Cam tower leak
Discussion in 'General Tundra Discussion' started by TheBeast, Oct 1, 2017.
  1. Oct 1, 2017 at 6:36 PM
    TheBeast [OP] The Beach
    looks like I have it too...Just noticed minimal oil leak on both sides. It's coming from the grey sealant used there.
    Honestly it probably been there for a long time since I never noticed any oil leak on the ground. I just happened to install new UCAs last week and while inspecting bolts today I noticed the small oil leaks.
    specs: 2012 5.7L engine. 58,000 miles
    Now I have extended warranty til January 2020 so I'll probably wait before getting it fixed under warranty unless it starts to leak a lot more.
  2. Oct 1, 2017 at 9:38 PM
    Well that sucks. Personally I would get it fixed asap, but that is how I roll though.
  3. Oct 2, 2017 at 7:54 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Sorry man. I'll post a pic on my thread later with the way the sealant looks after the fix. When you have them fix the tower, make sure they remove the heat shields and clean them really well. Oil collects on them in the dimples and slowly burns off, making it smell for a while unless they are cleaned first.
    TheBeast[QUOTED][OP] likes this.
  4. Oct 2, 2017 at 11:53 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    That sucks! I'm in the same boat, its pretty disheartening. I noticed it last oil change and have been watching it pretty diligently. It seems pretty minor and hasn't gotten any worse but definitely has me concerned. Im at 55,900 and dont have an extended warranty. Maybe someone can answer this for me as I'm the second owner....is this covered under the 60,000 warranty regardless of ownership? From what I've read I'm under the impression that it is covered but there always seems to be a 'catch 22'.
  5. Oct 2, 2017 at 11:54 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    when is your date of first use? slight chance your still under 5yr/60k and i would get it covered now rather than later.
  6. Oct 2, 2017 at 11:56 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    no its covered under 5yr/60k powertrain, I do all of them for my dealership i dont have a 'catch 22" except to give me a a few days with it so I dont have to rush and make sure its done and wont leak again.
  7. Oct 2, 2017 at 12:04 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    X2 get it fixed ASAP. Like that you can monitor it while you have lots of warranty left.
    Had mine fixed about 20,000km ago (12,400miles) And not a problem yet, and have pulled my camper with it. Still runs like new.
    It’s a black sealant, so far so good :thumbsup:
  8. Oct 2, 2017 at 12:56 PM
    January 2013. thanks. how difficult/long is the job ?.
  9. Oct 2, 2017 at 1:00 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    yea you should still be cover. And it really prolly depends on the tech, you pull out the cams and the timing chains, to me its more meticulous because there is alot that can go wrong even if it all looks ok. I do them in about half a day, warranty pays about 15 hrs. but i do a lot of heavy line, over 90% for my dealer and all 4.6 & 5.7 engines. when i start on them i dont stop until they are all done, so thats why i ask for a few days to move my work load around that repair.
  10. Oct 2, 2017 at 1:02 PM
    too bad you are not in CA :) now to find a dealership that can handle it here..
    trdlife likes this.
  11. Oct 2, 2017 at 1:05 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Fingers crossed that they fixed this for the 16's. Still haven’t heard of a case past 2015.
  12. Oct 2, 2017 at 1:06 PM
    yes so far 2010 to 2015....took them forever to fix the issue I should say..
    BlueFalconActual likes this.
  13. Oct 2, 2017 at 1:09 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Yes very true and im glad someone else had noticed, i have not done any actually built in 2015. I have done "1" 2015 built in late 2014. I think they finally got it
  14. Oct 2, 2017 at 1:12 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    From what i see, maybe i should be out there, seems alot of people could use a good toyota master lol, plus you guys have fun areas to drive and places to play, I have wheat lol, lots of wheat. And sometimes what helps is just talking or asking the tech how the feel about it, I dont mind, I have several great tundra customers here that were having a bad experience until you talk to them.
  15. Oct 2, 2017 at 1:12 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I read somewhere (can’t remember where) that they found out what was causing the issue and fixed it in 2015.
  16. Oct 2, 2017 at 1:14 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I know they have done multiple changes at the plants, from how its applied and where its applied, theres a list lol. But I think they got it.
  17. Oct 2, 2017 at 2:07 PM
    I cleaned up the seams last night and drove to work. Not seeing any oil sipping out right now...no burnt oil smell..nothing..odd
    trdlife likes this.
  18. Oct 2, 2017 at 2:18 PM
    duece292
    Greg
    Green Bay, WI
    Thanks Tim! Now to psych myself up to take it in lol. I know master GM and Mopar tech's but don't know any master Toyota tech's at the local dealership....wish I did.
    trdlife[QUOTED] likes this.
  19. Oct 2, 2017 at 6:50 PM
    sent an email to toyota see what they have to say and now trying to find a dealer in SoCal that would perform the work.
    duece292 and trdlife like this.
  20. Oct 4, 2017 at 3:46 PM
    alright guys, Toyota got back to me. Nice phone call and opened a case number. I followed your advice and dropped the Beast at Toyota dealership today. They ordered the parts for both sides. I'm now driving a Nissan Sentra......black...of course..;).. I feel like a half man driving it on the freeway..lol
    mdavis, duece292 and Y0TA PR0 like this.
  21. Oct 4, 2017 at 4:38 PM
    gdiep
    Syracuse, New York
    I'm sure they'll get her fixed right away.
  22. Oct 4, 2017 at 10:06 PM
    duece292
    Greg
    Green Bay, WI
    @TheBeast, sounds like she's on her way to being good as new again. I'm needing to do the same. If I can ask, how and who did you contact at Toyota to get the ball rolling and did they have any suggestions on what dealership to take it to?
  23. Oct 5, 2017 at 3:49 AM
    gdiep
    Syracuse, New York
    I called customer care 800 number to get a case started. I was frustrated by the dealership where I purchased the truck, but Toyota asked me to continue to work with them. Toyota sent out a master tech to school the dealership and customer care helped me with a warranty afterwards.
    blizz86 and duece292 like this.
  24. Oct 5, 2017 at 10:54 AM
    @duece292
    honestly I called Toyota to open a case so they would have a trace of my request and could monitor in case I would run into issues with the dealership I would go with. They wouldn't recommend any dealerships since they compete against each others.
    I just asked my Toyota mechanic (independent shop owner now) to recommend me a dealership with good mechanics around here. He sent me to that one. I just showed up and they checked the leaks and ordered the parts, gave me a loaner and sent me my way. They didn't try to argue or whatever. I'm guessing I'm not the first one to come for that issue. It's probably the biggest dealership in L.A. Now hopefully it gets fixed the correct way and the first time but I still have plenty of warranty left to monitor any issues or not.
    duece292[QUOTED] and Y0TA PR0 like this.
  25. Oct 5, 2017 at 11:47 AM
    Did I mention I miss my Tundra ?...I'm having withdrawals and the Nissan Sentra ain't helping..lol..I tried to floor it on the on ramp this morning..and nothing...:ballchain:
    duece292 likes this.
  26. Oct 5, 2017 at 12:02 PM
    blizz86
    blizz86 New Member
    Good to know this info man, which dealership? You can PM if you are hesitant to post it here.. Does it start with H and end with ER?
  27. Oct 5, 2017 at 4:28 PM
    duece292
    Greg
    Green Bay, WI
    I know the feeling! Every time I get a rental I'm quickly reminded of why I hate driving cars lol.
    Thanks for the info! I called Toyota today and had them open a case as well. The girl I spoke with, although a little hard to understand, was very helpful and very quick to assure me that I'm well within the powertrain warranty. I called the local dealer and have an appointment set for them to look at it and see what they need to do the job. My S.A. at the dealer wasn't sure if they'd ever done one of these so hopefully they've got a tech who's confident in his abilities.
  28. Oct 5, 2017 at 4:40 PM
    the thing you want is being documented by Toyota: the more paperwork the better in case it goes south.
  29. Oct 5, 2017 at 4:50 PM
    duece292
    Greg
    Green Bay, WI
    That's what I thought too and is why getting Toyota involved prior to going to the dealer seemed like the best way to approach this. I have a pretty good relationship with my S.A. (for the few times my truck has been in) so I'm confident he'll get me taken care of. I guess all I can do now is cross my fingers and hope for the best :rolleyes:
    TheBeast[OP] likes this.
  30. Oct 6, 2017 at 2:02 PM
    might be ready tonight. I requested they steam clean the engine too
    Wynnded, duece292 and Y0TA PR0 like this.
