Camburg ball joint UCA for Trd Pro any reviews ?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by NjPro, Nov 19, 2018.
  1. Nov 19, 2018 at 4:34 PM
    NjPro
    NjPro [OP] New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    A7CE4AF7-A507-47E1-8A70-B8F082A6E3FF.jpg I want to get a set off these and want to know if any of the guys with a pro have them installed. I do a Cb 1” shim, any feedback would be cool and appreciated. I have spent a few weeks looking around the fourum and have read a lot of info about all of the UCA’s that are available and this is the set I want to get. With the sales going on right know I can get them a good bit under 600.00 delivered. The delta joint is beyond what I want to spend. I have around 800.00/850.00 to spend on purchase and install. Thanks
  2. Nov 20, 2018 at 5:14 AM
    NjPro
    Tom
    Nj
    Bump
  3. Dec 27, 2018 at 10:04 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Are UCAs even needed on the PRO after the CB shim lift?
  4. Jan 4, 2019 at 4:25 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Looking at the same setup for my Pro as well. Do you guys think for a $100 more it's worth the uniball worth it? Someone must have an answer?
  5. Jan 4, 2019 at 4:43 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    If you wanna spend the money I would go with the Camburg Kinetic UCA. If your looking for a cost effective UCA I would go with the SPC UCA.
  6. Jan 4, 2019 at 4:46 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I think that @831Tun had alignment issues with the Camburg arms.
  7. Jan 4, 2019 at 4:52 PM
    alpinepro4
    Pat
    Why do folks like SPC so much? I would have thought this Camburg setup would be cost effective, and good future upgrade for better suspension. In the near future.
    I did read somewhere there can be alignment issues with Camburg.
    831Tun likes this.
  8. Jan 4, 2019 at 5:29 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Cost effective, good product, low matience.
  9. Jan 4, 2019 at 5:41 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I would skip UCA's with TRD Pro shocks and put the $$ towards other mods. Most upgrade UCA's to help with alignment and gain extra travel with extended travel shocks on a Mid Travel/Long Travel setups from Fox/King/ADS/Icon.
    NjPro[QUOTED][OP] likes this.
  10. Jan 4, 2019 at 6:23 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The Camburg UCAs have A LOT of caster built into 'em which I believe can damage the steering rack. I switched 'em for MCM UCAs. I've been through several UCA setups and think MCM and TC yield the best results with caster and camber.
    GodlessPro likes this.
  11. Jan 4, 2019 at 6:45 PM
    alpinepro4
    Pat
    I am looking to upgrade my UCA 1st. Going to go ADS or Kings next fall. Staying 2/1. Sounds like MCM is a better choice. TC little more then I want to spend plus I hear they can squeak.
    831Tun likes this.
  12. Jan 5, 2019 at 9:57 AM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    TC can squeak if they aren’t properly greased. Mine squeaked terribly on my Tacoma until I hit them with the grease gun.
    831Tun likes this.
  13. Jan 5, 2019 at 10:06 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Like @ Guhner123 says, clean and lubed they won't squeak, dirty/ dry they'll both squeak. MCM is the same as TC for the most part (same uniball and poly bushings) except they provide a little more caster. It's important to note that to lube the bushings properly, the long bolt is supposed to be loosened to prevent ruining the bushings.
    GodlessPro and Guhner123 like this.
  14. Jan 5, 2019 at 10:10 AM
    alpinepro4
    Pat
    Should you re grease every other oil change, or how dusty and wet the conditions are and grease accordeling. I live where there is lots of snow and dry and dusty in the Summer.
    GodlessPro and 831Tun like this.
  15. Jan 5, 2019 at 10:12 AM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    I live in San Diego and through desert trips and stuff like that I didn’t have any issues for 20k Miles. But it can vary. That’s why people do like SPC ucas there just like the stock ones and don’t require much matience.
  16. Jan 5, 2019 at 10:13 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You shouldn't need to grease the bushings very often. I haven't had a set of UCAs on the truck long enough to require re-lubing after install. You'll wanna keep a rag and some triflow around for your uniballs. Mine squeak a little when they get dusty.
  17. Jan 20, 2019 at 7:44 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    I don’t have a pro but have I have the Camburg ball joint UCA’s and they have done me well. I had a set of SPC UCA’s on my Tacoma and they squeaked like hell after the first few months. Decided on the these since I don’t see any hardcore or extremely fast off-roading and they are much more protected from elements. IMO, you can’t go wrong with whatever company you go with
    NjPro[OP] likes this.
  18. Jan 20, 2019 at 7:53 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    Can someone explain the exact reason why you would need these? Alignment help and long travel strength are the only reasons I see why. Thanks.
  19. Feb 7, 2022 at 6:40 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    Refreshing this thread as I'm considering the Camburg billet UCAs. Anyone care to elaborate/add to the alignment issue?
    831Tun likes this.
  20. Feb 7, 2022 at 7:19 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I have TC uppers for going on 4 years and no problems whatsoever. I grease them once or twice a year during oil change / driveshaft grease intervals and keep the balls cleaned whenever I wash the truck.
    My alignment is stellar. No issue.
    Edit: my previous Gen1 had Camburg uppers and never had an issue. Same maintenance schedule and same alignment guy.
  21. Feb 7, 2022 at 7:25 AM
    Tundradrenalin
    Virginia Beach, VA
    I think people either don't know how to grease them or they grease the bushings incorrectly with the top bolt un-loosened. And then they have problems and blame the equipment.
    You MUST loosen or even remove the top bolt when you grease the bushings. If you don't, you will damage the bushing.
    I loosen the top bolt/nut so that the washer is easily spinning in my hand, then I put the grease gun and push grease until it pushes out a lot of the old grease, then wipe off the excess, tighten the bolt, wipe again. And I'm done. Easy peasy. Don't even need a lift.
  22. Feb 7, 2022 at 9:05 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The billet Camburg's have heims so the above mentioned bushings are a moot point. The benefit is a very adjustable UCA allowing all kinds of alignment adjustment. The downside is alignment techs are often not the greatest/most experienced mechanics and none of them know how or are willing to put in the extra effort to use the heims to adjust your alignment. The heims are a great feature that few can/will be able to take advantage of.
    Tundradrenalin likes this.
  23. Feb 7, 2022 at 9:17 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Be sure you have proper wheel offset to accommodate these.
