Camper Shell / Tailgate Weatherproofing
Discussion in '1st Gen Tundras (2000-2006)' started by adrian.bee, Jul 11, 2019.
  1. Jul 11, 2019 at 3:28 PM
    adrian.bee
    adrian.bee [OP] New Member
    Maine
    05 AC 4X4
    I'm hoping to rejuvenate the topper on my (new to me) rig. It's been on the truck since 2005 so naturally it could use some TLC.
    I drove on the highway a few weeks back during a thunderstorm and noticed a small amount of water in the front corners of the bed and I have plans to build out a bed platform, so I want to seal this bad boy up nice for some late summer / fall camping trips.
    While I have the topper off, I also want to insulate and line the topper like this TW member: https://www.tacomaworld.com/threads/camper-shell-build.476020/
    These items are what I'm looking to order, and will be picking up the carpet/insulation/adhesive locally.
    Bulb seal: https://www.amazon.com/gp/product/B00MPMBIZW/ref=ox_sc_act_title_1?smid=A26GQRWSJVLGWV&psc=1
    Tailgate seal: https://www.amazon.com/Ultimate-Tailgate-Seal-Taper-10ft/dp/B00IPQWXZQ
    My questions for you fine folks are:
    1) Any tips for removing/cleaning/resealing my topper?
    I have a feeling the old seal is gonna be a b&*$h to remove and to clean off the bed
    2) Has anyone installed a tailgate seal?
    I dont have a bed liner, just a bed mat. It seems pretty straightforward but personal recommendations are always appreciated.
    Here are some pics of the bed, you can see the light coming through on the front corners.
    Thanks!
  2. Jul 11, 2019 at 3:33 PM
    adrian.bee
    Maine
    05 AC 4X4
    Oh and for posterity, here is my truck from this weekend. Did a little beaching and camping in RI/Cape Cod:
    Black Wolf likes this.
  3. Jul 11, 2019 at 4:08 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can tell you I bought the same "double bulb" and other material and I didn't work for me. It helped a little but still leaks. I also put pipe insulation along the front rail.
    I will add that the main reason mine leaks is because it was made for a double cab and it's an old topper.
    Jack McCarthy likes this.
  4. Jul 11, 2019 at 4:57 PM
    Professional Hand Model
    Hand Protectors
    Load’er up with some Fuze by Liquid Nails and she’ll be submarine material. Gett’r dunn.
  5. Jul 11, 2019 at 5:24 PM
    adrian.bee
    Maine
    05 AC 4X4
    Ha! Fortunately I don't need it to be submersible and I'd like to take it off if needed.
  6. Jul 11, 2019 at 6:35 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I also did that and it did not work. Some shells just leak. These things aren't air tight. The windows leak too.
  7. Jul 12, 2019 at 6:09 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I think the trick will be to eliminate any and all cuts to the weatherstripping...particularly in the corners. I had leaks on my T100 topper and I think it was because I had the seals cut and just touching in each corner. If you can run one continuous line of the seal and work it around the corners it should work ok. Then maybe an extra clamp as close to the corners as possible.
    Oh, and if you're camping in it, the universal BedRug mat could be a great addition. You'll have to cut to fit, but should be comfy. I have one that I still need to cut.
    adrian.bee[OP] likes this.
  8. Jul 12, 2019 at 1:30 PM
    adrian.bee
    Maine
    05 AC 4X4
    Great tips, thank you sir!
    Gotcha. I'm definitely scared of taking the windows out to do the carpeting because they don't leak right now. The PO took really good care of it. I don't need air tight but definitely don't want my gear and bed getting soaked in a storm.
  9. Sep 26, 2019 at 9:01 AM
    adrian.bee
    Maine
    05 AC 4X4
    Update time!
    Redid the seal with double bulb and a large bed rail seal on the front. The clamps really squeezed the seal together and so far, no leaks!
    58835131966__007E117D-3D08-40AD-A09C-4CDDEEB7646B.jpg 58835523686__A79EFC71-4BE3-4037-9CA5-9DCABB0391E5.jpg
    Truck looks weird without a cap..
    Now time to build bed platform. I did a good amount of research on designs and landed on a pretty basic two box setup with flip tops for storage, aka "carpet kit". I need the ability to throw mountain bikes and go into "pickup" mode quickly if needed. The height is based on a YETI cooler.
    Basically I bought two sheets of 1/2" ply and some 2x3's, and had some scrap 2x4s. Didn't necessarily have a plan but put together the frames in one night. The lengths are notched around my clamps.
    Next up, squaring up the frames. Due to wonky scraps (or bad craftsmanship) the frames weren't exactly square. We came up with a ratchet strap securing/squaring system. The straps are wrapped around the cargo tie downs and tightened, which will help with squaring and install/removal making everything tight and tidy.
    Plywood walls..
    Almost finished. Next up is piano hinges, two piece center platform with marine carpet. Thanks for reading!
    NUDRAT, FrenchToasty and speedtre like this.
