Camping Fridge/Freezer Setups
Discussion in 'Outdoors' started by Krezz, Mar 25, 2019.
  1. Mar 21, 2022 at 10:15 AM
    #181
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Lol... Thank you :hattip:. Valley of the Gods, UT
  2. Mar 21, 2022 at 10:27 AM
    #182
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I think the question you need to first ask yourself is if battery capacity is an issue. If it’s not, then fill the extra space with foam/pool noodles.. whatever.
    But if battery capacity is a semi-concern, then you’re going to want to use something else. Not sure if this will work for you since most of my ventures are day trips, but I have 6 semi-robust plastic jugs that I keep in there filled with potable water. When I’m originally packaging the fridge I fill the extra space with those and will bring 1 or two with me (pre-chilled). As I use up cans, I’ll eventually replace that space with another jug. Makes it so my fridge doesn’t have to work as hard (easier on my battery).
    Wallygator and Cruzer[QUOTED] like this.
  3. Mar 21, 2022 at 10:40 AM
    #183
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Nope, not an issue. Fridge runs off the alternator when the engine is on and when it's off it runs on the 120ah secondary battery. I'm also adding two permanently attached 100 watt solar panels to the under side of my bed rack that will be attached via drawer slides so that it can pop out over the tailgate and double as a sun shade.
    Wallygator and Mater[QUOTED] like this.
  4. Mar 21, 2022 at 10:49 AM
    #184
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    FYI, found this code for 15% off on iceco's website: hobotech
    Wallygator likes this.
  5. Mar 21, 2022 at 10:49 AM
    #185
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Nice. Foam sounds like a good option then
    Good idea with the slide out serving as a sun shade.. hadn't thought of that:thumbsup:
    Cruzer[QUOTED] likes this.
  6. Mar 21, 2022 at 3:23 PM
    #186
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    15% off
    Free shipping
    No tax
    I had to man! :thumbsup:
    Damie Street, Wallygator and Cruzer like this.
  7. Mar 21, 2022 at 3:45 PM
    #187
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    goddamn this forum! I need a side hustle for this truck.
    SAGE63 and Flyinryank[QUOTED] like this.
  8. Mar 21, 2022 at 3:55 PM
    #188
    Cruzer
    Cruz
    Sunnyvale, CA
    Can you do me a favor? When you receive your fridge can you take a picture of the packaging it was in and post in on here?
    I ordered a Dometic fridge (not a CFX though) during Black Friday and it arrived damaged, they sent another and it arrived damaged, then they sent a 3rd and it too arrived damaged. The fridge came in a box but had no foam or anything.
    Flyinryank[QUOTED] likes this.
  9. Mar 25, 2022 at 3:00 PM
    #189
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
  10. Mar 25, 2022 at 3:55 PM
    #190
    Cruzer
    Cruz
    Sunnyvale, CA
    Thanks! What about the inside?
    FrenchToasty likes this.
  11. Mar 25, 2022 at 6:01 PM
    #191
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Opening it tomorrow and making a platform on the 40 side of the backseat
  12. Mar 25, 2022 at 7:52 PM
    #192
    MadMaxCanon
    Awesome thanks! Just ordered the vl45
  13. Mar 25, 2022 at 8:11 PM
    #193
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    That was my other choice. Numbers are hard to beat for the price
    MadMaxCanon[QUOTED] likes this.
  14. Mar 25, 2022 at 10:22 PM
    #194
    helidave
    flagstaff
    2015 DC 4x4
    Nice! I would have gotten that one instead of the JP40 but it's too big for my fridge slide.
  15. Mar 26, 2022 at 9:41 AM
    #195
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    For those who have made platforms for fridge; do you pull those 2 rubber (square) grommets?
    I want to make a basic platform to hold my fridge behind the driver seat long ways. Looks like I can mount a platform to the factory seat brackets and make a L shape to the floor where people’s feet sit for support.
    just want to get ideas on where exactly you guys braced the platform too. I want it totally module so if I need to pull my fridge out; I can have the platform be removed quickly.
    many thanks!
  16. Mar 26, 2022 at 11:37 PM
    #196
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Not bad but not my best work. Will perfect a full platform soon for my fridge and dogs.
    des2mtn, Warreng and Wallygator like this.
  17. Apr 1, 2022 at 7:46 AM
    #197
    helidave
    flagstaff
    2015 DC 4x4
    FYI, if you used that code you'll get a free LED lantern. Mine was delivered separately like a day after the fridge and I thought they sent it by mistake at first.
  18. Apr 1, 2022 at 8:02 AM
    #198
    MadMaxCanon
    Awesome! I didn't see any reference to that though. It's been 3 days I don't think I got one.
  19. Apr 5, 2022 at 9:32 AM
    #199
    helidave
    flagstaff
    2015 DC 4x4
    Took out the passenger side seat and made a little platform. Uses the factory seat bracket bolts on the rear wall and the middle bolts go through the pads that the bottom of the seat rests on.
  20. Apr 7, 2022 at 2:00 PM
    #200
    Cruzer
    Cruz
    Sunnyvale, CA
    I like it already! The cans are held pretty snug in the tray. It took a couple weeks to arrive from China though.
    I wish I could've put all 8 next to each other but the 7th one in the middle works out just fine limiting the other trays' movement. I can also put 2 more trays on top, if I want, for a total of 10.
    Mater, Warreng and SAGE63 like this.
  21. Apr 7, 2022 at 2:05 PM
    #201
    SAGE63
    San Diego County
    @Cruzer where did you find these?
  22. Apr 7, 2022 at 2:08 PM
    #202
    SAGE63
    San Diego County
    Installing today
    Flyinryank, FrenchToasty and Cruzer like this.
  23. Apr 7, 2022 at 2:08 PM
    #203
    Cruzer
    Cruz
    Sunnyvale, CA
    Flyinryank and Mater like this.
  24. Apr 7, 2022 at 2:09 PM
    #204
    SAGE63
    San Diego County
    lol
  25. Apr 7, 2022 at 2:09 PM
    #205
    Cruzer
    Cruz
    Sunnyvale, CA
    Imma chill by your truck at T2S this time round :cheers:
    FrenchToasty and SAGE63[QUOTED] like this.
  26. Apr 7, 2022 at 2:13 PM
    #206
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think we need to check the internal temperature of each can to make sure the cooler is working properly
  27. Apr 7, 2022 at 2:15 PM
    #207
    SAGE63
    San Diego County
    I will be in the quiet please no parties over here section....lol
    FrenchToasty and Cruzer[QUOTED] like this.
  28. Apr 7, 2022 at 2:17 PM
    #208
    Cruzer
    Cruz
    Sunnyvale, CA
    I'll start there and work my way back :burp:
  29. Apr 7, 2022 at 8:10 PM
    #209
    SAGE63
    San Diego County
    Installed ICECO VL45 and slide...
  30. Apr 7, 2022 at 8:16 PM
    #210
    Cruzer
    Cruz
    Sunnyvale, CA
    Good looking fridge. Looks sturdy. How many beers can you hold for me?
    Mater likes this.
