Camburg UCA install
Discussion in '1st Gen Tundras (2000-2006)' started by ajmorenoaz, Jun 22, 2020.
  1. Jun 22, 2020 at 9:18 PM
    ajmorenoaz
    ajmorenoaz [OP] New Member
    2000 Tundra Sr5
    Well I’d call this a successful weekend, anyone else have trouble popping the upper ball joint out of the spindle? 4 trips to auto zone and O’reilly to rent tools but we got it done
  2. Jun 22, 2020 at 9:21 PM
    ajmorenoaz
    2000 Tundra Sr5
    There’s really no way to lift it more with coilovers without LT huh? And I’m not feeling a body lift ahh
  3. Jun 22, 2020 at 9:22 PM
    BajaTurd
    BajaTurd Burrito Champion
    Aj
    San Diego
    19 4x max
    Camburg uppers Kings Deavers
    Solo motorsports makes a lift spindle
    Hbjeff and Darkness like this.
  4. Jun 22, 2020 at 11:50 PM
    ajmorenoaz
    2000 Tundra Sr5
    They want how much???? Might as well long travel it at that point Im so sad lol
  5. Jun 23, 2020 at 10:29 AM
    BajaTurd
    Aj
    San Diego
    19 4x max
    Quality Truck parts aren’t cheap. And no you can’t compare a spindle to a full long travel kit in cost.
    $1800 for spindle. Done-
    2350$ for the basic kit
    And in reality you should get the spindle anyways for strength and removing the preload from your coils. Huge upgrade.
    New shocks cuz yours won’t work-1300$?
    Steering upgrades.
    Fenders-350+-
    Paint?
    Bumper?
    Endless fixing things like sheet metal fixing other parts failing from abuse etc
    Proper set up/fab/install. Cuz if you struggled with an upper arm good luck.
    Just a basic break down.
    Tundyfundy, Darkness and chugs like this.
  6. Jun 23, 2020 at 3:03 PM
    ajmorenoaz
    2000 Tundra Sr5
    This is funny asf to me I only had problems because I didn’t have the right fucking tools and when you have connects with camburg the possibilities are endless and explain to me why these coilovers wont work for Lt? The possibilitys are endless for these coils and the bumper? when you weld all you do is buy the steel piping I’m lost on what’s so expensive half these kits come with the damn lift spindle do your research before you run your mouth lmao
  7. Jun 23, 2020 at 3:14 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
  8. Jun 23, 2020 at 4:44 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    They're not nearly long enough. If you have connects with Camburg and don't believe it, ask them.
    The stock upper ball joint is a bitch to get off without removing the spindle. There just isn't much room to get a big enough tool in there. I had to cut the end of a wrench off and use a cheater pipe to get leverage.
    If you just want lift, and you don't have ABS, i would definitely consider that 1800 spindle. You've already got a nice set of coilovers, you've just finished putting on arms that run $600 (without discounts). Neither of which will work with long travel and won't sell for half of what you paid. You'll pull 5" of lift up front with the spindles, gain track width, and gain serious strength. Bonus is they come with new hubs, bearings, and longer studs.
    Long travel is gonna run you into the 5k neighborhood fast for the front alone, add a few thousand more for the rear. If you want to invest that's awesome but you said you want lift so not sure that ride is worth the price.
  9. Jun 23, 2020 at 5:51 PM
    Just an observation.....I would replace those wheel spacers with hub centric spacers or get a different offset wheel.
  10. Jun 23, 2020 at 8:39 PM
    BajaTurd
    Aj
    San Diego
    19 4x max
    What’s funny asf to me is you ask basic questions get a basic response then turn into basic bitch. Only a camburg/solo —RACE KIT—comes with a spindle and that kit costs more then your truck all said and done lmfao
  11. Jun 24, 2020 at 8:14 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn it turned into Vortex in here.
  12. Jun 24, 2020 at 8:33 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
  13. Jun 24, 2020 at 8:42 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    :popcorn::duel:
    Tundyfundy likes this.
  14. Jun 24, 2020 at 3:13 PM
    Rudolph_05tundra
    Rudolph_05tundra New Member
    Seth
    Kentucky
    2005 Toyota Tundra DC SR5
    So with these spindles, how does lift work really? I'm sitting at 3" with coilovers already and these spindles I believe are rated to get about 3", would that be about 6" or stay about 3"? Sorry, I'm new to spindle lifts Honestly didn't know they made some for our trucks, so I'm intrigued now
  15. Jun 24, 2020 at 7:41 PM
    ajmorenoaz
    2000 Tundra Sr5
    Aye boss your trucks what you think it’s worth lmao I don’t see any pictures of your pavement princess on here so I can’t really say much lmao
  16. Jun 24, 2020 at 7:42 PM
    ajmorenoaz
    2000 Tundra Sr5
  17. Jun 24, 2020 at 7:56 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @ajmorenoaz depends what size tire you want to run. Good news is your Camburg arms provide more clearance than stock arms.
    Common tire size is 285/75/16 or 285/70/17. You should be able to fit either if you find a wheel with width of 8 or 9" and 4.5" backspace or less, 4" backspace and 8" wide is best.
    If you want to run a bigger tire than that youd have to do serious surgery to cut and tub the pinch weld area between the frame and your doors.
    Sunnier likes this.
  18. Jun 25, 2020 at 5:06 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
  19. Jun 27, 2020 at 3:13 PM
    saybng
    Gary
    Ventura CA
    @ajmorenoaz .. installing my camburgs atm..how much grease do you put in the bushings?..anyone?
  20. Jun 27, 2020 at 3:32 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I pumped grease in until it was oozing out of each side, then put the truck down, bounce the truck, then tighten the pivot bolt.
    Sunnier, AZTundra and saybng[QUOTED] like this.
  21. Jun 27, 2020 at 6:09 PM
    ajmorenoaz
    2000 Tundra Sr5
    Yea pump it until the grease comes out of each side and I wouldn’t even worry about bouncing the truck, I did it while the control arms were off the truck did I fuck up lol
    saybng[QUOTED] likes this.
  22. Jun 27, 2020 at 8:46 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You should be fine as far as grease, but you really want to put the pivot bolt on loose and bounce the truck before you torque it down. I like to drive in and out of my driveway, or go over a speed bump slowly a few times. That makes sure the bushings are not twisted, then you torque the pivot bolt while the truck is on the tires.
    A lot of guys fuck this part up and torque the pivot bolt while the truck is in the air, that binds up the bushings at ride height and theyll make noises in 2 years.
  23. Jul 24, 2020 at 5:52 PM
    ajmorenoaz
    2000 Tundra Sr5
    I’m trying to buy a set of methods the problem I’m having is they go off the offset not backspace how much offset would I need boss? Or am I just off all together this backspace offset thing is throwing me off
  24. Jul 24, 2020 at 6:17 PM
    saybng
    Gary
    Ventura CA
    What size wheels are you going for?
  25. Jul 24, 2020 at 6:49 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    yes you could effectively have 6 inches of lift, or even better you can turn your coilovers down so it will ride better and have 5 inches.
    one option for the rear of a gen 1 is a shackle flip to get 4 inches of lift or so
  26. Jul 24, 2020 at 6:58 PM
    ajmorenoaz
    2000 Tundra Sr5
    16s
  27. Jul 24, 2020 at 7:03 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  28. Jul 24, 2020 at 8:52 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Which methods? How wide are they and what is the offset? That can be converted to backspace and then you'll know.
  29. Jul 25, 2020 at 5:38 AM
    Professional Hand Model
    Hand Protectors
  30. Jul 25, 2020 at 7:06 PM
    ajmorenoaz
    2000 Tundra Sr5
    They’re the 305 Nv 16x8 with a 4.5” backspace
