Camber issues please help!!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by l3LUEFALCON, Sep 19, 2018.
  1. Sep 19, 2018 at 7:14 AM
    l3LUEFALCON
    l3LUEFALCON [OP] RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    I recently got the TRD pro suspension upgrade installed and set it for max elevation. Even before I installed the new suspension I always thought I had a problem with my camber. The alignment machine says that is within spec's (before and after) but whenever you look at the front end it always looks like it has positive camber. Is this just me or do I have something wrong?
  2. Sep 19, 2018 at 7:16 AM
    l3LUEFALCON
    Josh
    North Houston Area
  3. Sep 19, 2018 at 7:25 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Take it to a different alignment tech.
  4. Sep 19, 2018 at 7:31 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Also you should be looking at the rim, not the tire.
  5. Sep 19, 2018 at 7:43 AM
    l3LUEFALCON
    Josh
    North Houston Area
    I've taken it to Midas and Pepboys.
    dcsleeper408[QUOTED] likes this.
  6. Sep 19, 2018 at 7:54 AM
    l3LUEFALCON
    Josh
    North Houston Area
    From Midas
  7. Sep 19, 2018 at 8:00 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    could be your driveway is sloping up on that side? Agree above, look/check the rim.
  8. Sep 19, 2018 at 8:08 AM
    l3LUEFALCON
    Josh
    North Houston Area
    C
    Heck the rim for what, to see if it looks straight.
  9. Sep 19, 2018 at 8:08 AM
    l3LUEFALCON
    Josh
    North Houston Area
    I think I'm going insane with this.
  10. Sep 19, 2018 at 8:09 AM
    Jengel451
    The Bitterroot, MT
    that doesn't look off to me. I think it's your driveway
  11. Sep 19, 2018 at 8:11 AM
    l3LUEFALCON
    Josh
    North Houston Area
    On the last set of tires I had, it looked more worn on the outside of the tire.
  12. Sep 19, 2018 at 8:12 AM
    l3LUEFALCON
    Josh
    North Houston Area
    Any of yall using P-metric tires or o ly LT?
  13. Sep 19, 2018 at 8:15 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    this picture look straight to me.
  14. Sep 19, 2018 at 8:16 AM
    l3LUEFALCON
    Josh
    North Houston Area
    Maybe y'all are right. Maybe I am just going crazy and not looking at it right.
  15. Sep 19, 2018 at 8:19 AM
    l3LUEFALCON
    Josh
    North Houston Area
    There is no pull unless I'm turned completely. It will not set itself back straight when I'm turned all the way in. But that's understandable to me.
    Watt maker likes this.
  16. Sep 19, 2018 at 8:27 AM
    2015Crewmax
    2015Crewmax New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    Mine looks the same no matter where i park. looks like it has crazy camber issues.
  17. Sep 19, 2018 at 8:34 AM
    l3LUEFALCON
    Josh
    North Houston Area
    Ha! I'm not crazy! ..... unless we're both crazy?:crazy:o_O
    2015Crewmax[QUOTED] likes this.
  18. Sep 19, 2018 at 8:37 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    no. i used to do alignments all the time. LOTS of shops do a TOE and GO type thing. CRAP service. they dont want to waste time on camber cause some vehicles need shims or more. if ou adjust the toe enough itll bring camber in a little.
  19. Sep 19, 2018 at 4:20 PM
    hollywood d
    hollywood d New Member
    2014 SR5 Tundra
    Mine does the same thing. It has worn the outer edges of my tires more than the inside. After taking it to various alignment shops and wasting a bunch of money one guy finally told me, that's just how trucks are. I don't know that I necessarily buy that but I haven't been able to get any shop to adjust it any better than yours is. The outer edges of my tires are 2/16 more worn that the inside edges. I rotate every oil change. I have about 42k miles on my BFG KOs and I will probably get another 15k out of them with the way it is now.
  20. Sep 21, 2018 at 2:01 AM
    Mtbrider541
    Mtbrider541 New Member
    Eric
    Medford Or
    2015 Tundra CM TRD
    Front and rear bumpers, ICON stage 1, Zone UCA's, Custom made airbag mounts with firestone bags, Body mount chop, ICON progressive rear leaf pack 1 inch lift, OME greasable rear leaf shakes & bushings, 295x70x18 Toyo Open Counrty ATII, URD Maf calibrator, K&N Intake tube w/ OEM Airbox, AFE Trans Temp and AFR Guage w/ Lotek guage pod, leer 100XQ with leer locker, Mangnum RT steps, and Trail Ridge tow mirrors.
    If the lift you put on is new and raised the front of your truck then you need to do one simple thing to fix this. Jack up the front of the truck but do not it keep the jack under the lower control arms, use jack stands on the frame placed forward a bit of the front doors. Mark the position of your lower control arm cam bolts and then loosen them. They should twist or pop when they become free. You will know they are loose because you'll be able the turn the bolt side of the cam fairly easily and see the control arm move in or out of centerline. Then take your socket wrench and tighten the nut until there is no play left (5 to 10 ft lbs) do this to both sides. Once complete lower the truck back down and drive in reverse to the end of your driveway straight and then back forward. Crawl under the truck (not on jack or stands) reposition your lower control arm cam bolts back to the marks you made in the begining and tighten to 207 ft lbs. This will correctly index your lower control arm bushings to your new ride height. Lower control arm bushings do not twist themselves only the LCA moves. When you lift the front and obviously push the LCA down at an angle the rubber part of the bushings are put in tension and will always be fighting to return thier original position, thus making alignments to go wonky.
  21. Oct 10, 2018 at 12:41 PM
    Mtbrider541
    Eric
    Medford Or
    2015 Tundra CM TRD
    All my alignment numbers as promised
  22. Oct 11, 2018 at 5:01 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    looks like they did a Toe and Go. The set the total toe as close to perfect as possible and ship it. I have seen that done A LOT
  23. Oct 11, 2018 at 6:32 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Go some place else and take a picture or look at the truck. It might be your driveway and how the truck sit;s right in that spot.
    My driveway is not flat and its on a incline so some days my truck or car looks like its leaning to one side.
    Pics of my drivway for refrence.
  24. Oct 11, 2018 at 8:52 PM
    Mtbrider541
    Eric
    Medford Or
    2015 Tundra CM TRD
    With aftermarket UCA's ICON coilovers and 35's I wanted zero camber to prevent inner or outer tire wear. The caster when using coilovers and UCA's is supposed to have greater positive caster. It drives dead straight and smooth. I have also removed the front sway bar which helps with undulation in the suspension and also being able to adjust each side truly independently.
