of bubble levels installed on your camper? I have one on the front driver side which makes it easy to get out and check when using the levelers on one axle.
  3. Apr 29, 2025 at 3:48 PM
    Florida AF
    Florida AF [OP] Florida Outdoors... Heaven
    Logan
    North Florida
    I bought some and thought they were stick on, they were not. So I havent installed them yet. I have a magnetic one I keep with the first out stuff, I use that for now to level. The end goal is to get one of the fancy electronic ones.
    Dsptundra[QUOTED] and ColoradoTJ like this.
  4. Apr 29, 2025 at 4:11 PM
    I just took a level with me as back up. Seemed my factory ones that came on my camper were not as reliable.
  5. Apr 29, 2025 at 4:28 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    First lesson to be learned is just like in Florida camping in the summer in Texas without A/C is Damn Near impossible!!!
    Cant say I've ever woke up in the morning feeling refreshed tent camping in the summer in Texas.
    I ended up buying a custom made canvas tent with an A/C opening on the side of the tent.
    You'd set the A/C unit on a short table with the custom made sock with a drawstring connected to it.
    Right about sundown you'd wet the tent down and fire up the A/C.
    You could hang meat in the tent!!!!
    Now I'm all about campers!!
    The only drawback is you cant pull the camper down the beach.
    I suppose you could try but you're likely to get stuck.
    The only way would be to come in at low tide and leave at low tide so you could drive on the wet sand.
  6. Apr 29, 2025 at 6:31 PM
    Azblue
    The Dirty T ( ^_^)_且
    I much prefer the curved levelers to blocks. Also, get one of these, you can set your phone on the center console and watch as you inch up the levelers until level. Also you can do the same thing even before starting to set up as you pull into your site to find where the ground is more level.
    https://www.amazon.com/dp/B01FGGSWPW?th=1
  7. Apr 29, 2025 at 7:14 PM
    Florida AF
    Logan
    North Florida
    Spent 1/3 of my life in TX.. all true!
    I will check it out! the system I was looking at was a lot more expensive so I will look in to these.
  8. Apr 29, 2025 at 7:15 PM
    Florida AF
    Logan
    North Florida
    Forgot to mention I purchased these.... they are being returned. For some, they will probably work great. For me, I took them off to add tire pressure (all read low and accurate) and two of them did not alarm to the loss of pressure. Plus, they all did not consistently connect. I decided to do a tire/valve stem/monitor upgrade next year so I will just ride blind until then.
    https://www.amazon.com/dp/B0CW9GXBCB?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    ColoradoTJ likes this.
  9. Apr 29, 2025 at 7:25 PM
    I just checked tire pressure at stops and before starting out each trip.
  10. Apr 29, 2025 at 7:33 PM
    Florida AF
    Logan
    North Florida
    I have decided to go this route for sure. I did it until now and had some points to spend so I bought this... unreliable. Next up, old faithful.
  11. Apr 29, 2025 at 7:39 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    We used to take the 60 mile run down Padre National Seashore.
    60 miles and you might see a couple of people.
    The wildlife was amazing!! And the Huge Dunes!!!
    They were easily 100 ft tall!!
    We saw a bunch of Huge Manta Rays that were easily 12 foot across leaping out of the water!!!
    Apparently they do this to dislodge the sucker fish and other parasites.
    It really shows you what the beaches used to look like before getting overpopulated!!!
    Florida AF[OP] likes this.
  12. Apr 30, 2025 at 4:41 AM
    Dsptundra
    Austin TX Area
    That looks slick. Going to check it out. Is it just one unit to get it level from side to side or does it do front to back too?
    Azblue[QUOTED] likes this.
  13. Apr 30, 2025 at 8:26 AM
    Azblue
    It does both.
    Dsptundra[QUOTED] likes this.
  14. Apr 30, 2025 at 12:20 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    I'll see if I can find some of the Pics from our trips down Padre.
    Might have to get them put on a thumb drive.
    There's a service out there that does this.
    mrmahi and Florida AF[OP] like this.
