Camburg 2.5 long travel kit with 2.5 Fox shock
Discussion in 'Suspension' started by fazi, May 3, 2021.
  1. May 3, 2021 at 12:33 PM
    fazi
    fazi [OP] New Member
    frank
    2017 Tundra TRD SR5 Crewmax
    N-fab Front bumper 40 Rigid RDS light bar GOrhino Rear bumper
    Hi tundra folks.
    My truck got a camburg long travel kit installed with 37inch tire and Fox 2.5 shocks. I full-turn front tire , when I take a sharp corner,and the tire just rip off the reservoir hose of the Fox shock. I was wondering if it is the right installation position that camburg instruction says. Any body have the same issue out there?
    Thanks!
  2. May 3, 2021 at 12:40 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    A quick Google search shows every camburg Lt setup having the reservoir mounted with the clicker facing the other direction..
    Sick setup btw
  3. May 3, 2021 at 12:41 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
  4. May 3, 2021 at 12:51 PM
    fazi
    frank
    My local 4 Wheel Parts installed it. I don’t know why the hose knob is facing to the tire anyway
  5. May 3, 2021 at 12:52 PM
    fazi
    frank
  6. May 3, 2021 at 12:53 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    I would take it back to them and have it mounted the right way. And any damage repaired as I'm sure the shock will need new fittings and recharged..
    T-Rex266 likes this.
  7. May 4, 2021 at 7:41 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    That is not the same shock or setup so do not use that as a reference for your reservoir mount. I would suggest contacting Camburg to see how they spec the reservoir mount. These are not OEM specific shocks, they should be specific to Camburgs kit.
